Dodge,Ford,Chevy-----Who Wins? - II
Nothing like an American v-8 with the right exhaust!
I am not into modifying the stock engines anymore. Been there, done that. For me it's a truck, not a pro stocker.
If you wanted some off-the-line snap, you could consider a higher stall speed torque converter, but if I were you, I would save my money.
The exhaust system makes as much sense as anything. I don't think you get very much of a boost with any bolt-ons, short of a whipple, or Ligenfelter 383.
Maybe listening to too much performance crap on edmunds. I am currently shopping for a new used F150 2wd and it turns me off every time I go and look at one that resembles a JC Whitney poster truck.
Good Luck!*****************************************
I totally agree. Computers today have taken the fun out of the "mechanics" of an engine today. That's probably the reason why I always have left my trucks stock while pouring money into my bikes!!
At 6'8", yes I am very comfortable in the new rig. You should come to Texas, Quad. with this CC, I now finally feel like part of the crowd...
I've been leaning toward the same. if you put your foot into, that 350 has plenty of snap. I've had it for 5 days, and i'm still amazed at how strong the Vortec is over the non-Vortec, even in the heavier truck. the only other issue is I put 265's on it instead of the stock 245 tires, which makes my speedo off a little. I thought, get a hypertech, correct the speedo, boost the engine, but hell, its only 2 mph off anyway. Plus I'm getting 16 mpg (2 tanks, highway) out of a 6500 lb truck, with more passing power than my old one. What the hell am I complaining about???? I can't wait to hook the boat up and head for the coast.
Thanks to all!
of several that will walk away from the 454 vortec even with 7000+ lbs of trailer.It seems the 5.7HD is underrated to make the 7.4 look worth the money.So GM overrated the 7.4.On paper you'd think the 454 would be so much more,but in the real world,it really isnt much stronger,and it isnt even a grunt motor anymore,so it needs to be wound up as much as the 5.7.I think the 200+lbs you saved in weight makes up for the HP difference in the two and you now have 200+ more payload,which is very important with CC,they are real heavy as you know.I'm still amazed at the vortec5700's power every time I drive one-even more so in heavy trucks like yours,they really pull well and dont die with a load,as 7.4 owners would have you believe.Good luck and get a Hypertech powerprogrammer and a good cat back and go eat some bigblocks!
I question whether the side exhausts were a "problem" or more of a liability to Ford. The chances that someone damaging their side pipe is unlikely but it would garner bad press since Ford would and does have the option of placing the pipes behind the wheel. Any lawyer could eat that up-which leads me to that opinion rather than mishaps.
http://members.aol.com/sturbridg1/utahtrek.html
My point exactly....
You haven't looked hard enough then. Plenty of problems reported on Tundra. The guy reporting the stuck exhaust valve caused by metal shavings is more serious than any GM problem you've read about, and probably just as rare.
So what does the Co-host do? Is it a paying job?
Community Leader paid too
gw,
Still up in the air as to what Dodge will do wioth the 4wd system of the new Ram. Personally, I would hope the heavy duty trucks would at least maintain the system they have, or better yet, go to a manual option like the Ford Super Duty trucks.
kcram
Co-Host - Smart Shopper & FWI Conferences
edmunds.com Town Hall
Does it pay enough for a new Ram??
running stock 235/85 R16 tires. It is a work/play
truck that is used for hauling, towing and off-road (hunting, camping, exploring, etc. on roads that are usually rough and washed out.) As I don't believe in driving slow, I've bottomed out the heavy T-D engine more than once! I am not a
rock-crawler or heavy off-road enthusiast, however, I am looking for good shocks. I am willing to spend the money on Bilsteins or Ranchos, but if Monroe or Gabriels will work, that's great! I don't mind a stiff ride (I was born and raised in pickups) as long as it handles well. Any suggestions? Thanks!
kcram
I hear you!
Chevyck1,
15 isn't outrageous. Two quarts of oil per thousand is-if true.
"It is unclear which Mercedes engine will be used. Mueller said a common-rail diesel injection engine might be the choice. These engines are designed for passenger vehicles and range in size from 2.0 liters to 4.0 liters. But a manager with Dodge powertrain development in Auburn Hills, Mich., said his team has been working on packaging the Mercedes' MBE-906 diesel engine in the Ram. The MBE-906 is a six-cylinder, 6.4-liter, turbodiesel. It is a heavy-duty truck engine available in DaimlerChrysler's Freightliner and Sterling brands. The MBE-906 is larger than the Cummins engine and offers between 190 and 280 hp."
