A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
BMW 3-Series 2006
1122123125127128135
  • graphicguygraphicguy Member Posts: 14,120
    That 335i pricing increase is hefty. By the time you put the options you want on it, the Acura RL, Audi A6, Infiniti M35 and Lexus IS 350 looks much more attractive. Looks like if I'm going to pull the trigger, I'm going to have to do it sooner than later on a 330i.....or, start looking at the alternatives.
  • inqinq Member Posts: 10
    I don't know the answer to your question (which I also wonder about) but I recall reading an article or a post which implied that BMW North America is not merely a subsidiary of BMW but has some independent authority in the products that are introduced in the US market. So if you're looking for someone to blame,...
    Personally, I'd like to see the European 330i (DI, NA, 270+ HP) introduced here in addition to 335 and 328 but apparently the fuel we buy here is not as clean as Europen fuel. So, may be you can also blame the oil companies since we blame them for all of the world's problems anyway.
  • rayainswrayainsw Member Posts: 3,192
    $2,100 = “Hefty”?
    Faced with both inflationary pressures and a Dollar \ Euro ( um ) issue, I was actually surprised to see the difference so small.
    Not that $2,100 is trivial, but with the 328i going up a bit less than 5% ( $1,500 ) and including a modestly upsized ( to 3.0 L and 230 \ 200 HP \ TQ ) version of their I6 motor as the only significant change, I see the 335i increase as reasonable.
    The RWD 328 shows incremental improvements ( by comparison ) in acceleration numbers, according to BMW: 0.4 and 0.3 seconds, 0 – 60.
    The 335i gains 45 HP and a whopping 80 lb-ft of TQ, plus the apparent improvements to the 6 speed STEPTRONIC automatic trans. ( that would be my choice – with added paddle shift levers on the steering wheel, when the Sport Package is selected ) I see this as a rational dollar increase over the 330i. BMW quotes an improvement in acceleration of 0.7 seconds in 0 – 60 for both automatic & manual 6 speed versions of the 335i compared to the 330i. That is typically an amount of difference that can easily be discerned – by those addicted to torque. ( If it please the Court, I plead: guilty, as charged. )
    And my ** GUESS ** is that these improvements will result in quarter mile times for the STEPTRONIC of close to 14 flat, at approx. 100 MPH. Enough to be entertaining, in my book.
    YMMV.
    - Ray
    With a BMW sedan back on the radar as a possible option, come time to replaceme my current sedan . . .
    2022 X3 M40i
  • dl7265dl7265 Member Posts: 1,381
    "the Acura RL, Audi A6, Infiniti M35 and Lexus IS 350 looks much more attractive"
    I would not generally consider any of those vehicles in the same Class of a 3er, Even though it is starting to get quite Portly.
    A6 and M = 5er
    IS = joke
    RL= 50K Honda accord
    Just my 2c
    DL
  • ivan_99ivan_99 Member Posts: 1,681
    I thought the same thing…then I thought well, if they’re selling for approx. the same price you can include just about anything…Hummer etc.
    I’ve seen people cross-shop 2 seat convertibles and SUV’s.
    Seems sort of silly…but when somebody is getting ready to “plunk” down hard earned dollars I guess everything is up for grabs…then you can get into used cars (used 911).
    I thought a 2K increase is very reasonable…if you took a 330i and went aftermarket, you’d spend much more for that kind of performance increase.
  • mookmook Member Posts: 4
    Owner of a 06 325i manual sport package. 3k miles - broken in strictly according to instructions.
    I am noticing - under hard excelleration - there is a slight, brief, but noticeable power dip/hiccup/ bet. 3.5/4K RPM - not every time but it has occurred enough to make me concerned. Note - my bride has taken it upon herself to use regular gas (gasp!) on occasion - but I can hardly believe the wives tales about power problems as a result.
    I am definitely going to bring it up at the first service - but thought I'd check with the forum for any similar experiences.
    Thanks in advance.
    Mook
    Can't disagree with any of what you're saying. Problem is, even the Infinities are already at 300 HP as is the IS 350 (although I do agree that it's yet another less than sterling attempt at chasing a 3 Series).
    Acura RL is being steeply discounted now (still nice cars, no matter what the biases are) and for all intents and purposes, I believe I can snag an A6 Q for $9K off MSRP (according to newspaper ads in my 'burg).
    Point being, the price increase puts the 3 series in a whole other league with some mighty fine luxo models.
