Ford Fusion/Mercury Milan
15657596162111
  • mschmalmschmal Member Posts: 1,757
    The longer break in period you experienced on your Ford vs the GM is due to the HIGHER tolerances used by Ford in its manufacturering.
    When the Ford engine is new there is more friction in the drivetrain due to such tight tolerances.
    Mark.
  • akirbyakirby Member Posts: 8,062
    It's part of the message center. I'm pretty sure it's standard on the SEL, not sure about the other trims.
    I think you meant that Ford uses LOWER tolerances and thus builds a tighter engine. Tolerance is the amount of deviation allowed so lower is tighter.
  • dcc06dcc06 Member Posts: 3
    Recently purchased a Fusion SE 2.3 5-speed. Only complaint so far concerns headlights. They are simply too dim. Can the bulbs be upgraded to a higher wattage/candlepower without harming lenses or electrical system? Any suggestions would be greatly appreciated.
    SE standard info package does not include compass.
  • evandroevandro Member Posts: 1,108
    Actually, remember when engines needed a careful break in? That's because the machinery then had looser tolerances than nowadays. Therefore, an engine that takes longer to break in is built with looser tolerances than one that breaks in sooner.
    I don't think it's the brightness - I think it's the aim. I plan to adjust mine soon - I think they're simply aimed too low from the factory.
    Breaking in an engine to avoid premature wear or damage is not what we're talking about here. Almost no modern engines today need a break-in period. We're talking about additional friction in the first 5000 miles or so that limits power and reduces mileage.
    Lower tolerances equate to tighter engines. Higher tolerances equate to looser engines.
    If the tolerances are tighter, the pieces fit together per the blue-print. Therefore, the engine would work sooner according to design.
    Tighter tolerances has nothing to do with tighter engines. Either the parts are made with precision or not.
  • rayainswrayainsw Member Posts: 3,192
    Another significant variable in ride softness \ harshness (and typically steering feel \ precision, etc.) is tuning of the various suspension bushings.
    With otherwise identical parts & geometry (control arms, dampers – caster, camber, etc.) the bushing compliance, in several respects, can be changed and will result in different response to short, sharp bumps.
    - Ray
    Hardly a suspension engineer, but . .
    2022 X3 M40i
  • fordfaninbowiefordfaninbowie Member Posts: 34
    6,800 miles, no problems or complaints. I have the SEL V-6 Fusion. I've checked computer MPG to hand calculations and the computer is within .1 MPG, very accurate. Results are all with one or two passengers:
    All highway driving, flat, at 55 MPH = 33 MPG
    All highway driving, flat, at 75 MPH = 29 MPG
    All city driving, stop and go, never higher than 35 MPH = 17 MPG
    Combined, highway, flat, 55 MPH for 5 miles, 75 MPH for 5 miles, 12 miles city, stop and go = 21 MPG
    I'm very happy with highway MPG, and very dissapointed with city MPG, but I still wouldn't trade it for any other car. It has a lot of room and comfort at a great price. DC traffic is tough on the MPG, as is idling, and very fast acceleration.
    Ok, one last try:
    When engines are assembled loosely (with higher tolerances) there is not as much friction in the first few thousand miles so you get better power and mileage right away. You also risk more compression loss and oil consumption.
    When engines are assembled with low tolerances then the parts fit together tighter which leads to higher friction for the first few thousand miles until the tight fitting parts wear a little and loosen up. The up side is higher compression and little or no oil consumption, especially on high mileage engines.
    It has nothing to do with working per the 'blueprint'.
  • poodog13poodog13 Member Posts: 320
    OK guys, time for a basic stats class. Tolerance means allowable deviation from target spec. Deviation goes in either direction, i.e. +/- certain amount from spec. A larger tolerance will result in some batches that are slightly too large and others that are slightly too small, dealing in very small increments of size. The biggest impact here is excess wear and tear, affecting reliability. A smaller tolerance will simply reduce the level of variation around the mean, and provided that the mean approximates the target spec, a well put together engine.
    The idea of "loose" or "tight" is inaccurate, a higher tolerance could result in an engine that is either too loose or too tight (or too tight in some places and too loose in others). A low tolerance gives the "just right" desired result.
    I agree tolerance isn't the right word. Perhaps clearance is better. But some engines are definitely "tighter" than others and require longer to reach maximum power and fuel mileage and the 3.0L Duratec is one of those.