I know nothing about Mercedez diesels other than they have been making them forever and everything they make is super heavy duty. But I wonder how technologically advanced a prospective engine for the Ram would be, i.e. will it match up against the Duramax and the next generation Powerstroke? The article also stated that the move to change from Cummins to Mercedez is at least partially based on cost savings. At any rate, this is a very interesting change of events, especially since the most commited Ram fans are the Cummins fanatics (myself included). Go see the article at www.autonews.com - "Mercedes diesels to power next Ram" (March 6, 2000).
Does a Dodge owner want to wear gray flannel? What happens the when tinted window rolls down, and the driver says, "Pardon me, but would you have any grey poupon?"
I hope the Cummins finds a home. For a while, it was rumored you would be able to get one in Dodge, Ford or GM.
It Mercedes persists in de-Americanizing Dodge, where will that small but loyal group of truck buyers migrate?
This is a Dodge problem. Chevy owners will flock to the Izuzu Duramax, because the previous GM diesel can't be mentioned in the same sentence as the more esteemed Cummins 1SB.
Perhaps Cummins is the victim of its own success. It really is a very costly propostion to own and maintain one.
I have the easy answers to your questions. Ford would drop International like a hot potato and pull in the Cummins motor.
The Blue-collar and Cummins fans would flock to Ford especially now that the Ram guys claim the Super-duties are look-a-likes anyway. It would be a mistake for Daimler but they'll probably make it. Many former Dodge engineers have left the company and a recent Time article found that the company is dominated by the Germans.
I think you could be right, but Navistar has sold lots of engines, and should have a pretty good following of its own developing, no?
One reason for liking the Navistar is that most owners will say it accelerates more strongly. It's bigger too. I guess the good part about the Cummins is when your truck retires, you take the engine out and use it in your next one.
Dominated by Germans? Well, kind of sobering I guess. They know how to make things. But can they understand the American truck buyer? I'm skeptical too.
Chrysler Dodge Jeep Edition
BUZZ
NEWS
REVIEWS
FEATURES
INDEX
MERCEDES DIESEL FOR NEXT RAM?
Warning: This column is often based on rumors and information derived from
unsubstantiated sources. We do not guarantee the veracity of any of the information
contained in this column. For news and in-depth features please visit the News,
Features or Reviews sections of this site. Read on at your own risk.
Automotive News is reporting that Dodge will use Mercedes
Benz diesel engines in the next generation Dodge Ram truck.
Their source, DC Chairman Juergen Schrempp. Hour's after
the story was posted , DC released the following statement.
Title: DaimlerChrysler Statement in Response to Future
Diesel Engine Applications for Dodge Ram
In our pursuit to offer the most powerful, durable and fuel
efficient diesel pickup truck in the market, we owe it to our
customers to look at all alternatives. At this time, a
Mercedes-Benz diesel engine is being considered in addition
to the Cummins engine that is currently
offered in Dodge Ram diesel pickups. However, we are very
early in the process of determining which engine -- or
engines -- will be best suited for future Dodge Ram trucks
and have not made any final decisions. We have enjoyed a
strong relationship with Cummins for many years and we
hope to continue it.
So which diesel are they "considering?" The Automotive
News report adds that a Dodge power train manager told
them that "his team has been working on packaging
Mercedes' MBE-906 diesel engine in the Ram."
The engine seems like an obvious choice. In the US the 6.4
liter diesel engine is used in both Freightliner and Sterling
trucks. The water-cooled in-line six features 3-valve
technology (two intake, one exhaust). The electronically
controlled turbocharged engine uses charge air cooling to
improve performance.
2300 rpm and a 520 lb. ft. @ 1200rpm. At its top rating the
mill puts out 300 HP @ 2300 rpm and 860 lb. ft @ 1400
rpm. It would also be a good match for the Mercedes Benz
W5A800 transmissions recently listed in Dodge literature.
So will Dodge switch from Cummins when the next Ram
shows-up? In my first column about the DC merger, I
predicted that we'd be seeing MB diesels in Dodge Trucks.
Of all the possible synergies, it seemed like the most
obvious. It still does, why go out and buy something that
you already build in-house?
