Coolant Temperature Reducers
texasbeast
Member Posts: 5
Anyone have experience with these chemical additives for your radiator claiming to drop your coolant temp better than standard E.G./H2O mix? I saw a product called "40 Below", which claims to drop coolant temps another 40°F, and my 180000 mi 1980 Crown Vic is beggin' for something more to keep her cool. New water pump, hoses, and regular flushes, but the wore-out engine still runs hot. Strong engine and crisp tranny.
Still runs, though, so I guess I should be happy.
I would suspect that Vic has a fluid clutch in the fan drive, most of the large engines do. take a little morning test some day before firing the beast up. put ALL sets of keys in your pocket, pop the hood, and turn the fan by hand. if it spins freely, you need a new fluid clutch. if it doesn't spin by hand but will turn when the engine is started, you probably should replace the clutch. if there is a gob of oily goo behind the fluid clutch, replace it.
but if on a cool morning you can turn the fan and it feels to have some sort of smooth steady resistance, the fan clutch is probably OK.
have you taken a hose to the back of the radiator and flushed all the bugs, cottonwood seeds, and nonsense out the front? is there a bug screen in front of the radiator that is substantially plugged up? -- if so, get a toothbrush and brush the slop off.
but putting what is almost certainly mineral salts into the radiator is only going to increase corrosion. save your money both now and later, don't fall for that "mechanic in a can" nonsense. the only time the mechanic's in the can is when he/she takes a "health break."
There are no quick fix chemicals.
Plain and simple. You know that saying, "If it sounds too good to be true, it probably is."?
Well.............
Fix the problem, then there are some things that can help. Most of them are mechanical, not chemical.
I think the claim of a 40 degree drop in coolant is reckless advertising.
I'm sure there's some alcohol to its base substance...and it seemed to work OK. For $6, not a bad deal.
It's never claimed to be a miracle cure and I know many racers who use the stuff in drag racing since you can't use any type of coolant at the race tracks.
I'll hose the rear of the radiator like you said, swschrad. I've brushed the front clear regularly, but I never knocked the impacted stuff forward like you say. Harder to reach back there, so "outta sight, outta mind". Probably all kinds of nice things wedged up in there!
Actually, I don't know how they work exactly, come to think of it.
The steam acts like an insulator so the coolant cannot absorb the heat from the spot. Bubble burster. Nucleate boiling is the term.
Actually WW may increase the coolant temp ecu sensor reading because it reads coolant outflow from the head [absorb more heat, the coolant temp goes up] but the radiator becomes more efficient due to higher differential temp [hotter input], thus the rad OUTPUT may be slightly lower than without WW........need to read input and output [back to engine to learn exactly how much]
WW Works primarily by lowering the overall head temperatures which results in less detonation.
Aluminum heads conduct heat to coolant faster than iron [why they can run higher static compression ratio].
After all the head temperature [combustion chamber temperature] is what's important not the coolant temperature READING.......assuming you have enough pressure to keep from boiling in rad.
The less % AF you can use [and still have some corrosion protection] the more heat the coolant [water] can absorb from head and transport to rad, thus the higher efficiency the rad can operate at.
Following for HOST:
Depending on head design, composition, ambient and power output don't expect RR WW to always lower the coolant temperature the ecu temp sensor sees.............sometimes you need to trick the sensor/ecu 3,4,5,6,7F [trim the sensor resistance curve to avail yourself of the full benefits].......some [all] ecu go into summer protective mode [progressive advance reduction] when coolant exceeds 195F[Nissan]-200-205F [Ford 210F]reading. ALFA [?].
87 nissan 200sx 6cyl
perfect condition
radiator flushed 2 weeks ago.
we live in a hot climate
the car has been running hot for the past year and a radiator flush didn't cure the problem. his questions are... will removing the thermostat keep his engine running cooler? will removing the thermostat do any damage to his engine?
Without a thermostat the coolant will not warm up enough in cool weather to tell the ecu to get out of warm up enrichment mode [higher fuel consumption].
A 10 year old radiator may just need replacing as chemical cleaning can't correct the external corrosion or dirt......blocking air flow......new thermostat at the same time.
When ever you use a chemical flush you should change the thermostat afterwards as the rubber/neoprene seal can be damaged by the chemicals.