    "Note - my bride has taken it upon herself to use regular gas (gasp!) on occasion - but I can hardly believe the wives tales about power problems as a result."
    Are you serious? Dude, there are no OWTs involved with this issue as this is very well known science that dates back to the early 1920s. While you may not feel higher octane fuel has any benefit for a high compression engine, if you look at WWII (when high octane/high compression piston engines were first widly used), there are many noted individuals (General Jimmy Doolittle for one) that have claimed that were it not for our ability to produce high octane aviation fuels, we wouldn't have won the war. While I think that might be a bit of an exaggeration, it may not be too far from the mark either.
    Don't believe me? Do a little internet research over at the SAE or in the old NACA (precursor to NASA) archives.
    http://www.sae.org/servlets/index
    http://naca.larc.nasa.gov/
    The truth of the matter is that your engine WILL retard its ignition timing and cut fuel flow where and when necessary to keep the more volatile low octane fuel from destroying your engine.
    Best Regards,
    Shipo
  • sjaggsjagg Member Posts: 1
    Hello there, do you know when the new 2007 3 series convertible will come out? I heard it's a hard top now. Anywhere I can find pictures?
    Thanks for your help.
    Steve.
    I understand the point about pricing. Most of the 3er enthusiast sill long for a lighter weight, tossible Sports car that happens to have the utility of 4 doors (if you so choose) and fold down read seats. Unfortunatly, following the American diet its getting bigger and bigger... :sick:
    If your stepping up I would Defiantly choose the A6...
    DL
    So much for Wives AND their tales!
    Thanks for the advice Shipo.
    Mook
    PS: I did confirm with my bride that she only put in one tank of MID-level octane gas early on - and swears she only did it once due to my protests. So would that be enough to continue the problem?
    Mook
    dl....funny you should mention the A6. Drove a 3.2Q last night. Obviously, it's a bigger car and weighs more. As much as the Audi interior has been praised, I happen to like the interior of the BMW better. 330i feels faster. A6 steering is a little numb in comparison, too.
    Both are equipped about the same....I-Drive navi in the BMW (I actually liked it)....MMI navi in the A6. A6 has the quatro. BMW I'm looking at is RWD.
    I like the BMW driving dynamics better, but the A6 isn't far behind.
    Here's the kicker....I can get $9K off sticker on a new (no demo) A6 3.2Q. I'm still working on negotiatins on the 330i (last dealer offer was $2k off sticker). But, as it stands right now, I can buy the A6Q for the same price as the 330i. The 335i comes in higher, then it makes the whole balance shift to the Audi (and probably the Infiniti M).
    I actually haven't driven a current A6 3.2Q, But I've allways had a soft spot for VW/Audi products despite the reliability concerns. I snatched up a Turbo Diesel to commute to work in and love it.
    You could do a ED and save some cash on the 3er and If you joined BMWCCA get another $500 back. The market here is so tight (Dallas) I could do a ED. Drive it for a year and resell to Carmax and make 1K......If you very frequently swap cars might be worth considering.
    DL
    I suppose that one can certainly compare just about anything to anything else – if one so chooses.
    In my case, I am looking ( quite seriously ) at a 335i and a C6 Corvette. Quite different ‘creatures’, but either will fit my requirements: At this stage, my primary requirements are entertaining performance & comfort in commuting and touring. Number of seats ( beyond 2 ) is irrelevant, though a sedan seating position is what I am most used to, right now.
    In this case, though, the A6 ( and I have driven several current Audis and 3 Infiniti M45 Sports ) with 3.2 strikes me as distinctly slower ( less quick? ) than even the 330i. (Setting aside the 335i, for the moment.) If that aspect is important. Since the A6 is not available with a manual trans. – as the 330i is – I presume that you are comparing the A6 to a 330i with STEPTRONIC? The only published comparison test including a 330i w/STEP and an Audi 3.2 that I am aware of is this one in Motor Trend:
    http://www.motortrend.com/roadtests/sedan/112_0509_sport_sedan_comparison/index6- - .html
    The A4 is ( clearly ) lighter than an equivalent A6, and the 0 – 60 & quarter mile differences here I’d see as significant. With an expectation that an A6 3.2 would post something less quick yet. And the 335i is an unknown right now, but I stand by my ‘fearless prediction’ that a STEP 335i will be close to 14.0 at 100. A pretty quick sedan. If 15.1 at 93.4 is enough for you, and the ( much ) greater front weigh bias of an A6 vs a 330i is OK with you – and particularly if you live in a geographic region where AWD has real value much of the year, the A6 certainly has much to recommend it. Just not outstanding acceleration or exemplary handling balance. ( Note: In R&T’s test of the A6 3.2 they posted 15.2 at 93.8. And the M45 Sport looks like it is close in acceleration to where I expect the 335i to ‘land’. )
    Even the A6 4.2 is not a particularly quick sedan – published tests have typically shown high 14s in the quarter - and the feel, in my experience, is commensurate. Again: very nice motor, very nice car - just not particularly quick.