As far as the notion of offering two diesels . . . I just don't
see it. There's no advantage to the move. It would only add
complexity to the line-up and double the parts and training
Dodge truck dealers would need.
That said I hate to see Cummins go, they build a world class
product. Cummins has been a great partner to Dodge. The
relationship began in 1988, since then they have played an
important part in Dodge's success.
WHO WILL IT BE?
WIN THIS HAT
Our friends at Dodge sent over an interesting item today
titled "Who Will be Our Next NASCAR Driver?"
Auburn Hills, Mich. -- Keeping up with the latest racing
rumors? Dodge figures NASCAR racing fans keep up to date
on the latest news and gossip. But how informed are they?
Dodge will launch an internet-based poll of NASCAR fans to
find out who they think will be the next driver to be named
to take the wheel of a Dodge Intrepid R/T in the 2001
NASCAR Winston Cup season.
Fans will get their answer soon enough -- NASCAR team
owner and Dodge Motorsports development partner Ray
Evernham will host a 9:35 a.m. press conference this Friday,
March 10 at Atlanta Motor Speedway to name the first of
two drivers to race the Evernham Motorsports entries.
Dodge is conducting a major radio and internet promotion
to reach fans who can then log on to Dodge's website and
show off their insider racing knowledge. The first 30,000
respondents will receive a commemorative Dodge
Motorsports hat as a token of appreciation.
END
The release confirms my report that Evernham has already
signed his drivers. We know "Awesome" Bill Elliott is
definitely on-board. He will definitely be Friday's
announcement.
The second guy is still a mystery. Evernham has often stated
that his second driver will be a young gun. The leading
contender in the NASCAR press has been Casey Atwood.
However if you believe the Buzz, Atwood hasn't spoken to
Everham until last week.
Two weeks ago an inside source told me the deal was done .
Does this mean he's out of the picture? That fact that was
allegedly confirmed by the friendly note I got from Atwood's
PR flak after I mentioned him last. He informed me that
"Casey has NEVER spoken to Ray Evernham or ANY
Dodge representative NOR HAS HE SIGNED WITH
ANYONE FOR THE 2001 WINSTON CUP SEASON."
If not Atwood, then who? Jay Sauter and Stacey Compton
have also been mentioned. Compton's Dodge racing
connection (he drove the #86 RC Dodge last year in the
Craftsman Truck series) would probably make him the
contender among those two.
Regardless of who you think it is, make sure to head over to
the Dodge site right now. You don't have to be right to win
one of the 30,000 prizes, but you only have until the 10th of
March to enter!
SPREAD THE BUZZ
Click on the button below&#
If you go to car-truck.com they say that the source is Jurgen Shremp head of dc.
BUZZ
NEWS
REVIEWS
FEATURES
INDEX
MERCEDES DIESEL FOR NEXT RAM?n to eMail a link to this column to a friend.
Have a comment on this column? Heard a rumor you're
wondering about? Do you have questions about future
DaimlerChrysler products? Click here to ask the Buzz
Watcher
March 7th, 2000
NOTE: Car & Truck News is supported solely by advertising
revenue. If you enjoy this site, please take a moment to visit
our sponsors. Thank you for your support.
BACK TO BUZZ
TO JOIN THE BUZZ
MAILING LIST
CLICK HERE
DO YOU HAVE A TIP
FOR OUR EDITORS?
CLICK HERE
CHRYSLER DODGE
JEEP QUESTIONS
CLICK HERE
Copyright 1989-2000 Car & Truck News
CAR & TRUCK NEWS IS NOT AFFILIATED WITH DAIMLERCHRYSLER CORPORATION
UNLESS OTHERWISE NOTED ALL MATERIAL IN THIS SITE IS THE EXCLUSIVE PROPERTY OF CAR & TRUCK NEWS.
NO PHOTOS, GRAPHICS, CODE, OR WRITTEN MATERIAL ON THIS SITE MAY BE USED WITHOUT WRITTEN
PERMISSION FROM CAR & TRUCK NEWS
ENTRY INTO THIS SITE INDICATES ACCEPTANCE OF THESE TERMS
editor@car-truck.com
OPTIMIZED FOR NETSCAPE SINCE 1995
Mar. 7, 2000-- DaimlerChrysler announced on Monday that the automaker was considering Mercedes-Benz diesel
engines for use in Dodge Ram pickups, Reuters reported.
"In our pursuit to offer the most powerful, durable and fuel-efficient diesel pickup truck in the market, we owe it to our
customers to look at all alternatives," DaimlerChrysler said in a statement.
