Ford Ranger 4.0 Engine Problems
                    Am I the only one out there?  Have you ever
listened to your 4.0 V-6 engine (1998 Ranger 4X4,
driven easily and dealer maintained) - with the new
5-speed transmission (this may matter, not sure
yet) at idle - no load on engine - not in gear, no
a/c on? You just might here a noise you don't want
to hear - uneven piston knocking? So far, that is
the best my dealer can figure out. And, so far, a
truck that is only 15 months old with 17,500 miles
is truly not like new. The engine has been
totally rebuilt - about 2 weeks in the shop, mostly
waiting on parts from FORD. (The dealer wanted a
new engine - FORD says no, try to fix this one
first.) And, it still is not right. The dealer
has rebuilt the engine back to what I think is
better than factory specs - it feels like it was
when it was new and maybe better. BUT - now I
know the noise! And, I already hear it again - not
loud, but less than 100 miles since the rebuild!
So, just letting others know - I have a dealer
doing all they can, but FORD did not go along with
the proper fix. After over 20 years of buying Ford
trucks - this may very well be the last. Thank
you Toyota for finally braving the world of our USA
dominated trucks and building a truck that we may
all consider usable. Does Ford not care that we
spend a lot for their trucks, many have been
incredibly loyal and now I have to be without mine
again for who knows how long? At this point,
before the inevitable e-mail - I will pursue
arbitration.
arbitration.
Shame on Ford though.
I own a Ranger just like yours 4.0 5spd. I only have 15K, not one problem.
As far as the Toyota is concerned, check the sheet metal thickness and the bracing compared to the Rangers. At 75 mph, the Toyota's hoods really vibrated and shook badly on the ones I test drove. I drove the Tacoma and the T100. The metal thickness is less than the Ranger. It makes you wonder if a front end collision would end your driving days. Check the safety records on these trucks before purchasing a Toy. I believe the Ranger is the compact truck to drive.
Rat
14,000 mile no problems and seems to run fine. First alignment at 13,000 miles, 3 offroad 10,000 foot 4X4 passes in the rockies and it was still within specs, just minor tweeks. DO BE PREPARED TO SPEND $40 A SIDE TO GET CASTOR ADJUSTERS. Suppose to eliminate drift.
I've replaced the fuel pump and all filters. Vacuum lines are good. Relay is good.
Anybody have another idea?
ADDRESS IS WWW.FORDRANGER.COM HOPE IT HELPS
PAULJ
I was reading a guys post elsewhere. He had the pump cut out every so often. Had pump/relay changed.
He found a build up of corrosion or something on the fuse in the engine compartment. Changed fuse and off it goes so he says.
Try that.
Had a 93' that with the four cyl. that is still going after 187,000. Does not burn a drop of oil and has never had anything more than new brakes, tires, shocks, and the occ. tune-up. I'd won't be
switching from the ranger line-up anytime soon, and would highly recommend them.
I wish we could get a better description of the noise, because it sounds to me like there is a Dealer problem rather than a Ford problem. I have had a problem with a 3.0 litre V6, and a 3.8 litre V6, with piston slap in the first couple thousand miles. Ford put another motor in both of them, and I ran them both to 80k with no problems
Jason C. Lake Charles, LA
with towing and these engines?
I have a 1998 Ranger 4x4 3.0l 5spd and it does not tow my 2300 lb boat very well, I have to slip the clutch a bit to get it going..sure I know it is right at the towing capacity for the truck, but didn't know I was going to get a boat this early.. I am looking at full size with V8 as it is pretty hilly here in Colo....Couldn't tell you much about the 4.0l but I don't think an extra 40 ft lbs is going to make that much difference when pulling that kind of weight, but hey the auto can tow more than the manual, at least that's what my owners manual states.
NOTICED MINIMAL KNOCKING AT 8K MILES SLICK 50 FIXED IT. NOW HAVE 11K.
ASLO NOTICE SQUEAK IN REAR OF TRUCK. WD40 ON ALL BUSHINGS AS WELL AS SPRINGS FIXED THAT.
NOW LOOKING FOR NEW CHIP TO FIX THE SHIFT DELAY.
I AM VERY HARD ON THIS TRUCK (THE 4.0 CAN TAKE IT)
WHEN I STEP ON IT...IT SHIFT DOWN ONE GEAR (WRONG ONE) THEN DOWN ANOTHER (RIGHT ONE) AND TAKES OFF.
THIS SHIFT LAG DRIVES ME CRAZY. I NEVER HAD THAT PROBLEM WITH MY 94 4.0. THINK ITS THE CHIP FOR THIS 5SPD AUTO. WILL UPDATE WITH WHAT I TURN UP.
Just curious, does the boat alone weigh 2300lb or is that the boat-and-trailer combination? I ask because my boat-and-trailer combo totals about 2500 lb and I'm thinking of getting a 3.0L Ranger.
Dan
My biggest problem is getting it all going on anything more than a slight incline, have to slip the clutch to get the sucker moving, but after that it does fairly well (I have learned not to use 5th gear on the highway, truck does much better at highway speeds in 4th and still get reasonable gas mileage)...still looking for full size, too many close calls for me and my wife, we WILL have a full size before the start of the boating season next year..
Bob
Get electric brakes for the trailer if it doesn't have any, not that pulse actuation crap, when you need to stop, you don't have time for the piston in the tongue of the trailer to compress the fluid to the brakes..get electric and stop NOW!! Or as close to NOW as you can!!!
Bob
The one that listed the technical service bulletin and safety RECALL bulletin for Ranger and Tacoma from 89-99?
Oh..heres the stats
89-99 toyota comapct pickup
17 safety recalls
64 Technical repair recall bulletins
89-99 Ranger stats
80 safety recalls
290 technical repair recall bulletins
Oh..whats this? the link to the only unbiased automotive source?
http://www.nhtsa.dot.gov/cars/problems/
Happy trucking!
3.0 and a 4.0 automatic. The 3.0 couldn't get out
of it's own way. How do you 3.0, 5 speed owners
feel about your trucks?
I would have to say the power is a bit low driving in the mountains, but around town it does ok. Towing...well, already talked about that a couple of posts ago....If I had the choice to do all over again, I would've went full size in the first place, but hey in a couple of months it won't matter 'cause I'll be driving one!!
I have a 1998 Ranger XLT 3.0L 5 spd manual
Take care
The Ranger hasn't stayed Number one for the last 12 years by just luck. The Ranger is a good truck. The Ranger/Mazda are the best value, best all around compact pickup on the market today.