  • justgreat47justgreat47 Member Posts: 100
    oh, that's not good to hear about the dimness. this is the one feature (xenons) that i wish the fusion had. what vehicle are you coming out of? also, do you have the mnaual 5 speed and if so, how do you find the clutch engagement and clutch pedal postion relative to the bottom of the steering wheel?
    can't offer any advice on the wires and the upgrade to more powerful bulbs, other than to suggest that if it bothers you that much there are kits available to upgrade the wiring to allow brighter bulbs. more work than simply plugging in a new bulb but atleast it's an option.
  • Kirstie_HKirstie_H Administrator Posts: 11,247
    A reporter seeks to interview owners of the Ford Fusion, Chrysler 300C and Chevy HHR. Please respond to jfallon@edmunds.com before Wednesday, February 8, 2006 with your daytime contact info and a few words about the model you chose.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • driverdmdriverdm Member Posts: 505
    Greetings all. As you all know I have been an avid Ford Fusion fan. No longer is it on my buying list. I am disappointed with Ford as a car company. They say they are going to pull out all the stops and then give us peanuts. The news lately has really hampered my view of my favorite American car company. First they introduce the Expedition that is not ready to go toe to toe with the new Yukon design wise, then they cancel the Ford GT (An American icon) and the Sport Trac Adrenaline (something to get excited about). Then the rumors of the imploded SVT team swirl (bye bye Fusion SVT_ and then came the straw that broke the camel's back. They announced the new MKZ, previously known as Lincoln Zephyr and stated the the Fusion would not get the 3.5 this year. To throw further salt in my wounds, the new MKZ does not have manu-shift. How do you have 250 plus horses and not manu-shift I do not know. Every other manufacturer, including the big bull Toyota is offering it in everything. Look at the new Camry SE for an example. Ford does not offer it in one of their vehicles. And why not pull out the stops and give the Fusion the 3.5? It is built in the same plant as the Zephyr/MKZ. Wait till next year when the V6 comparison is done and you have the new Camry turning out 269hp, the new Accord that has at least 250hp since the current Accord has that, the Sonata with 236hp, the new Sebring with 255hp. Bold innovation? I think bold ignorance fits better. To "win back the American road way" you cannot have a driver's car that is the slowest in it's segment. That is common sense. You have to offer everything the competition does and a little more. Maybe just a centimeter more, but something more non the less. The Fusion would have been equal with the 3.5 and manu-shift with its styling giving it a foot on the competition. For all the Ford people that monitor the boards, tell Bill Ford when he gets serious please give me a call.
    it's amazing what a few stop lights can do to fuel economy; it doesn't take much to wreck the numbers. the hiway numbers are decent enough.
    it's easy to get caught up in "the numbers game" absolute numbers are NOT an indication of how an engine will perform in every day driving...it's simply bragging rights. without seeing power graphs for torque and h/p, the numbers are almost useless. WHERE does it make it's power? and for how long through the rpm range? THESE are the important, usable facts regarding any powerplant...that and what your driving habits entail.
    i will agree totally with the fact that ford "missed the boat" with certain features on the fusion, the 3.5 is not one of them...bigger and bigger engines (if only a half liter) are not going in the right direction. the lack of a more sophisticated shifting arrangement is something that ford missed, but in their defense, go to the avalon board and check out how many people have been having drivability problems with their 05/06 avalons due to the drive by wire AND the "intelligent" software on their transmissions. this is an absolutely a bad combination...something that for the next few years should be avoided by the consumer. it will take that long for the engineers and designers to sort the dbw problems on the automatic equipped with "intelligent" software on the trannys.
    so; sometimes less is better.
    oh, one other feature ford missed: xenons...they definitely should be an option on the fusion.
    Nobody is getting the 3.5L engine besides the Edge, MKX and MKZ because they simply can't build more than that this fall. They have to ramp up production of the engines and transmissions. Once could argue the 500 needs it more than the Fusion.
    The real problem is the 3.5L engine is at least 2 years late due to development problems.
    Ford still has to get the mainstream models out the door and working before they can afford to go after the smaller enthusiast models.
