New S40/V50
The FWD S40 T5 will not have any more torque steer than the S60 2.5T (which is not a lot when compared to other FWD cars). Amd the S40 will not be classified as a "luxury" car, anyway.
Someone posted a concern about the HALDEX system "hindering
the 220-HP T5 model...that is absolutely not true. A simple question goes as..."has the haldex hindered the S50 2.5T AWD"??? Anyone who has driven that car will say "NO"! And the S60 2.5T is a low-pressure turbo engine!
Yannis
According to EVO, there will only be FWD T5 for now. The AWD won't be ready for another year possibly sometime in '05.
Which class? The new S40 got a longer wheelbase than the Mazda3/Focus II, & more passenger room than the S60.
however, i have to respectfully disagree that the AWD won't affect it. It adds weight, period. Ok, so, if designed properly, it won't affect it MUCH, but the extra weight will slow it down even if its just slightly. Its a trade off. I've really grown to like AWD in some cars, so it might be a worthwhile tradeoff. I'll cross that bridge when I come to it.
by the way, if you feel up to it, there is a question on the s60 forum regarding the demise of the T5??
Since I don't like turbo/kompressor, I might even prefer a non-turbo AWD S40.
the S40 T5 is, according volvo, going to have about the same 0-60 as my s70 T5. And, as i stated before, the torque steer on that is not bad (compared to some others I've driven). Its not all about power-to-weight that causes torque steer. Many other factors go into it. For instance, probably the worst example of torque steer I ever experienced was an Alfa 164. 210 HP in a fairly heavy luxury sedan. 0-60 somewhere in the 7.5 sec. range. So there are others that are more powerful and much faster that have LESS torque steer. Its all about engineering.
Of course, I'm not saying the S40 WON'T have bad torque steer because, obviously, I have yet to drive one. But don't count it out until you do.
Torque steer is fine if your buying a Dodge, but when your spending real $$ for a (near) luxury car it should be unacceptable.
Hence the need for Volvo to go AWD, and the Haldex is a great system.
by the way, a limited slip differential would eliminate torque steer just as well, but cost less and impact weight less than a full-blown AWD system. So that is not an excuse for volvo going with AWD. They are doing it purely to step up to the plate in a competitive market.
Volvo is stepping up as you say because there are other choices in the marketplace with superior driving dynamics
Hey, I love Volvo, but there has ALWAYS been cars in the marketplace with superior driving dynamics.
Again, i like AWD, but its not necessarily the cure all. There are plenty of incredible cars that do incredible things without AWD. Volvo is adding it for marketing purposes and possibly safety. Driving dynamics is last on their list. If it were top of their list, then they would offer RWD and AWD instead of FWD and AWD.
LSD on a FWD does help putting the power down accelerating hard out of a corner by avoiding just having one tire spinning. But torque steer? I don't think Nissan Maxima got rid of it w/ LSD. In fact the latest Mazdaspeed Protege turbo has its LSD shifting torque left & right, & tugged the steering annoyingly.
"Driving dynamics is last on their list."
I sort of agree. That high-performance AWD S60 didn't provide any bit of the drifting fun from the rear. But at least the Focus-steering S40/V50 should have the best steering feel/feedback ever.
I guess only BMW bother to power, rather than braking, in their next AWD vehicles' ESP program to adjust the understeer/oversteer balance. Now, that would be lots of fun driving an AWD.
sometimes i think manufacturers should consider developing new versions of the old posi-rear (positraction differential) to use in some applications.
You can ask the tires to perform only one function at a time.
Either steering, or traction. But not both.
In a turn the front wheels are ALWAYS moving at different speeds, so a true posi trac won't work.
Even an LSD has to let the front wheels turn at different speeds.
The torque effect can be reduced, but never eliminated in a powerful FWD car.
Hence AWD, or re-engineer your car as RWD.
AWD has its issues as well. So does RWD. Each configuration has its pros and cons. None is the perfect solution. Hence the existance of all these setups.
you can't ask for steering and traction? Obviously, if that were true, the car would never turn since the turning wheels actually need traction to make your car go where you want it to.
The FWD turbo will be available from the start w/ auto and manual gearboxes.
Dealers should have 1 test vehicle by Mar 1 and saleabe cars in either May or June.
The new S40 gets an excellent review, and I suspect that their one complaint (occasional transmission "snatch") will be addressed before production starts.
Nice seats. Dorky interior styling, though.
http://www.autoexpress.co.uk/?previews/previews_story.php?id=4108- 6
“The chassis does things that have never been done in a Volvo before. None of its models has ever steered as crisply, keenly and fluidly as this one Volvo engineers knew the steering has been a past weakness of their cars, and at last they have done something about it This is more fun to drive than the S60 ”
So, all this talk about the great handling of the s40 vs. other Volvos may not mean that much to most Volvo owners who value the overall comfort and day in, day out, feel of the car as well as active and passive safety features.
Even a base BMW 3-series coupe is pretty pathetic in town(& even on the fwy) for its lowered std sport suspension.
Volvo isn't doing that well in the following 2 areas for convenience & accident prevention:
Volvo isn't just ignoring the importance of curb-to-curb turning circle, they also made the wall-to-wall u-turn worse by stressing the importance of long front overhang.
At least the new S40 has its front corners pretty much rounded off so the wall-to-wall u-turn isn't that bad. The Mercedes C-class has the wtw turning circle nearly the same as the ctc.
Volvo's recent pronounced shoulder "trade-mark" that makes the car look tough for side protection actually hurts the rear glass width, which makes a difference helping the driver seeing the vehicle on his right lane right behind. For example, the car in front of you suddenly stopped, & you don't want to miss any opportunity changing to the right lane immediately & safely. Or you're simply doing passing on a 2-lane hwy.