    My current sedan is well documented as capable of low 14s in the quarter. This level of acceleration, I consider quick enough to be entertaining. Your parameters or requirements may certainly differ.
    Just my 0.02 gallons worth . . .
    - Ray
    Admitted torque addict & acceleration junkie . . .
    2022 X3 M40i
    Ray....having just driven the 330i and the A6 3.2Q back to back, much of what you say is true. Both were automatics.
    The A6 steering felt light to me. Ride was a little better than the 330i, but the 330i has probably the most "near to perfect" ride/handling trade-off as I've ever experienced. A6 felt slower than the 300i. But, the A6 is significantly bigger and had the quatro advantage (we get some snow in the midwest, but usually not more than 3 times/year). I would compare the A6 4.2 acceleration more in line with the 330i's. All my comparison was done using my "buttometer".
    Both interiors are what I would consider best in class with both the 330i and the A6.
    If 1/4 times and 0-60 were my only consideration, I'd pick the IS350. But, that car falls down in so many other areas when compared to the BMW or the Audi, that I crossed it off my list. Try as they might, it seems the Japanese brands just can't get that "sports sedan" feel right.
    M35/45 was a considreration. As good as it is, it still can't seem to capture what the BMW and Audi have captured as far as driving dynamics.
    I can get great discounts on the '06 A6 ($9K off MSRP). I can get about $2,500 off the 330i. That puts the A6 and 330i pretty much at the same price, comparably equipped. Given that the 335i is going to be $2,100 more than the 330i. And given the fact that I doubt any substantial discounts can be had for the 335i for quite some time, I'm trying to decide between the A6 3.2 and the 330i.
    I got the 0-60 acceleration "jones" out of my system when I sold my '05 Mustang GT (at a profit, no less) a while ago.
    The C6 is in a whole other league when it comes to accleration and handling. But, it's a different car....two seater....forget about driving it during snow months (if you get that where you live). I know people how have had good luck with build and reliablity with 'vettes. I've known just as many who have had dismal luck with them. Chevy dealers aren't particularly known for their customer focus, either. You really can't get a much better dealership esperience and customer support than you get with BMW or Audi dealerships (at least in my 'burg).
    Shopping around a bit (Kerbecks), you can get a c6 for about the same price as a nicely equipped 3 series or A6, but the Audi and BMW are year round cars. I know of no one who uses their 'vette as a daily driver.
    Nice to have such choices in that price range, isn't it?
  • jared1000jared1000 Member Posts: 20
    hi all --
    I was wondering if there would be a ride difference in terms of feel between the 300 xi and the 330i sport or non-sport ... For those that own a 330xi, please describe the type of feeling you get from driving the car
    I am aware that the 330i sport is lower and a stiffer suspension but i was wondering if this translates to a big difference when compared to the xi
  • bargamonbargamon Member Posts: 302
    Apples and oranges. A6 is as all quattro's are held back with the quattro. A6 is luxuary tourer where 330 is sports sedan.
    A6 with no manual has gotten off my list as I prefer more sport and handle as I get older. Go figure. My cars keep getting smaller. S class, E-class, A6 Turbo, and now IM thinking 3 series!
    Mid life is getting me!
  • tcn2ktcn2k Member Posts: 277
    Guys,
    I am in a market for a 2006 325i with xenon, premium pck. and auto. MSRP is about 36k. What is a reasonable monthly lease for this?
    I saw on bmw website that they are having specials on 06's and msrp of 33k 3 series monthly is about $383.00 with only 10k a year in mileage.
  • circlewcirclew Member Posts: 8,666
    I have the 330xi with SP and had the opportunity to compare it to a 330i non-sp in March.
    The SP rides nice on smooth surfaces but translates uneven, bumps rather harsh. The upside is outstanding handling. I have 7,600 miles so far and having fun but I prefer the performance feel. There has been some controversy regarding the el-42 rft's regarding loudness and stiffness. I can say that this car's set-up gives quite a bit of confidence even in the rain. In the twisty's unbelievable but I am used to American steel which is no comparison in a sedan.
