Navigation GPS Systems
Has anyone heard of a navigation system or GPS that works in a 2001 Civic EX?
If it had a cassette, I would just get a cassette adapter to run the audio from the laptop, but that is not an option. I also heard that there are FM transmitters than could be used, but they work poorly.
Someone said there is some way to tap into the unused factory CD changer input so I could connect the laptop or even a MP3 player and get full fidelity.
Anyone have an idea how this could be done?
It would be really cool to use the laptop to play MP3s and also simultaneously hear the navigation commands if that software was running at the same time.
http://www.soundgate.com/products/aux-in/ford.htm# for the aux in.
http://www.soundgate.com/products/cd/ford.htm for the cd changer
Find a dealer near on on their website and have them install the module. Let me know if I can be of further help. Good luck
I'd rather leave the car's speakers for music, or leave them silent. It's creapy hearing "Turn here" in stereo!!!
Good list of GPS vendors <http://gpsinformation.net/banners.htm>.
The Good - nice colour maps
- nice to be able to load detailed maps on your planned route
- the beanbag mount works very well and makes it easy to adjust the unit
The Bad - still has bugs in the software (hangs when you get near the loaded files edge and doesn't use the base map when you get to the detailed map area, even though the detailed map didn't have the major highways - BC Canada)
- compared to my GPS III+ very poor receiver in this unit - lost sats. in locations the III+ works fine
- is rather large on the dash
- the III+ allows changing the things displayed on the side of the screen - couldn't see anyware how to do this on the Streetpilot III (I like to see altitude, trip distance, avg. speed, current speed, and time/date)
Overall, I give it a C-. For the money, I think I'd recommend checking out the GPS V. It is practial for handheld use as well and has most of the features of the Streetpilot III.
http://www.navmanusa.com/land/icn630/index.html
Maybe it will work better than Streetpilot III.
Has anyone tried this one?
Both being Garmin products, I can use the same media for this and my Vista when on foot. (It gets to be a real pain to have to have totally different media for all your different GPS hardware.) I have the internal built-in base maps for both, plus the detailed CityNavigator that came with the SPIII, and a Garmin topo disc for use with my eTrex when hiking. The little eTrex only has 24 MB of memory, so you have to reprogram it occasionally, but programming is actually kind of fun, so overall this works well for me.
One thing I saw some search-and-rescue guys do was to install a dedicated 8"-ish LCD screen on top of the dash that they could plug the GPS unit into. Swivels and tilts on a little pedestal. This gives the driver and navigator a much easier-on-the-eyes monitor than that puny little 3" deal on the unit itself. You and I may have a little difficulty explaining that monitor being up front near the driver to a cop ("Sir, were you watching TV while driving down the road? Was that why you were speeding and weaving like that?"), but it works well for those who need it in their line of work. A liability insurance-wise, but it sure is a lot easier to see while driving down the road than a handheld or even an in-dash unit.
The Sky's the Limit (Fast Company)
Does that constitute "New for Fall"
I'm having trouble with mine. Its incredibly annoying to plan routes with. I sit here at my desk and try to navigate the map and it keeps beeping every 10 seconds or so and shifts the view on the map to another part of the state (different every time). Really wish I hadn't bought this thing. very frustrating.
Mark
The only beef I have with the current version of the mapping software is that whenever i veer off route the very annoying voice keeps saying "off route, off route..." and does not recalculate. I have to restart the software to get rid of the bug. Another issue with Delorme is that you HAVE to use Delorme software. I have tried using MS trips and tips, but Delorme receiver has a chip that disables NEMA communications with programs other than Delorme.
I am will be checking out Rand McNally and eTrecks as the upgrade.
you'll have to let me know if any other software works. That would be great.
I would suggest you call Delorme's tech support and see what they come up with. You may be required to un-install it, restart, install, restart and see if it helped.
http://www.garmin.com/products/sp2610_2650/index.jsp
Anyone have any experience with these yet?
Aaron
My simple research seems to say I should get either the Magellan 500, or Garmin Streetpilot III or GPS V?
Any advice or recommendations greatly appreciated. Are there other features that are "must haves"?
I am so spoiled by the Navigation System that I have to get it fixed but it seems like everything is working except the light. Has anyone encountered this problem and if so is there a less expensive fix?
I would sure appreciate any suggestions.
Dotti,
Massachusetts
dotti@santomarcore.com
For roughly the same $$ you can get a brand new aftermarket system. Maybe that would be wiser?
Mark
If you install an aftermarket navigation system in an RL, future buyers will complain.
Better off dumping the car and getting a new one with warranty. The new TL has a great new navigation system with more features than that RL. You could also look at the Acura MDX and Lexus RX330. Those are great for real estate agents to tote clients around in.
as far as one that you can take with you, read the rest of the messages on this board.
I understand these are Magellan 750-based systems which I think is the next model higher to the 500. Costco sells the Magellan for $899 and the Garmin for $699 so unless there are people who can share their experiences with both of them, I guess one way to go is try both of them using Costco's liberal return policy and return one.