But Cummins Engine Co. -- which currently provides diesel engines for the Dodge Ram trucks -- announced today that
it would continue to provide all diesel engines for DaimlerChrysler's product.
"I spoke to [DaimlerChrysler President] Jim Holden last night in Auburn Hills, who confirmed that Cummins would
remain the diesel engine option in its Dodge Ram pickup truck," said Cummins Chairman and CEO Tim Solso.
The announcements followed an article printed in Automotive News that quoted Mercedes-Benz manufacturing
spokesman Enrico Mueller as saying the M-B engines would begin with the next generation of the Ram pickup, due in
2002 as a 2003 model.
According to the story, one in five Ram pickups uses a Cummins diesel engine.
Did ya'll not believe me then!!???
sorry, needed some self-fulfilment today...
I think it's kind of exciting. But they probably should not have messed with the Dodge buyers. Germans build cars the way they like them. If you put a Mercedes diesel engine in a Mercedes SUV, and then re-badged it as a Dodge, I wonder how many of the drivers stepping into it would come from Dodge trucks? Not many.
So what they risk, is the loyal pool of ownership, trading on the belief they will attract enough customers from other segments. The Dodge buyers could be interested. No doubt it's a good engine. Question is, will they put too much German influence into the style, making the Dodge cab into a MB? That would be a mistake in the American market. In my opinion, of course.
Just as Cummins had a great reputation for diesels, anyone who looks into it will see that Germans have more experience with diesels than anyone. Look at German tanks in WWII, those diesels were schooling our gas tanks. Mercedes has great engineers. Germans generally over-build things. I think most pickup owners recognize those things. So you can bet a MB diesel, if placed in a Ram, would be heavy duty. Question is: how much power/torque compared to Duramax/Powerstroke?, how efficient is it?, and how expensive will maintenance be?
the problem with them was the rebuild. if and when those engines went out, it would have been over $100,000 in parts and kits alone. a comparable Cat or Detroit wouldn't cost 1/4 of that.
So yes, currently MB builds great performing and extremely expensive engines. hopefully, maintenance costs won't be an issue other than fluids.
I disagree with gwmoore on the brand loyalty. true, Dodge pulled over a lot of Ford and GM drivers over the last 6 to 7 years on the Cummins track record. but after this amount of time, I see a lot of those people who've had no probs,( and even some folks that had a few probs) swearing by Mopar products, not Cummins. I think Dodge has a following faithful, almost as devout as the Ford/GM.
I think the Cummins has very big following as well. I know of several former Chevy drivers that traded in for a Cummins cuz they loved the way the engine pulled a load. they could care less what was the grille ornament, the Cummins under the hood was their only reason for buying. so folks in that class will be alienated.
I just think that Dodge has a bigger following than Cummins does, so they won't be hurt.
The MB engine in question is listed on the MB website under Commercial Trucks; I found it a year ago when the rumor first started. This engine challenges the Cat 3126, and the larger Cummins ISC - it's rated as high as 280 hp and 800 lb-ft - too high for a 3/4 ton pickup.
But that's strictly my pair of pennies.
kcram
crazywoman,
I hear you. That's the reason I have gone almost exclusively Ford the past few years for my firm. My point was that the only superior attribute of the Ram IS the Cummins! Take that out of the Ram and I think Dodge/Daimler are making a huge mistake at judging teh American truck consumer: personal and commercial. I know Merceds can make a motor but at what sales loss can it be beneficial to do "in-house"?
Reminds me of the GM diesels......at least they had to bail out and get Isuzu to design theirs for them.
Now, on to Mercedes. They are a pretty smart company that is obsessed with their reputation. I don't see DC putting a new diesel in the Ram that doesn't at least do as well as the Cummins. More than likely, IF they do put a MB diesel in the Ram, it will be one heck of a good engine and be top of the class. Mercedes has the resources to assure that, and they can't afford to tarnish their reputation with anything less. If DC does put a new engine in the Ram that is the top of the class (whether it is Mercedes, Cummins or a Yugo), you're crazy if you think that will chase Ram owners away!
Look at Chevy. Now that is a good old boy, traditionalist group of buyers and they are welcoming a JAPANESE engine like it is the Second Coming! If they can keep their buyers with an Isuzu diesel, then I'm sure Dodge can keep their buyers with a Mercedes diesel (as long as it performs and doesn't cost a fortune). Besides, if there is such a thing as loyal Dodge customers, they probably want one of the new Hemis instead since that would be a true Dodge legacy.
