99silverado vibration problem
I am perplexed though. The dealer had initially taken steps to correct some of the problems, then said it was operating to specs, but now they are calling in the rep.
Could anyone with experience dealing with the rep please comment on what they make of this? Thanks.
Silverado lemon is being turned into the dealer
Monday. I will take a $1557.50 hit for miles driven and I'm still on the hook for the GMPP warranty(hoping they will be more reliable than GM) and believe me, I hate that.
Worse however is the way I was treated by GM, with the exception of one or two (at most) people that I have spoken to at GM it seems that their main objective is to get you to accept that your vehicle is "good enough" and they are granting you huge favors just by talking with you.
The ASM was telling me how much GM is "Helping
me out" and losing money with the purchase of a new truck, at the same time he was trying to get me to buy a truck $1187 over invoice. Calling the dealer on the phone gets you $100 over. What a guy.
When the sales manager called me yesterday to
tell me the check had arrived, he wanted to know
why I sounded so bitter. GEE, I don't know, maybe
having to fight with your dealership and GM for 5
months to take care of a problem with your product
and having to pay for that pleasure makes one a
little bitter?
I am persistent and I had trouble wading
through the Bull$h** that they throw in the path, I can't fathom how a anyone that is the least bit timid gets around this B.S. Then again, maybe I am just a little bit too intense and I could have gotten further faster with a little less "Tude"". Nah, nevermind. This is actually a thank you to all the people here who pointed me in the right direction when ineeded help.
Ed
Looks like we are going to have to solve it for Chevrolet, cause they aren't doing too well for themselves.
Like I said, the new tires setup with the new balancing machine made a noticeable difference, but it ain't close enough yet for me.
-Funk
If anyone with these problems has access to a laser printer (or other fast printer) can print all 376 pages about vibration out...I think we will all prove a point to them....
If anyone with these problems has access to a laser printer (or other fast printer) can print all 376 posts about vibration out...I think we will all prove a point to them....
http://www.accessatlanta.com/partners/clarkhoward/consumer_help/cars.html
Click on the topics below to find some great tips and ideas from Clark Howard's book "The Consumer Survival Kit"
• Car Accidents
• Car Leasing
• Car Recalls
• Car Repairs
• Lemon Law
• Buying a New Car
• Buying a Used Car
• Arbitration
• Trade-ins & Financing
say, 30000 miles of moderate duty.My truck vibrates too , and I`m sick about it.I don`t know wether to turn it in or try to have it fixed. Its a 2000 1/2 ton 2wd long bed 277 miles on it.
Dealer has replaced trans, xfer case, rearend, and drive shafts. Problem still there.
Perhaps these letters should be in a topic list of their own instead of 1999 vibration problems. Anyone else have the same "problem"/condition?
We had our first snow here in OK and when I pressed on the brakes hard the pedal went way down and then came up by itself and made a loud clacking noise. Loud enough to hear over the radio. Is this normal?
of my complaint. I was told Chevy has cancelled the buyback program for trucks because it is not a
safety problem and will cause no abnormal wear on
the trucks. Chevy says their technical assistance
is working on the problem and are working toward a
resolution by the end of March.
I think they've been working on it for about 19
months already, what makes them think they can fix
it in another month or two?
Looks like we're hosed again, because folks were
letting the dealers try to fix because the buyback
was always an option if they failed. No more.
Kingfishgus,
Contacting GM Cust. Service is not going to get the job done. It is a necessary step in order to make it seem like you have done everything possible to correct the problem from your end but it does nothing to get your money back. You must contact the BBB number in your owner's manual and follow every step required by your state's Lemon Law. Keep real good records, names of people that you have talked to, etc. and good luck!
NO MORE SHAKES, PINGING ENGINE, HARSH SHIFTS....
have read through all the comments and discussion
and am having a hard time determining if the
vibration and other driveline problems are just
1500's or do they also affect the 2500. If I find
the problems are not with the 2500 I will continue
to find my dream truck.
Good luck to you!
LS(lemon shaker)x-cab, reg bed truck too. I had three set of tires replaced(General tires), front hubs replaced, shackles, to no avail. Tires can cause shaking according to an engineer friend of mine. The tires GM is putting on as stock tires
are not even sold retail(see if available in your area), probably not. After my last time at the dealership in which it took 8 weeks to get my truck back, the very next day SSSHHHaaakkkke.
At that point, Service Mgr. recommended buyback.
GM customer service is USELESS. 4 more weeks passed and I decided I had enough GM BS. I hired a Lemon Law(car) lawyer and won my case. Don't let GM shove this bad product down your throat, you have an option.
Did some investigation, Found out that left side had been damaged before delivery. Not Disclosed to me. Dealer wants to Repaint! Truck has only 3000 Miles on it and I have had it only 3 Months. What are my options? Do I have to accept this resolution? Isn't this considered a Failure to Disclose Information? HELP! Advice needed!
So the disclosure statement probably says you waive your rights, after not finding anything wrong at time of inspection.
The dealer will say, we had nothing to disclose, because we found the damage and repaired it before delivering to you.
I know that's cynical, and I hope I'm wrong about all points. Understand the angle, expect the worst, hope for the best.
No matter what you signed, you can still sue and win, especially if it involved deception by a car dealer or manufac. Juries are sympathetic to those type of problems since either they, or a person they know has been shafted in some way by a dealer or manufacturer, and being on a jury gives them the chance to get revenge.
There are plenty of lawyers that would love to handle your case on a commision basis.
I realize a tire shop will do this for free. My concern is with the air-impact wrench. It is possible to warp a rotor if they tighten the nuts this way. The proper way is with a torque wrench.
Anyway, I have not re-balanced yet, still no vibration at 23,000 miles. '99 Z71 4x4.
as you guys ,i had a arbitrator put down the
same words ,that its a charistic problem with
other trucks and its not a safety issue.isn't it
amazing it was worded exactly the same as the gm
comments its like i never had a arbitrator it come
strait from gm.
looks like i got it this time but it won't happen again.
Ed
what is a good price to ask for my shaker,and how much on a trade in,its a loaded 1500 silverado
with 10500 miles on it.how much did you guys get on your trucks.
Boy i'll bet that ford & chrysler would like to have a commercial!LIKE
do you want a shaker or do you want a real
truck.
like a rock(it would float good in water).