    The other reason for limiting options is simply to reduce complexity and eliminate launch problems which can simply KILL a vehicle (remember all the Focus recalls?) with bad publicity. Do you remember any major first year problems with the Mustang or F150 or 500 or (so far) Fusion/Milan/Zephyr? I don't and that's a good thing. So while it may be a little frustrating overall I think it's the right strategy.
  • jaxs1jaxs1 Member Posts: 2,697
    The bigger, heavier 500 is desperate for the bigger engine. The Fusion doesn't need it when the 3.0 does 0-60 in 7 seconds. A bigger engine would be nice for some kind of future Sport or SVT model, but an SE or SEL is just fine with the current power.
    The Fusion could use an AUX input and an automatic transmission with more than just D and L selections.
    The fusion should get the Aux input for 2007 along with the Edge since it's the same radio.
    The shifter will be fixed but not sure if it will be 2007 or later. The D and L were holdovers from the original plan to use the CVT tranny in both the Fusion and 500 but it was subsequently replaced by the 6 speed Aisin tranny. They chose not to redesign the shifter.
    To be honest, it was one of the few things I was concerned about with my Fusion but so far it hasn't been an issue at all.
    Agreed! Having D and L has not been an issue for me and I've driven it 7,000 miles. My V-6 has more than adequate power and acceleration with 4 people pulling onto a highway.
    My only 'want' at this point would be to have rear footwell lighting. With the sunroof, the front interior lights don't make it to the rear footwell and also, rear seat passengers can't read in the dark.
  • arc43arc43 Member Posts: 1
    Navigation may not be offered as a factory installed option, however a Ford in dash nav system can be installed. The same unit that is offered on many 06 Fords will work without any modifications. Be prepared to shell out about $2,000. I have installed it many F series, a few Mustangs,Explorers, 500s, Freestyles, and Fusions.
    thanks for the response! re your questions:
    lexus es 300. fusion seats are a vast improvement over lexus.
    5-speed. clutch pick-up took some getting used to -- have adjusted power seat "just so" and clutch engagement is fairly smooth. position not a problem with power seat and tilt/telescope wheel.
    will see what the aftermarket comes up with and look for best price/value alternative.
    If you want to upgrade the lighting I'd suggest Sylvania Silverstars - much brighter and whiter than stock, but I don't know if they're available yet to fit the Fusion/Milan.
    Please don't put in those awful blue fake-HID bulbs. They don't look cool and they definitely don't give you more useful light. If you want to do HIDs you'll need the entire kit including reflectors. Retrofitting HID bulbs in the current reflector may blind oncoming drivers or result in worse lighting where you need it.
  • theman123theman123 Member Posts: 170
    I was bored last night and was surfing around the net and I stumbled onto this link. It's something called Podrods from the Jacksonville newspaper about the Milan.
    1.it's really short not even 5 minutes
    2.You need Quicktime to listen to it.
    Your thoughts please :)
    Mercury Milan
  • jc14jc14 Member Posts: 1
    Perhaps this Q belongs in another thread, if so I apologize (I'm new!).
    Found what I consider to be a pretty good deal on a loaded Milan V6 Premier for my wife- auto,leather,ABS, premium audio, side air curtains. MSRP= $24,605, Ford A-plan Price $21,148 (after $1000 in rebates). 36 month/12K lease, .00073 money factor, 50% residual, $1094 total drive off (1st mo, acquisition fee, DMV)= $292/month including taxes. Not too bad for a ~$25K car.
    Problem is, her existing Taurus doesn't come off lease until 3/26. From what I've seen, Milan sales have been better than expected, so I'm worried that if I wait until mid-March to consummate this deal, the rebate and/or attractive money factor may go away. I think she's pretty set on getting the new Milan. Should I:
    (1) just bite the bullet, get the Milan now and essentially make an "extra" car payment for March;
    (2) roll the dice, wait until mid-March and hope the incentives/financing are the same (or better);
    (3) try to negotiate something with the dealer?
    Part of me says lock in a great deal now, but another part says the domestics are really struggling now, and there's no way they'll reduce/pull the incentives/lease support. And if any of you have any experience and/or advice re: option (3), I'd love to hear it. Thanks.
    Wow, "better fit and finish than the Japanese competition"!!! Kudos to Ford.
