Black forest pearl w/ivory interior
Craig
Or, call me crazy, but how about just some old-fashioned quality interaction with the parents?
Also, any comments from 330 owners who have, in the past owned the 300. Is the updated version really much better as far as ride and handling, etc?
Yes & Yes
The wife had been riding me since I traded the LS for a supercharged big block Suburban a while ago.
Only got 500 off retail (I've NEVER paid retail for a car); took a bath on the Trooper that I traded in to get it; and I didn't get Nav and backup camera that I wanted (they weren't there yet).
But every time I drive it, it all doesn't matter. This is one SWEET ride!
But after market brands like Alpine can bring some specs. that OEM equipment lack. For instance, one LCD screen they sell has 3 times the number of pixels that most mobile LCD displays have.
Of course, it may be hard to install such units as well as they're installed at the factory.
With a small and light portable you can view the screen from any position you like.
I try not to book flights on airlines that have the screen mounted in a fixed position. The ones with swivel/swing arms are so much more convenient.
Not likely to EVER buy a "captive" DVD system, so I must use the airlines as my example.
Can you imagine two kids NOT arguing over which one gets the choice of DVD entertainemnt and/or which one gets to set directly in front of the screen for the best view?
I would take my chances with portables, one for each kid.
Don't get me wrong. I am not against it. I do have an infant kid. But there are many ways to make them clam. I will still consider this option if the dealer is willing give me a good price on it. And I will not consider an aftermarket or having install the factory unit after delivery.
And unlike My RX300, My RX330 will not have an utterly useless gps/nav.
I have the stock audio system, so the audio sound is similar, which ain't bad.
Hey Willy, still don't understand how the center-differential setup works on the RX300, do ya?? Maybe I'll explain it to you AGAIN someday.
One of the first things I will do is powder coat the aluminum pieces some matching color.
Otherwise I think the RX330 is a real beauty, fully open center diff'l (front and rear too) and all.
1. Ever tried raising a trunk or hatch with an arm-full of groceries?
2. Closing a wet/dirty gate without getting your fingers dirty.
They seem insignificant, but, hey, it all adds up!
"Two situations that I can think off right away.
1. Ever tried raising a trunk or hatch with an arm-full of groceries?"
my answer: No. That's why I use a shopping cart to carry groceries. Besides, ever try getting your keys out of your pocket or purse with an arm-full of groceries? Just as tricky.
"2. Closing a wet/dirty gate without getting your fingers dirty."
my take: Never had an issue on my RX300 because the lift gate has a nifty handle/nook inside to utilize to close the hatch. Best part, it quick to locate and I can close it as fast or slow as I want. No searching for a button anywhere.
just my .02 cents. :-)
Has tinting gotten better? Cuz in my car, the tint started to bubble up in 2 or 3 years.
The heat from the sun takes it's toll on the adhesive they use on the glass.
Maybe if cars come from the factory that way, they could embed the tinted layer inside the glass.
And re: closing. I know there is an inside handle. But do you not still have to push on the outside to slam it shut?
You see, the Japanese are masters at inventing devices to make life's mundane tasks simpler and easier. The power gate is one such device. It ain't no cure for cancer, but it will make life more enjoyable.
Hmmmm. I think a DC minivan was the first with power doors and liftgate followed by the 2003 navigator. Japanese hardly invent anything what they do is study it and make it more reliable and usually of a better quality. Lexus itself has invented nothing everything available on there cars was available elsewhere first they just try to perfect it.
"And re: closing. I know there is an inside handle. But do you not still have to push on the outside to slam it shut?"
My answer: No. the inside handle does just fine. No mess no fuss.
I have no doubt gadgets like the power lift gate will appeal to some, but to me it's potentially another item that will wear down or break or malfunction and probably after the warranty expires, too. And that, you see, does nothing to enhance my enjoyment of life.
Regards.