You can't turn the front wheels 90 degrees, the front axles won't allow it.
The turning circle of the 850 is 33 feet. Volvos were always wonderful at turning around in a small amount of space for their size and making tight turns, they've gone backwards in this regard.
Can't Volvo put in some rear steering or something to improve the turning circle to about 35 feet or so on the s60? I think on the new s80 and v70, s60 replacements reducing the turning circle must be a priority. Now it's a chore to park these cars in tight parking lots.
The 960 was 31 ft. Because it was RWD
The S60 is wider than the 850, and has much wider tires with no corresponding increase in the wheel well size.
4 wheel steering adds weight and complexity to the car, so I doubt that Volvo is seriously considering it.
imho, the harsh ride of the m3 doesn't exist.
it is definitly 'firm', but nothing out of the ordinary compared to my '02 explorer or '91 mustang gt. too many people take what c&d says as gospel.
You can't turn the front wheels 90 degrees, the front axles won't allow it."
W/ RWD, turning the front wheel 90 degrees won't even allow the rear wheels to push the car forward. Only FWD can roll the front wheels side way at 90 degrees.
It's all conspiracy from car companies to make the small cars' turning circle about as large as the bigger cars, so when people stepping up to the next higher model won't get upset when they have to sacrifice the convenience & pay more $.
Nissan didn't want to disappoint the people used to the old RWD Datsun 210's convenient tiny turning circle. So the FWD replacement - the Sentra - kept the tiny turning circle for several years!
The V6 Camry had 36.7 ft curb-to-curb turning circle. The RWD V8 '95-98 Lexus LS400 has only 34.8 ft ctc! When measured wall to wall, that LS400 is even smaller than the 4-cyl Camry, as the FWD Camry has a longer front overhang.
"Yes, but the Accords turning circle is 36.1 feet and the Camry's is 34.8 (with the 4 cyl and auto according to Edmunds). The Camry's is better than my rwd C240 and it is considerably bigger."
The C-class has a very short front overhang corner so the wtw turning circle should beat any Camry.
Honda is actually a very pretentious company. They tried to earn business from people who are against Japanese cars by claiming that the company headquarter is in America & called themselves "American Honda". Next, they kept the required "CHECK ENGINE" dash warning light from coming on so the customer satisfaction rate went up, & ended up w/ a big fine from the U.S. government. Since we used to associate Honda w/ the tiny Civic CVCC hatchbacks, Honda purposely kept all the Accord's exterior dimensions AND turning circle bigger than Camry's to sound like a big car, although, in fact, the Accord had rather poor stretch out leg room up to '97. Wasn't that "36.1" vs Camry's "34.8" sound peculiar? As if "36" is whole lot bigger than "34". Come on, only in American do we use "feet", as rest of the world is all metric.
it is definitly 'firm', but nothing out of the ordinary compared to my '02 explorer or '91 mustang gt. too many people take what c&d says as gospel."
Duh, mentioning the buckboard-riding crude vehicles is out of the question. There are always the Suzuki Samurai & the Jeep Wrangler WW2 military vehicle.
The BMW 3-series sport suspension's ride comfort is still a dream compare to other sports cars, per C&D, etc. But I'm only willing to tolerate the ride of the non-sport longer-travel suspension found in the base 3-series sedan(not including the recent 330i).
Also, when the road surface gets ragged, the torque-steer tugging becomes more obvious.
They also warned you that you better back off the throttle when the front tugs/understeers, or else. Once the traction control kicks in, it won't let go for a long time!
No, the light pressure turbo doesn't have enough delay to create lag, just soft throttle response. Low end is so rich that the 6-sp isn't even needed. The R model will be the one w/ the hardcore turbo setting.
The non-turbo model may be much weaker at lower rpm, but is enjoyable to rev, plus w/o any of the vices of the turbo model mentioned above so handles more fluently. The higher-profile tires on smaller diameter wheels are just as wide as the turbo model at 205/55, so the road contact/grip is still there. Along w/ the softer suspension, the ride is better, too. For sure they like the non-turbo more than the FWD T5!
well, then how about this one:
http://www.swedespeed.com/features/road_tests/s40_t5_2004/index.s- html
They seem to love it. Best handling Volvo ever (aside from the R) and handles like a RWD, according to that article.
And considering the S40 T5 will have about the same rate of acceleration as my current T5 and I have none of the issues to the degree of severity that CAR supposedly states, I find their review less credulous. But, only time will tell. We'll find out the truth for ourselves.
Not bad, now the new S40 gives you the choice to do some rear slide.
and is the S40 roomier or less roomy than my 99' Civic????
Remember it's the stretch-out leg room that counts, not the knee room. That's also why I found the Civic sedan roomier than the pre-'98 Accords.
Driving enthusiasts like it. Unskilled drivers need it EVEN more! Some steerings seem firm, but feels totally washed out at the limit, such as the present Jetta. The steering of the '86 760 Turbo I used to own is simply just heavy w/ no feeling, & worse, can't even track straight on the fwy w/o lots of concentration!
NOT just at the limit, the steering should be able to inform the driver if the tire still has adhesion EVEN WHEN going in a relative straight line, as an Focus engineer pointed out. An example is the Acura TSX's steering. It always feels like there's no tire adhesion, despite feeling firm due to strong self-centering action. Sure, the car goes fast around corners & even able to absorb bumps the same time. But an average driver who drove it on a high-speed fwy curve got scared & complained that his Mercedes C220 didn't have this problem.
Bottom line: Is the 2004 S40 a good car or not? Other options I'm considering are the new 2004 Mitsu Galant and possibly a Subaru Impreza, which a friend just told me was a great car; the Subaru is pretty ugly IMO, so I don't know if I can get past that!