    I just hope it's not too little, too late. After ignoring the sedan segment for years (no redesigned Focus, no Contour replacement, late replacement for the Taurus, way past due demise of the Crown Vic) in favor of trucks, Ford is struggling to remain afloat financially.
    I don't think it will be any cheaper next month and it is possible they could drop the incentives - no way to really know. There is a good chance they would let you out of your existing lease a month early - check with the dealer. If not then I'd probably wait and take a chance. If they change the incentives then it probably won't drop more then $500 so the difference in that and your extra payment won't be that much.
  • badgerfanbadgerfan Member Posts: 1,565
    Well, I don't lease as I keep cars ten years and 90K-100K miles, so leasing makes no sense for me as I don't like paying for that first three years of depreciation and not keeping a car for a good long period. I cannot comment on whether that is a good lease deal
    What is most likely is that there will be likely be at least the same or better deal next month as well as the month after and the month after. The competition from all the auto manufacturer's seems to be so cutthroat that the consumer is nearly in the driver's seat all the time, even with a fairly new model such as this. Ford is likely still ramping up production from earlier in the model year when the plant was starting production, so Milan/Fusion supplies might be looser next month than now.
    In any case, I wouldn't lose sleep over it. Buy or lease when you are ready.
    The current program on the Milan, includeing lease runs until 4/03/06.
    The program was not changed much since last summer when it was announced but money rates could always change.
    Mark.
    I think you make great points about more is not always better. However, Toyota has recognized that its 5A/V6 is NOT as well executed as it should be (though the V6 itself is ROCKIN). According to the 07 Camry's press release, the new 6A offers 50% quicker downshifts than the transmission it replaces. If thats true, I dont think driveability will be an issue. That tranny is expected to make its way to the Avalon as well, so its not going to take a few years.
    ~alpha
    Wait till next year when the V6 comparison is done and you have the new Camry turning out 269hp, the new Accord that has at least 250hp since the current Accord has that, the Sonata with 236hp, the new Sebring with 255hp...To "win back the American road way" you cannot have a driver's car that is the slowest in it's segment. That is common sense.
    There is a lot more to being a "driver's car" than peak HP numbers. There are not many who would include Camry and Sonata when talking about "driver's cars", no matter what the HP number is.
    Front wheel drive and over-powered cars is not a good combination anyway.
    It definitely won't hurt and as I said before, you can't have a "driver's" car be the slowest in its segment.
    Indeed front wheel drive and over powered cars is not a good mix. But these cars aren't over powered. From every review of the 240hp Accord, they love the car. The new Camry is getting similar reviews. The Sonata as well. Look at your Acuras, front wheel drive with 300hp, no complaints. The TL is one of the highest selling luxury cars in its segment.
    Ford did a good thing with the MKZ in one respect to me. They kept the car fresh as new for another year. If Ford updates its cars every model year or model year and a half to address the competition and keep the car "new" they'd be fabulous. You know, a manu shift in 07 model year, a 250 hp in 08, a Limited Edition and a Special Edition with special colors, grill, dash trim, and seat inserts in 08.5, a facelift in 09, SVT for 10, and then the new model for 2011 model year, the car would have been fresh and new every single year at a minimal cost increase. Special editions aren't expensive as long as you don't change the engine. Mazda seems to do one every half 6 months.
    Now that is a Way forward.
  • jimargejimarge Member Posts: 9
    I was told by a Ford enthusiast, that if I disengage my Traction Control System, I would notice an increase in pick up and in miles per gallon. He claims when the roads are dry, I just need press the TCS button on my dash to disengage it. When it rains or snows is when I would actually need it back on again. Is this a valid thought?
  • johnclineiijohnclineii Member Posts: 2,287
    No, it is not. Traction control has no effect whatsoever on power or mileage unless and until it is engaged. If you have it turned off, it will not be available when you need it...and you won't always know when that is unless it is too late.
    What did this have to do with the Fusion/Milan? You'd get more precise, better answers in more specific forums, I would think...
    I have a 2006 Fusion SEL V6 with traction control on it. Also, the enthusiast was telling me this at the auto show as I was looking at a very similar model to mine. I assumed that this would be a valid question for the Fusin/Milan section. Gee, sorry I offended you by asking a question about a Fusion on a Fusion forum.
    I just wondered! How do you like your Fusion? Tell us! :)
    johnclineii is correct. TC is only engaged when needed (and you'll know when it's engaged, believe me). Leave it on.
