Toyota Cold Engine Ping
I've been working through Toyota Customer Assistance to figure out this ticking (possibly pinging?) noise coming from the engine of my '01 Celica when it is COLD. The dealer insists it isn't the valves and it has to do with the fuel. He has my using the next higher octane (89) for a few tanks to see if that helps the problem. After one tank, no change. But, of everything I've read, engine ping happens when an engine is hot, not when it's cold. Is that true? When the engine warms up, it sounds fine. Any suggestions or insights are appreciated.
Pinging is hardly a "mystery noise". It's about as subtle as an elephant with a church bell around its neck---I am surprised that this sound wasn't either identified or dismissed right off by the dealer.
Noisy injectors are easily diagnosed by a stethoscope; pinging by a test ride in which you load the engine (up a hill in a higher gear); and valve noise is rather obvious.
So tell somebody at the dealership to put the doughnut down and come listen to your car.
Are noisy valves or injectors when the car is cold anything to worry about. I only have 35k miles and was hoping to hold onto this car for at least 150k miles. A valve job costs about $800 since a system of shims is used
Also, I noticed the sound was much worse about a month ago when morning temps here in Orlando were in the 30's. Now that it's a good 65 degrees in the morning, it's not so bad. Would a cold temperature change like that have any affect on the fuel grade being the cause? I'm worried that my engine is slowly being torn up when its cold.
Happens on very cold morning starts (if my car was not in the garage) and lasts for about five minutes. Best experienced under moderate acceleration - if you feather the gas pedal (i.e. very little load) there is no noise, or if you rev the engine up (above 4K RPM, say) - again no noise. Happens only under moderate acceleration, and is gone after the engine warms up.
I have just over 30K miles on the car.
Any ideas?
I am wondering if it could be related to the timing chain somehow. Maybe the chain tensioner? Does the Celica use a timing chain? I know my Maxima does. Just a thought.
I had a very interesting observation over the last couple of days. This past Thurs. I had an oil change (same Castrol oil from the same dealer) and that seemed to help quiet the engine down. Not sure if this is relevent, but it seemed to make a bit of a difference.
Nippon - I checked my maintenance manual and there is nothing about valve clearance adjustments at any of the service intervals. According to the service director, valve clearance adjustments on these cars are almost unheard of. I'm not sure if the Maxima calls out for the periodic adjustment or not.
It could very well be valve noise. If the clearance is abnormally wide, it will not go away when the engine warms up. Also, some defect with the camshaft, camshaft oiling, etc., might cause this.
Timing chains can make all kinds of weird noises, that's true.
Anyway, does it give you any insight that I got a significant noise reduction with my oil change. I was running Quaker State (not my choice, but what another dealer put in) when this noise showed up. Now that another dealer is putting Castrol in, it doesn't sound as bad.
Could it possibly be some sludge not letting the cold oil circulate properly until it warms up? I've heard QS oil can cause oil sludge relatively faster than other oils. I change oil every 3k to 4k miles religiously.
I experience this problem very rarely lately, because, firstly, it is no longer so cold out; and secondly, I don't keep my car out overnight most of the time.
Another interesting observation - I was on a long trip in very cold weather and after driving non-stop for 300+ miles I stopped for gas and got the same sawing machine noise when pulling out of the gas station!
It seems like this is caused by some component that is far away from the combustion chambers, and got cooled down due to the long highway driving. But once you drive though traffic the engine heat gets distributed throughout the engine compartment and the noise is gone.
I suppose if you changed to an oil that flowed better when cold, this might decrease noise. I recall one Saab I had was quieter at start up when I swithed to synthetic for instance. That was timing chain noise, easily heard because on that car (older Saab 900) the front of the engine faced the firewall.
Unfortunately, when I put my ear up to the valve cover, the injectors are so loud, they drown everything else out. I actually have to be slightly away from the car (or in the cabin) to hear it. Now I'm back to thinking it needs a valve adjustment.