To keep away from the 'tech talk', No, you don't just trade HP for torque, or vice versa.
in fact given the same rpm engine, if you raise the torque, you raise the horsepower with it.
Torque is tricky to understand because the number that is always advertised, rarely means anything significant. peak torque is just the amount of work it can do at one specific RPM point. the torque curve is what really determines how an engine feels when you stick your foot in it.
hope i didn't add anymore confusion,
Don't worry, the MB diesel will be a monster. Really, at some point, engines are going to be hot enough to pull our trucks in half.
and I wouldn't call Isuzu diesel 'Japanese', when GM is the majority owner of the company. Isuzu has been competing with Cats and Cummins for years in the big big industrial apps, and are no slouch.
First of all, let's get the math/physics out of the way by noting (as you probably know) the equation:
hp = (torque * rpm)/5250 (torque in lb-ft)
The torque is itself a function of rpm which is a characteristic of a particular engine displacement (bore, stroke) and the tuning (cam choice, head choice, timing, exhaust choice, etc.).
If you call rpm "x" and the torque "f(x)", then
horsepower = g(x) = xf(x) (forgetting about the units conversion constant of 1/5250 for now). Okay enough math.
From a practical "feel" perspective, torque and horsepower are really the same thing. What confuses the issue is peak horsepower vs. peak torque. So ignore those quantities for a minute.
If an engine has more torque at a given rpm than another engine, it also has more horsepower there (the above formula tells you so). Most people don't think of diesels as having a lot of horsepower, but it's true, they generate more horsepower than even the best gas engines...at low rpm. It's just that with diesels the torque falls off fast at high rpm and by the formula, that means the horsepower goes down fast too. It's not often said this way, but when someone wants pulling power they want to have a lot of horsepower at low rpm. By the formula, the ONLY way to get that is by having high torque at low rpm. Race cars want the most horsepower possible regardless of rpm, so the easiest way to get it, again using the formula, is to have an engine that's able to rev to screaming rpms (8-10000). Even if the torque isn't particularly high there, as long as it's reasonable torque, the horsepower will be high.
To sum up, the best way to think of the difference is that they're not different. They happen to be two different ways of describing the same thing by using two different physical models.
To me the more informative model is the torque model because if someone quotes a peak horsepower number by saying "This engine has 290 horsepower" it's very important to ask "at what rpm?". It could be a truck engine at 4800 rpm or it could be a sportscar engine at 7500 rpm. You also don't know how high the horsepower is at normal driving rpms. However, if someone says, "This engine has 410 lb-ft of torque", the rpm matters, but not nearly as much because the torque function or curve is fairly flat so if he's talking about 3200 rpm, it's still fairly close to that at 2200 rpm and 4200 rpm and even down to 1200 rpm. So from that one number, 410 lb-ft, you can get a rough estimate of the horsepower at all those rpms by just plugging in to the formula.
Anyway, hope that helped in some small way.
Later,
-powerisfun
Thank God that Power tried to explain it before I had a shot!! It reminds me of the "chicken versus egg" debate.
I have two classic examples of rpm/torque differences in my garage. One is a 93 Harley FXR Super-Glide and the other is a 96 Honda Magna. (I'll leave the BMW out of it since the Harley is a crude version of it.)
My magna displaces 750cc(45 cubic inches) which is nearly half of the Harley output of 1340. The Magna is stock 75 hp a@7500 rpms versus the Harley's 60(maybe) @4000rpm. The torque difference is felt in first gear where the Harley wants to crawl without gas--serious torque at a low rpm--virtually at idle @1000 rpm. The honda would stall out unless the gas revved the motor to around 3grand--at the least. The small flywheel and low torque demands on the Magna to require higher rpm for equal power to the Harley. At OD--this figure reverses itself as the Harley will top off losing power while the Magna is hitting it's sweet spot.
Rpm dictated that Harley would pull strong from first but die in fifth whereas the Magna proved opposite.
I know that Daimler will place an exceptional motor in the Ram but Cummins is no sloucher. Diesel fans should enjoy the future.
I think Power said it best when he said diesels actually have more horsepower than the best gas engines. AT LOW RPMs. absolutely correct, but rarely thought of in that context.
