Subaru XT Turbo Forester
-Dennis
Like so many things, best is subjective.
Larry
http://automobilemag.com/2006_new_cars/0509_2007_toyota_rav4/
Then again, if it "grows significantly" as they mention, comparing it to the Tribeca might be more appropriate - which would also put it in the same market as Toyota's own Highlander. Something doesn't make sense.
steve_, "Toyota RAV4" #1921, 30 Aug 2005 1:00 pm
Usual disclaimers, lol.
There's no way, I find that hard to believe. The Avalon costs a fortune and makes 280hp from a 3.8l that probably would not even fit under the hood.
I can see it getting the 3.0l or maybe the 3.3l engine, but those make 190-225hp or so. Maybe they will offer a TRD supercharger option?
I just can't see it going from 160hp to 300hp without anything inbetween, it makes no sense.
I'd sure as heck like to try one if it does!
-juice
Or if you want the only all-season tire that gets the Severe Service snow emblem, check out the Nokkia WR. Better in the snow at the expense of better handling in the dry.
-Dennis
Stacie
05 XT
If anyone has any experience they would like to share regarding this and their FXT I would love to hear it.
thanks and sorry have sent the first one before doing ALL my research.
Stacie
05 XT
-Dennis
-Frank
Stacie
Len
Does the Subaru aftermarket SR deflector help?
But at certain speeds, I still get buffeting. Yours is enormous so I can imagine it's worse.
I crack the rear windows just a tad, that fixes it at all speeds.
-juice
-Frank
You would get buffeting if you opened a FRONT window, not moonroof, just window. It was intolerable. You basically could not open the windows at certain speeds, period.
-juice
In comparison, DW's '02 MPV bought in July '02 has almost 29,000 on it, or about 9,250 miles per year.
-Brian
-Dennis
-Frank
About the only gripes I had during the test drive were that the wind noise seemed pretty loud on the freeway at speeds of 80-85 mph, and the seats didn't seem all that supportive. Wondering how comfy they would be on extended trips...
So now, I just need to ask myself the hard question: do I want to give up my beloved E36 M3 convertible for something that is probably just as fast and a whole lot more practical? The other thing still on my mind is that I feel I should probably look at an Outback XT as well given the added space for a family of 4, but I'm hesitating because I really wanted to keep this purchase on the low end of the $20-$25K range.
FWIW, we still plan on keeping our Honda Odyssey for a few more years, so I don't NEED the largest car out there.
Which brings up one more question: we tend to keep our cars for a long time. My M3 is a '98 and the Odyssey is a '99. I've never owned a turbocharged car before and do have some concerns about longevity over the long haul. Any comments? Thanks.
I'm getting my driver's side seat track replaced tomorrow. Checked on another website and saw another person with an 04 XT was also getting the same track replaced - its the outboard one. In both cases the leg is rusting where it meets the carpet.
This is the 4th one I know of. Takes just a second to inspect, and covered under the warranty Curious to see how long it takes them to replace. I'll find out since I'm waiting for the car.
Just a heads up for the rest of the group.
Larry
Do you feel like you've miled the M3 for most of what it's worth? i.e. are the best days behind you, or ahead?
You can get good resale on those, and probably not have to pay a large difference to have a new vehicle.
Also - do you need 2 practical vehicles? Are there times where the Ody is shuffling the kids around and you still need to make a run to Home Depot to pick up mulch?
If you encounter those situations, then you could benefit from a more practical car, so go for it.
If not, I'd hang on to the drop-top for as long as you can.
-juice (owner of a Forester and a Miata)
Re turbo reliability, only time will tell for certain but the reliability problems that were an issue in the 80s have hopefully been resolved. Turbos are certainly more prevalent now across many more makes and models.
-Frank
Just noticed that I'm getting a "noise" during the 2-3 upshift under moderate acceleration. Only happens when the transmission is hot.
Transmission still shifts smooth on the way up, its never really been very smooth during downshifts since the day I got it. Currently 27K on the car.
The noise is a tough one to describe - not a clunk, wham, or extremely loud for that matter. But it is repeatable, and is more like a rattle in the transmission (valve?) body. Definitely not engine noise. I know the XT uses more solenoids than the regular 4EAT and I'm wondering if that's what I'm hearing. :confuse:
Had the dealer check the fluid and they said it was fine.
Let's see, got 28 k on the 03 Outback's auto, maybe they're only designed to go that far..... So far between these two cars I've had more transmission issues than any other cars in 30+ years.
I'm going to make another appointment at the dealer to get it documented, but its going to be a waste of time. BTW- if they find anything I'll be happy to eat my words on this forum.
Larry
I traded in a '95 525i last year on a '05 XS with 5-speed. The old Beemer was at the point where I knew I'd be up against major maint (tires, shocks, 120K service), plus the electrics were starting to act up. 'twas time to start what the folks at work call "cost avoidance". I still have a '97 328i BMW convertible, driven summers, putting on 5k miles a year.