Here's the million dollar question: How do I get the Service Director to acknowledge the ticking when he insists it can't be the valves or anything mechanical? He swears these cars never need valve adjustments. Also, if it is a ticking valve and the dealer won't fix it under warranty (I'm not paying the $800 they want for the adjustment), is this damaging the engine in any way?
You may have to just give up and yet still insist that he mark on a repair order that you've complained about a ticking sound that matches engine rpm. That way you have something on record after the warranty expires.
The dealer is certainly not going to tear down your engine looking for an unknown source of the noise.
I would think he'd readily diagnose the noise as lifters since this would be profitable for his shop. Maybe he doesn't want to risk being wrong, I don't know.
At first I thought I had abruptly developed some new rattle in my dash, but it only did it in a small part of the rpm band and has since disappeared. Strangest thing.
I'm becoming afraid to walk in front of my car for fear it will start itself up and try to run me down, lol.
However, when I was asking the dealer about routine maintenance for this car, they told me they recommended valve clearance adjustment at specified intervals, 60K.
http://forums.maxima.org/showthread.php?s=&threadid=194959
Sgrd0q, thanks for the link. I'll try some good injector cleaner and keep my fingers crossed.
I figured the fact that it would require periodic maintenance meant it did NOT have hydraulic lifters. However, my old celica had mechanical valves too, with the 60K "recommended" adjustment interval, and I did them once at 120K. You can usually tell if they need adjustment by the sound.
In fact, valves will burn when the valve clearance is too tight, so you wouldn't hear that.
A light tapping is probably harmless. Quiet valves, if they are mechanical, could mean trouble. Odd but true.
Beware the whisper quiet engine if you have mechanical lifters.
The link that I posted earlier in this thread talks about the guy using a Slick-50 Fuel System Cleaner. Apparently he had a similar noise (under similar conditions) that we are experiencing, and in his case the noise disappeared. He seems to think that some component of the fuel system might have been dirty.
I personally never trusted those "additives". But now I am curious...
My impression is that noisy injectors are not "curable"---injectors have a service life and then you replace them if they start making too much of a racket. It's natural wear not really a defect per se.
But I won't disagree that some injectors are noisier than others, from make to make.
local dealer for the noise. They checked and they told me most all the engine do make valve chatter when oil is not present top of the engine valve.
One of my friend who has Toyota told me he had same problem but after using Rislone treatment in oil the noise stoped. I also tried and about 500 miles the noise down about 50 % and now I have 12500 miles the noise is completely gone. Also I feel I have better compression and more horse power and engine runs more smooth.
Thanks for all the good recommendations about the
Toyota engine, It is a good discussion board.
jsleesi
How long did your valve chatter last? With us the noise persists for up to ten minutes. (Which makes me think that we have a different problem.)
My chatter lasted about 2 to 3 minutes, as I drive it goes away, as I have mention to you,
I don't have any more.
I feel the Rislone cleaned inside oil small oil passage to top of the valve.
If you purchase the Rislone, all the instruction
is on battle. I even called the Rislone tech support, they giave me good solid answers.
Good luck to you,
jsleesi
Of course, if your camshaft is being hammered, this is something serious, but you'd hear a very sharp and constant noise in that case, a lot more than a soft light tapping.
I agree with Mr Shiftright - as long as the noise disappears (it does in my case) once the engine has warmed up - this shouldn't really be much of a concern. Still puzzling though. I'll try an injector cleaner fuel additive next.
I can't believe these new plugs cost $17 each!!! This new technology is such an improvement, lol. I'll post again after a few days with an update on whether or not this helped.
Also, totally off topic, I called Goodyear tire today to see how their prices compared to Tirerack.com, and the manager agreed to give me Tire Rack's price plus shipping. Not bad, but just goes to show that tire shops can be negotiated with on price if your educated on their competitors.