  • SporinSporin Member Posts: 1,066
    Did a bit of car lot looking today and was blown away at the Ford dealership.
    Was VERY impressed by the Ford 500 and the Fusion/Milan/Zephyr. Those cars look incredible and come basically loaded for LOW LOW money. They had very well equipped, AWD 500's with 24k stickers...and you know they'll sell cheaper then that.
    The 500's are HUGE, on the outside, and the inside. The rear seat looked easily as wide as that of the Charger I was so enamored with. I wish I wasn't so blah on the exterior. It just looks like an 11/10 B5 Passat to me and it seems to sit VERY high... but since every single one was an AWD....do the FWD's sit lower?
    I love the exterior of the Fusion and Zephyr, and the interior of the Milan. They had leather clad Milans, basically loaded cars, stickering around $23k. A similarly equipped Zephyr was $34k! I don't understand the differentiation.
    A well equiped 5 spd, 4cyl Fusion was well under $20k.
    The Lincoln actually looked like it had a lower, sleeker roofline... trick of the eye? The Milan and Fusion are true twins... the grills are the only big exterior difference.
    Anyway, my point......that's a stunning value... but do people know it?? Ford needs to REALLY get the message out on these cars. These are the kind of cars that people have been BEGGING the US makers to produce.. solid, midsize sedans that can go toe-to-toe with the Accord and Camry.
    Bill Ford needs to give everyone at Mazda a raise.
    They're advertising like crazy - not sure they could do much more than they're already doing.
    A fully loaded fusion is $26K. As for the Zephyr sticker - a comparably equipped Zephyr is about $4K more than a Fusion/Milan and it does have a few extra features like memory seats, homelink, etc. in addition to extra sound deadening, thicker glass, higher quality interior, etc. The other options that get it to $34K are not available on the Fusion (THX audio, Nav, HIDs, etc.).
    I don't think there's any difference on the 500s fwd vs. awd. They are planning an exterior refresh either late this year or next year - it will look more like the fusion. Both the 500 and Fusion were originally styled like the 500. Horbury didn't have time to change the 500 but they did have time for the Fusion. Could you imagine the Fusion with 500 styling and called the Futura? That all worked out nicely!
    Amen! I drive a Nissan Maxima and was wooed by the muscle when I bought it only to realize that most of that power can't be sent to the road because of tire spin. The only time the power really helps is the rare occasion when I get stuck behind a slow vehicle on the highway and need it to pull into the passing lane.
    The HP Wars have overrated the necessity for power in most vehicles, I'll pay much more attention to interior amenity and ride quality on my next purchase.
    TCS is completely invisible to the drivetrain unless its activated by conditions and is actually applying your brakes or decreasing your throttle.
    Mark
  • mtnman1mtnman1 Member Posts: 431
    If the Traction Control is anything like that on a Sonata, there are certain situations where you might need to turn it off. On the Sonata if it senses the wheels slipping while applying power it will cut the engine back. In some cases, on the Sonata that is, if it is very slick it will cut the power to the wheels totally. If that's the case, I turn off the TCS or I won't get out of the situation.
    2012 Highlander Limited AWD V6 and 2015 Ford Fusion Hybrid SE
  • rscherbrscherb Member Posts: 46
    Do you think they will actually re-do the 500 for 2007 like they desperately need to do? They need to get it our redesigned fast. Also they need to do a redesign on the Focus. It's the same car now for 7 years. What is Ford thinking?
    It's funny the 1996 Taurus was too wild and weirdly styled so they toned it down for 2000 to a much less offensive look.
    Now the 500 is WAY too bland and they need do something to lower the yawn quotient.
    What is with them?
    Maybe the restyle will work, but if they try to make it look like a big Fusion, that may be another disaster.
  • mz6greyghostmz6greyghost Member Posts: 1,230
    What is with them?
    The Five Hundred was a victim of Ford's styling policy set in the early '00s to mimic European styling, mainly Audi and Mercedes. Obviously, it failed miserably. Realizing this, Ford dropped that philosophy and stayed on this side of the pond for new inspiration. Styling for the Fusion, according to Ford, is "more American".
    The Five Hundred will soon follow, as early as '07. They'll also include the new 3.5L V6, if they can produce enough of them for the Edge as well.