For the Subie, maintenance costs are a lot less. I just got the 15K service done at zero out-of-pocket cost using Subaru bucks (3% rebate program on Chase credit card). Plus I am getting 30+mpg on regular gas over the last 7k miles (since May 1). It's nice to be able to drive 400+ miles between fill-ups.
From a comfort viewpoint, the XS wins hands down. Seats are not an issue. I've had a couple of 200-mile drives since April. The stick shift is easy to use once I adjusted / disabled the Hill-holder feature. Noise is a subjective issue. It is not the quietest car I've ever driven, but it is quieter than the 'vertie. Entry in/out the front seats is excellent - 'bout the best I've ever experienced.
Luv that huge moonroof ! Slide the shade back, the inside is flooded with sunlight or moonlight. When the sun beats down, you just reach over your head and shut the shade. But you know that already, from comparing the XT vs M3.
Comparing the driving experience between the two, overall, the XS (and I'm sure the XT also applies here) is more fun to drive than the 'vertie. I never thought I'd come to this judgement when I first bought the XS 10 months ago. It's great on snowy / muddy / dirt roads. Drive the Beemer in snow, you're always conscious that you have RWD and that you don't wanna do anything stupid to lose control.. With the Subie, you don't even think about maintaining traction in the slushy stuff. It just happens!
XS vs XT? XT is a rocket but it also requires an expensive high-octane diet, which is why I went with the XS. XT will give you the performance to zip up the hills.
So when are you getting yer XT ?
BTW, we are looking at the "Un-Limited" models, so no leather and no moonroof.
Good to hear that the seats are comfy. Remember that I only took a 15-20 minute test drive, so real world feedback from owners is a lot more informative. I am fairly tall and slim at 6'1", 165 and did appreciate the headroom in the FXT, but at the same time, I really don't mind the headroom (or lack of it) in my bimmer. As long as my head doesn't hit the ceiling , which it doesn't, then I'm OK. I do prefer a rather upright seating position (learned from a performance driving school) so I didn't notice the gearshift being too far away on the test drive.
Finally, as far as the "fun to drive" factor is concerned, I'm sure that while the FXT provides loads of enjoyment, I think you'll turn blue in the face before you can convince me that it would better than the M3 on a twisty stretch of dry pavement.
Huh? I'm quite sure no one here has tried to convince you that the Forester handles better. In fact I tried to make it crystal clear that if you get stuck on comparing the Forester's handling to the M3 then you won't be happy driving it. Yes the Forester has excellent handling for its class (small SUV/wagon) but it's not a sports coupe!
-Frank
Wet? Snowy? Bumpy? Gravel? Dirt? Sand? XT baby!
-juice
Here's what I was commenting on...
growler went on to say that his Forester is great for mud, snow, and dirt roads, which I'm sure is true. However, while he's entitled to his opinion, I wouldn't agree with the "overall more fun to drive" statement (as compared to his bimmer convertible). The M3 doesn't see mud, snow, or dirt roads as it was never intended to go there. On pavement, which is probably 95% of what I do, there's no question in my mind about which would be "overall more fun to drive."
Can anyone comment on what upgrades give the biggest bang for the buck without voiding the warranty ?
Michael
However, it's mounted into a plastic threaded T fitting that's connected on each end with what appears to be one-time use clamps. The pcv valve has the standard pinch connector on it.
The bad news is that I couldn't get the pcv valve out. I was afraid that if I applied any more force than I did, I'd bust the plastic fitting.
So I guess its going to be a dealer visit, at least for the first one.
So, if I were just out buying the thing for myself and had no other things to consider, I would choose the FXT. I think it offers more in the fun-to-drive factory, yet is still very utilitarian. However, given that we are planning to keep the Odyssey only for about 2 more years, this car could very well be THE family car for us after that. My wife has wanted a Mini Cooper since they came out, so I figure if she does get one in a coupla years, the OXT will be the better choice.
Guess I need to post my findings over on the Outback forum now!
The more I think about it, the more excited I get, so I'm going to try hard to keep my mind off of it until I pick it up from the dealer! I just hope it gets here in time for a road trip I need to make next weekend, through the windy, often steep Ozark mountains. Should prove quite a fun little test to break this thing in (as well as a nice challenge not to get a speeding ticket, as I did last month on the same route).
My average driving won't get me to 1000 miles for 5-6 weeks, and getting to work is rather difficult without the interstate - will the FXT make it to highway speeds without needing to rev over 4000rpm?
That's hysterical. I would like permission to quote you in the future. Seriously.
-juice
So here's to taking the long way home, and other detours, for at least the next month!
2006 XT, steel gray ext w/black leather int
Optional accessories:
all weather floor mats
cargo tray
splash guards
rear bumper guard
(may eventually add dog guard, trailer hitch, cross bars, and rear diff protector)
Delivered from Wyatt/Johnson Subaru in Clarksville, TN, to Little Rock, AR, with 111 miles on the odometer. Road trip to Springfield, MO tomorrow - I can't wait to get it up in the twisties! And at about 500 miles round trip, I'll be done with my first 1000 in no time.
Doug