By the way, Bodble2, to activate the power back door on the RX330 with the remote, you have to first of all press the unlock button twice timed no closer than 500 ms apart or longer than 2 seconds apart, AND then press the power door button for 2 seconds. Not exactly as convenient as you conceived it to be. (Although part of the sequence can be reprogrammed.) And I still have my grouch about having to wait a few seconds for the back door to lower and close before I can lock the car and walk away. I will pass this "innovative" idea to Lexus -- program the computer as such: Received lock door command -- check if lift gate is open -- if yes, close and then lock car, if not, lock car. The Japanese can copy this idea and perhaps improve on it.
Porsche should have cloned the AWD RX, added RWD torque biasing, a decent european style climate control, and a 4 banger with excellent cruising fuel economy but with some "kick" using a variable speed supercharger driven from batteries charged from regenerative braking.
The prior body style very successful in its own right is a little long in the tooth and starting to look dowdy. Especially next to the new RX330.
I am deciding now between buying the new RX and the new Infiniti FX35.
The last Lexus that I owned was a SC300 and the quality was not that great. There were many repairs that I would not have expected based on the Lexus quality reputation.
Any comments on the FX verses the RX???
I've test driven both and we're learning toward a 330 late this year - but we're also biased because we have a RX300 now and it's been great.
RX is more luxurious and the FX is better handling; FX35 also has more power than the RX (280 vs. 230 hp).
For some folks, handling and power are important; for others that carry dogs in the back, you can't use more power or handling or a high dollar stereo...because, simply, The Dogs Don't Like It...and they don't particularly want to discuss the matter!
RX has more interior storage room; FX's rear is more sloped; FX seems wider as well. Fit & finish on RX330 better than RX300 and better IMO than the FX. FX interior materials feel and look less expensive than RX.
Exterior styling is a personal choice for each buyer. Infiniti has gone after a niche market with the more cutting-edge FX's 20" rims, etc. while RX330 is more a revision of the original '99 RX300.
I have a Lexus dealer and an Infiniti dealer down the street where I live, facing each other across the main boulevard. I go by there twice a day and I see 20-25 FXs sitting there and if the Lexus dealer has one RX330 on the lot, it's gone within a day or two.
Which doesn't mean one vehicle is inherently "better" than another; after all, Lexus has a pretty loyal base of customers that have purchased what, 350-400k RX300s over the past 5 years? So they have a built-in advantage in moving more units in this segment.
Unfortunately both manufacturers make you buy expensive packages of options if you want Nav (right, Willard?) but Infinit's pack is ridiculous, up in the $9-10k arena. And with that pack you have to take the harder riding Sports suspension. Cheaper to make cars with less variables, I know, but now manufacturers are at the stage of losing potential sales because of the inflexibility. Too bad.
The final factor is reliability and service - I've had two Infiniti vehicles and three Lexii - and, while the Infinity dealer service was good, it didn't reach the Lexus level. Of course your location and dealer situation may dictate otherwise.
Good luck - both are excellent vehicles - just different target audiences. Lexus was smart to revise the RX and not replace it; Infiniti was smart to stay out of the RX's way by blazing a different trail.
And I have to admit that the large over-sized wheels always remind me of the "back to the future" car fitted with those wagon wheels.
It's a frustrating time for me, I really like the fact that the FX is primarily RWD torque biased but just simply cannot stand the appearance.
So for the moment I'm settled on the new RX, but sorta wanting to see what the new X3 will be like.
BTW, when you said you have to press the unlock button twice first, that would be to unlock the doors right, not the rear gate. You also said you can't press the buttons more than 2 seconds apart. What happens if you do? The doors don't unlock, or just the driver door unlocks?
I appreciate any information out there.
Hard to say if the package is good value or not. Like all other extras and luxaries we want in life, they are never of value in the economic sense.
Mind you though, a fully loaded Toyota Highlander actually costs more than the base model RX330.
The rear gate is treated the same as the other passenger doors. It cannot be unlocked by itself. It is unlocked and locked along with all the other passenger doors. That's why you have to push the remote twice to unlock before you can open the rear gate (regardless of whether you use the power function or not). When I allowed too long an interval between the two clicks on the remote, only the driver door was opened. I am going to ask the dealer to reprogram it so that all doors will open with one click.
Has any one been able to play DVD on the Nav screen while driving, if yes can you tell us the secret.
