2000 Chevrolet Siverado Tire Sizes
I have ordered a 2000 Reg Cab SWB Silverado LS and
I am a little disappointed in one of the
limitations placed on me by Chevy. My truck will
be used mostly for trips back and forth to work and
not towing. I will use the truck for towing my
boat which is 3000 pounds a couple weekends a
month. Here is my problem - The only way I can get
larger tires on my truck is to get the firm
suspension. Since almost all my driving will not
involve towing I want the standard suspension. The
truck comes standard with P235x75x16 with the
standard suspension but the tires I really want
are the tires offered with the firm suspension only
the 255x70x16 tires. Does anyone think there
would be a problem switching the tires out at the
appropriate tire dealership when the truck arrives?
Will the standard suspension handle the little
bigger tires? Am I knit picking to want the larger
tires? From exterior appearances will I be able
to tell the difference betwee the 235's and the
255's? I am getting the 5.3 V8, auto, with locking
differential. Thanks for any thoughts on this
subject you might have.
save this site
I have also been on the tire hunt and this is what I've found out. No tire dealer wants the 235/75/r16 tire because it's too big for cars and people who own trucks don't want a passenger tire. The best thing to do is upgrade to a little bit larger size (245/75/r16) but then you will need to have the truck re-calibrated because the shift points will be slightly different. Just about everybody makes that size and it is a good looking tire in a LT series. I have not purchased tires yet because of $ but I will do my best to dog out these Generals I've got and get some Michelins within the next year or so.
My 3/4 says 50/80...but I run 40 all around
- Tim
I recommend running them less than 35 psi if you are empty. Mine have been wearing a little bit in the center. MarkBuck explained that the object is to maintain the same size contact patch whether you are empty or full. That means more air pressure when loaded, less when empty. By how much I forget. He seems to have a good handle on this. Maybe he will chime in.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