    When I drove the 330i non-sp for 1,000 miles, the car handled great and got about 1.5 mpg better than my car. Very confident and felt lighter but the SP difference was easy to tell the difference when I got my car back.
    Bottom line, I needed the x-drive but was happy with the SP.
    Good luck!
    There is virtually no difference between the suspension of the 330xi (regardless of whether it was equipped with the cosmetic SP or no) and the 330i (non-SP). In fact, the only difference (other than the front drive couplings) between the two is that the 330xi has a slightly higher ride height. With the above in mind, the 330i, with its lower weight and lower ride height should easily out handle your 330xi (cosmetic SP or no).
    Best Regards,
    Shipo
    You need to experience it so I beg to differ. The SP suspension "tunning" makes a difference in the handling. Also the control arms are steel in the xi. Since I drove both versions for long distances, I know better.
    Best Regards,
    OW
    Sorry dude, not happening. There is absolutely zero difference between the suspension on a 330xi and the suspension on the 330xi SP. None, zero, zip, nada.
    As for the 330i (non-SP) versus any version of the 330xi, there are very few differences in the suspension and none with the wheels and tires. Given the lower ride height and the lighter weight, the 330i (non-SP) will easily beat any 330xi around a closed course track. To claim anything else is wishful thinking.
    If you don't believe me then call BMW yourself. If you don't believe them, well...
    Best Regards,
    Shipo
  • rhmassrhmass Member Posts: 263
    Shipo is absolutely correct. The suspension between the non-sp and the sp xi is exactly the same. However I don't think you are mistaken in detecting the difference in handling between the two which is due to the AWD set-up. That may be in fact the reason you like your 330xi over the 330i. Many do feel more secure driving the AWD, everything being equal.
    The placebo effect is a wondrous thing :P
    FWIW, I'm being sorely tempted by a one owner Bright Red 2000 323Ci that my dealer recently took in trade. SP and heated seats are the only options. It has a manual tranny of course- just as God and Munich intended. It would make a great commuter sled-especially once it gets a Conforti CAI and Shark Injector ;)
    If the suspensions are exactly the same between SP and Non-SP, why do they claim a tuned setup on the SP?
    "If the suspensions are exactly the same between SP and Non-SP, why do they claim a tuned setup on the SP?"
    Who's "they"? Certainly not BMW.
    The following is copied directly from the BMW web site under the details of the 330xi Sport Package:
    Sport Package
    - 17 x 8.0 Star Spoke (Styling 158) light-alloy wheels, 225/45R-17 run-flat* all-season tires
    - 8-way power front sport seats with adjustable back bolsters, 2-way manual headrests and thigh support; driver memory for exterior mirrors and seat positions
    - 3-spoke leather-wrapped multi-function sport steering wheel with audio controls
    *Run-flat tires do not come equipped with spare tire.
    Where in that description do you see any reference to an upgraded suspension.
    FWIW, for the 330i the SP does in fact include an upgraded suspension which is confirmed by the following language:
    Sport Package
    - Star Spoke (Styling# 162) light-alloy wheels, 18 x 8.0 front, 18x 8.5 rear; 225/40R-18 front, 255/35R-18 rear run-flat* performance tires*
    - 8-way power front sport seats (includes 2-way headrests and thigh support)
    - 3-spoke leather-wrapped multi-function sport steering wheel with audio and accessory phone* controls
    - Sport suspension calibration
    *Run-flat tires do not come equipped with spare tire *Due to low-profile tire, please note: wheels, tires and suspension parts are more susceptible to road hazard and consequential damages. Performance tires not recommended for driving in snow and ice.
    *If so equipped
    See the difference?
    Best Regards,
    Shipo
    OK, I stand corrected. All I can tell you is there is a difference in the standard i vs the xi which improves the handling characteristics.
    I do know the xdrive suspension has different tuning. Perhaps that is the perception I get in my comparison.
    OW
    Cool, now that we're all on the same page we can discuss the actual differences. ;-)
    Do I believe the "xi" and the "i" (non-SP of course) handle differently? Yup, without question.
    Do I believe the "xi" will out handle the aforementioned "i"? Nope. In addition to the two items I've mentioned before (i.e. lower ride height and lower weight of the "i"), there is another factor that I've neglected. Suspension weight. Forgetting for a moment your assertion that the "xi" uses steel control arms in place of the aluminum casting (forgings?) that the "i" sports, the front suspension of the "xi" needs to deal with the extra weight of the drive shafts. Add in the extra weight of the steel control arms and you've got a front suspension that has as many as four different handicaps to overcome just to be able to handle as well as an equivalent "i" model.
