Handling problems on icy roads
I own a 2001 Lincoln LS V8, and love the car. The only problem that occurs is when I drive on icy roads. The whole car seems to float, and will wander at will. This is not an isolated case, as I have talked to an owner from Colorado and also One from Canada who have the same problem.I am retired,currently and spend my winters in Arizona, but the drive home to Canada in spring can be adventursome to say the least. (Thank God I don't have to winter at home in Canada). If any of you owners have encountered the same prpblem, or have any solutions, I would appreciate hearing from you.
I run the Blizzaks since I live in an area where we generally receive a lot of snow from November to April, but the traction that the Blizzaks provide on ice has really been a great bonus. I'm an old dinosaur that still hasn't bought into the "All-Season" tire idea yet. I prefer to change over each season.
Perhaps it is a fault of the tires or the alignment that is causing the problem, but I think that the LS is quite stable on ice, snow, and rain.
Lot's of luck to you.
there are major fundamental differences in how tires attack this. most don't. if legal in your area, which is not common any more, adding carbide studs to existing holes in compatible tires is better than chains... but the studs tear heck out of roads that are not covered in ice.
a few types of winter tires use tricks like bubbles or suction cups in the rubber (like gecko feet) to squeeze out that microinch of water and grip far better than regular tires. they wear faster for the most part, and you'll want to rotate them with your 8-month tires as a result.
none of them let you drive 85 mph on glare ice. you still have to slow down, drive the car through turns instead of jerking the wheel and letting the friction of the tire's tread and edges cut you around in the circle, and allow plenty of extra space to brake.
I'm in an explorer myself, and after the nasty performance of the => KILLER TIRES! <= tm in all conditions, have been happy with the general ameri-650s I got in the "customer satisfaction exchange." that experience, unfortunately, doesn't help you much.
At 1st I thought it was just the winter since my 1st spring and summer with the car were awesome but last summer and so far this winter it sux.
Alignment has been checked 3 times and I've had 3 different sets of wheels and tires on the car with no luck. The best combo I've found so far are my snow tires on 16" Lincoln wheels.
I can hardly wait to get rid of this thing and with my record of bad cars from Ford I don't see how I can go back.
But if you mean just icy hard-pack, I'd say tire selection and careful tire pressures would certainlly help you.
For sheer ice, stay home!
you should then ask 'em if they stock chains :-D really freak them into the next dimension
I don't see too many "Z" rated snow tires because you don't usually exceed 149 MPH in the snow. Directional snow tires? Yes, GoodYear makes them, and there's a set on my S-10 4X4. They'll go through most anything. The previously mentioned Dunlop Graspics are on the Lincoln, and serve my wife quite well.
circlea
Stopped at a stop sign, switched off the TC, and nailed the throttle. Just like any other car, the LS slithered all over the road, and went nowhere quickly. Continued up the street to the next stop sign, switched on the TC, and tried this trick again.
The computer modulated the throttle and anti-lock system, and the car accelerated straight as an arrow. Naturally, it didn't take off like a rocket, because the laws of physics won't allow that, but the car did move off smartly and straight. Try this with your car.
If your car doesn't act like mine did, go to your dealer and have them check the TC system. If you're reluctant to do my "test procedure", just go to the dealer directly.
My wife is the primary driver of the LS. If she's happy with the car in the snow, the TC must be working quite well, because she's a fairly timid driver.
thanks again
circlea
After that my LS never seemed right again. I don't think the traction control ever worked right after that. It became almost undrivable in the snow. The slightest touch of the throttle and the rear end would kick right. Almost did a 180 a couple of times. The only good news is that is is amazing how sidways you can get a LS and still recover.
I had the Ford field engineer involved on another problem and while he was looking over the car he found what they called a "broken right rear strut" I assume they ment the shock since the LS has double wishbone suspension. After they replaced the "strut" it was better but still not like new.
With traction control ON I could often spin the right rear tire on dry pavement and if there was any sand on a dry road I could spin the rear tires with ease. The Traction Control light on the dash would blink, but it wounldn't do much of anything to keep the tires from spinning.
I test drove an '03 and nailed it on some snow slush and on wet sandy road and I could not get the slighest amount of tire spin. If I floored it on the snow slush it would almost feel like the engine died and the car would slowly move forward.
My conclusion is that the dealer broke my TC when they worked on the car and it sounds like circlea has a similar problem.
Mine never has been (the camber, that is), and this sort of "annoys" me. There's no way to make any adjustments, and all the dealer says is, "It's within spec". Yeah, it's within spec, but one side is at the top of the spec, and the other side is at the bottom!
The "strut" replacement and rear alignment GREATLY improved the car on dry roads. After the halfshafts were replaced and begore the "stut" fix the car would wander all over the place, even on dry roads. It just wouldn't drive straight. You couldn't take your hands off the wheel for 2 seconds. Seemed similar to some of the complaints others have made about their LS's being real cross wind sensitive.
After the "strut" fix, my LS was just fine on dry roads. On the center lane of a 3 lane interstate I could cruise at 80 with my hands of the wheel, just like a LS is supposed to do.
However the TC still didn't work right. When driving in snow I could still easily spin the rear wheels (TC on), but while the rear end still wanted to kick right, the tendency was substantially reduce.
Can't tell you anything about camber settings, my dealer's service department is the type that doesn't want to tell you anything about what they did.
The automatic allows 2nd or 3rd gear starts, at least with the SST option, but I haven't found it very useful. It takes so much throttle to get the car to move in the higher gear that, if a wheel does break traction, it starts spinning very fast.
The kind of wild behavior we're reading about here leads me to believe something is wrong with the TC, or something. I've driven lots of RWD cars on snow & ice and never had that kind of trouble.
I'll try mine with AdvancTrac turned off next time there's a safe opportunity. IF it ever snows again in Colorado.