One thing manufacturers should add to future built-in nav systems is a heads up display that can project, at the very least, information about the the next turn on to the windshield.
I can have an arrow pointing which way to turn, the name of the street and the distance ahead (if not a complete mirror of all the info on the main screen).
Both give reviews; gpsinformation gives links to several vendors.
Mark
As far as navigation systems specifically, I think that virtually every maker has at least one model that has navigation as an option.
Better to ask, I think, which is the better navigation system[s]. This seems to be the consensus from what I and JP Powers have picked up: Alpine, Xanavi and Denso are evidently the best brands. Alpine is used by Acura and probably Honda, and maybe some others. Xanavi, so far as I know, is used only in Nissan and Infinity. Denso is used in Lexus and probably Toyota, and maybe others.
Some of the features that you might want to look for, they say, are: voice (will it give verbal directions, and can you give it voice commands?), the so-called bird's eye view together with (but only one at a time) the regular flat map view, touch-screen rather than joystick, and number of points of interest included in the system (which seem to range up to about 10 million for the best systems).
Another thing is whether Navitech, who makes the actual maps for all systems I've heard, has finally mapped the smaller cities and towns in the U.S., not to mention Canada.
There are updated DVDs that you can buy, about once a year I think, which reflect the additional mapping done if you're not satisfied with the DVD that comes with the car.
Hope this helps.
-which cars offers which NAV systems:
http://www.autonav2000.com/Compare/OEM-sys-vendorlist.pdf
-what features come with which NAV systems:
http://www.autonav2000.com/Compare/Compare2.htm
Good luck!
Didn't realize the Infiniti I35 had a CD-based system.
I've seen and tested the 2004 Accord NAV. Its on par with the 2004 MDX NAV and should be considering its Honda top of the line sedan. Its got the same size screen, voice activation, 12 million POI, etc. Its improved from the 2003 Accord NAV. As to why Honda didn't put the same system on the their top of the line SUV, beats me except they make more money by including an older Alpine gps and old mapping/POI database.
Acura TL
Buick Rendezvous
Cadillac CTS
Chrysler 300M
Chrysler Town & Country
Ford Expedition
Honda Accord
Honda Odyssey
Honda Pilot
Infiniti (All)
Lexus (All)
Lincoln LS
Lincoln Navigator
Mazda 3
Mercedes Benz (All exc SLK-Class)
Mini Cooper
Nissan 350Z
Nissan Maxima
Nissan Murano
Nissan Pathfinder Armada
Nissan Quest
Pontiac Vibe
Porsche (All)
Toyota 4Runner
Toyota Avalon
Toyota Camry
Toyota Highlander
Toyota Land Cruiser
Toyota Matrix
Toyota Prius
Toyota Sienna
Toyota Solara
Volkswagen Phaeton
Volkswager Touareg
Volvo S60
Volvo S80
Volvo V70/XC70
Volvo XC90
-end-
Presently, auto makers are pushing these things because they are making a ridiculous profit on them. Analyze just what your $2000 is really buying. First, there is a $50 microprocessor, a $30 DVD or CD/rom, a small $85 LCD screen,, and a $150 GPS. For a real cost of 3 to 4 hundred dollars, they can make 400% profit...a wildly good deal for them!
If I am going on a trip, I can map out my route in advance with my $10 Rand and McNalley computer program, and toss my $5 R and M atlas in the car if I want to take a side trip. If I am going someplace in a strange city, I can map that out in advance using Yahoo or Mapquest. I can see a few specific uses for these systems..the real estate saleslady, for example, but for the vast majority of people, they are just another toy...one that may someday put them in a serious accident.
Q: Can you force your NAV system to follow you without a)prompting, b) guiding, or c) establishing any destinations? Further explanation: this would just be showing the map, just showing where the car is located on the map and allowing you to glance at it to see current location and direction.
Acura TL
Cadillac CTS
Honda Accord
Honda Odyssey
Infiniti G35
Lexus ES330
Toyota Avalon
Toyota Camry
Once I tried one I was hooked and came close to buying an Accord just for this feature, but then luckily I stumbled upon these messages that talked about less expensive Navi options, so now that's the direction I'm heading in.
I think that anyone who ever grew up watching Batman, Knight Rider or James Bond movies would go ga-ga over Navi. Talk about the ultimate grown up toy! Like any toy, Navi is fun and cool for the kid in us, but practical for the grown-up who hates asking for directions or thumbing through a road map book. I think it will be that way for at least a few more years until the next gizmo comes a long (anti-gravity cars I hope).
Now I have a question for the board: does anyone know if another company makes something like Honda's voice activation Navi? The idea of just speaking "find me a Chinese restaurant" and having the system come up with the info is just too cool for words.
Mark
BTW-the Garmin 2610 prevents you from doing any route changes while the car is in motion. The most you can do is change from map to text.
Mark