    While we will most likely have to wait for a magazine to perform a back to back test of two otherwise like cars, I believe it is almost a certainty that the RWD 3-Series will easily out handle an otherwise identical AWD 3-Series on dry pavement.
    Best Regards,
    Shipo
    Thanks for your analysis. It does make complete sense regarding the physical differences. I can tell you that the i did feel lighter around the curves but the way the 2 cars moved through in the apexes,the xi felt more planted and eager for more power into the approach.
    We will wait for the experts, so I guess I am experiencing some placebo! Either way, now I know why Bimmer owners are so phanatical.
    OW
  • patpat Member Posts: 10,421
    Bluetooth and the 3-Series. Some posts have been moved there.
  • imran62781imran62781 Member Posts: 26
    I have a jet black 06' 325xi. this past weekend it was parallel parked and my rear bumper got scratched. a few scratches are deep. all body shops said the only way to really fix is to take the rear bumper off and paint the thing. cost ranged from 320-500. i have no time to do this right now (some say it will take 2 days). i was thinking of just applying touch up paint for a while. this guy at an auto body shop said he would do it. he said all blacks are pretty much the same. my question is, should i just go with the paint he orders or will it make a difference if i got touch up paint from BMW? thank you for any help.
  • corvettecorvette Member Posts: 11,285
    Black touch-up paint from the dealer should be no more than $20... If this is a temporary fix then it shouldn't matter.
    If you have it repainted, be absolutely sure they remove the bumper from the car and don't put the car in the paint booth.
  • owner6owner6 Member Posts: 89
    A senior citizen backed into my bumper at a 45 degree angle and pushed in the corner about 3 inches deep and six by six square. My BMW dealer body shop ordered a new bumper for $186.00 and $250.00 to paint the new bumper prior to installing on the car. The Price also included installing the new bumper. I scheduled an appointment and waited, it took 2 hours to remove the old bumper and install the new one. Total $436.00. FWIW i suggest you do the same. Much cleaner approach.
    Owner6
    since i dont need a new one i should be able to get as low as $250 for painting and installing then. Even Maaco wanted $300. Interesting. Where are you located?
    For the time I got the touch up done. Obviously, it stands out a bit, however, i prefer it being covered in black that stands out rather than scratches.......
    Once I find the right price and time I'll go with the cleaner approach. Thanks for those numbers by the way!!!
  • nkeennkeen Member Posts: 313
    Is the ride height on the E90 different? I know it was on the older cars -- you can see it. But I thought that ride height was equal on the the RWD v the 4WD E90 cars. Anyway, the sales brochure lists one set of dimensions for 325i, 325xi, 330i and 330xi.
    Overall I love the car (white, black leatherette, poplar, 325i manual with SP, Xenon, Sirius, heated seats). But nothing is perfect.
    Likes: handling, steering, agility, high speed performance and cruise behavior, RFT050A tires, assembly quality, styling and interior design -- tastefully teutonic instead of that video-game Japanese look that my Acura TL had, headlight performance, mileage.
    "Opportunities": would prefer shorter throw on shifter and clutch, lack of low end torque, radio controls are unnecessarily complex (one big knob for volume, one big one for continuous tuner, one for function, one each for bass and treble, and buttons for preselects, please -- that's all we need), radio presets have disappeared twice, lack of a manual single zone air conditioner (I've never met an auto climate control I like and this one is not one of the best -- temp and humidity variations -- better to outsource from GM). I'd like the car to feel a little lighter on its feet -- lose 200 to 300 lbs. Simplify, simplify, simplify: concentrate on the car, not the technological gimmickry. Bluetooth -- so what?
    But overall I love it -- best car I've ever had.
  • calif65gmcalif65gm Member Posts: 75
    The AWD are slightly higher then the RWD w/o SP. The e90s with SP are the lowest.
    However, the height difference is not as cleary visible compared to the e46s.
  • skobolaskobola Member Posts: 207
    I have about 3k miles as well, but I do not fully agree with you with your comments. Actually, I would ditto you only for the need for the car that should have been "lighter", as it does not appear that much stronger than the E46 (16% increase in HP). I do not mind the complexity, because it is not that difficult to manage the controls. I would not certainly support you in regard to the Bluetooth, because I believe that it is an essential security feature, by allowing drivers not to fiddle by hands with their cellular phones instead of just driving.
    Re Bluetooth. I think there's research that shows that the distraction from cell phones is not so much the fiddling around but more the distraction of concentrating on the call, and that the change from hand held to hands free has little affect on safety. Also that cell phone usage is about equivalent to DUI in its affect on driver safety. I've seen it myself while riding a bicycle: drivers animatedly discussing something (probably of next to no importance) with such intensity that they fail to recognize that someone is there on the road with them. This reflects a prevalent mindset that driving is a secondary, part-time activity that only requires partial concentration. I'm glad to get away from all that electronic noise when I get into the car at the end of the day -- it's private time. But then, I don't carry a cell phone.
    I agree, because I have seen a number of drivers wondering the lanes just because they are on the cellular phone, making sudden turns without checking and alike.
    However, I believe that I am pretty concentrated on driving when calling or receiving calls. In addition, I have found that in my usage of the cellular phone, I am most dangerous when dialing, because my sight ultimately goes to the small screen instead on the road, and we all know what can happen in 1 second while driving, and especially when driving fast.
    Therefore, to me, Bluetooth is one of the best security options on my Bimmer.
    Sounds like a good option for you.
    Nkeen,
    i agree. I carry a cell phone However, I dont make calls when driving. If i receive a call only from my 2 sons I will pull over to the shoulder and see if its important.
    I stopped using a cell while driving several years ago when: My intention was to avoid Harrisburg PA commuter traffic at 7:30 AM by taking the PA Turnpike over the river and get off at the 1st exit across the river to continue north on I-81 to Canada. The next thing I noticed (while I was on my cell) I was 48 miles east at a reading PA exit sign. I dont remember anything about driving there. I remember picking up my ticket and the next realization of driving and the road was 48 miles later. Note I was on a Business call.
    I was so shocked over this experience that I never use a cell while driving.
  • blueguydotcomblueguydotcom Member Posts: 6,249
    Wow, quite the multitasker. :D
  • igglesiggles Member Posts: 11
    I've had the 325i for a year now, and have gotten used to the grippy brakes. Still, I'd like it better if I could have more control at very slow speeds, like when I'm parking. In most cars, if I press the brakes at 90% of full braking, I can move very slowly. In the BMW, the car will stop suddenly. Ditto for releasing the brakes -- the car lurches forward. Makes it tough to park in tight spots. Anybody else have this problem? Can BMW adjust the brakes?
    What the blazes is that about? The braintrust at BMW just dropped the brand-identifying tagline of "The Ultimate Driving Machine" for the milquetoast slogan "A company of ideas."
    31 years they've been using the same slogan. The world and every generation knows BMWs as one thing. Guess driving is not important to BMW anymore.
    Kinda goes without saying. A spin in the e90 proves they're more into making luxurious cruisers with gizmos than performance sedans.
    Maybe an STI is in my future. Sigh.
  • ewupbroewupbro Member Posts: 2
    i got an accident (325xi, 2006)and the estimates came out to be approximately 15,000.
    can somebody tell me how serious it is after seeing pictures plz?
    is there any chance to go back to same as before?
    you can check photos here http://www.carspace.com/ewupbro
    i can give the detailed estimate if necessary
    A spin in the e90 proves they're more into making luxurious cruisers with gizmos...
    Noisy loose trim pieces and electronic gizmos that fail... Mine spent 19 days out of service last month to diagnose and repair a faulty "intelligent battery sensor" that was causing all sorts of electrical anomalies. :lemon:
    I thought that BMW was the reliable German car company... :(
    yowza....that's quite a bit of damage. I'm assuming you rear ended someone?
    Obviously, the entier front end and at least one 1/4 panel. I'm guessing, but the radiator has to be replaced. Probably some tie rods, maybe shocks on the front. Front tires (which ain't cheap because of the run flats) and wheels.
    Can't tell from the pics, but find out of there was any frame damage.
    Did the airbags go off?
    I can see it being $15K to fix.
    The good news is that you're alive and able to post here.
  • proeproe Member Posts: 157
    Or maybe he ran into a wall or something on the race track :P
    If there is no frame damage, then the car probably will go back to what it used to be.
    However, there will be a nagging feeling regarding to the accident when the car starts to behave different.
    I will try to sell the car if I could.
    Your insurance is going to go through the roof after this accident. I feel your pain.
