I did it because the front seat folds flat, and when you have cargo on it, the chime would go off! It thinks a person's weight is there.
Hopefully Subaru has something similar.
I was able to 'silence' the seat-belt warning chime. As I recall it was pretty simple like "repeatedly plug-unplug the the seatbelt into the latch 20 times in succession within 30 seconds"
As I recall I did it with the engine idling. AND IT WORKED!!!
No more chime when I remove my seatbelt.
Here is a Youtube link showing the procedure.
Gotta love the Subaru Crew! :shades:
1) @ 13,000 (1yr old) driver side left front wheel bearing failure. It took 15 months and several trips to dealer because the noise was intermittent they couldn't fix it until it was heard. Diagnosed @ 26,000 m. I told them from the beginning it was the wheel bearing and they did all types of tests and said it was fine. Replaced under warranty.
2. Didn't take test drive @ night. Since new, headlights have sharp cutoff & don't illuminate too far ahead. Asked dealer if headlights could be adjusted, no. There are complaints on nhtsa.gov for this issue.
3. Noticed driver seat creaks when making turns. Dealer says nothings wrong. Trim pieces in back window pillars popping out. Dealer replaced both sides. New ones are doing the same.
4. Brakes spongy & go to floor. Subaru is not known for their great brakes. Dealer said, all is normal. I've had the lines bled, new fluid & front & rear disc, pads replaced there hasn't been improvement. All at my expense.
5. 5/10 New windshield replaced. Driving down street (25 mph) small rock hit windshield, cracked length of vehicle. I know it may be design of slanted windshield.
6. Driving on highway & residential street, noticed rock chips on hood of car within 1st year.
7.@ 2 yr (24,000) both trunk hinges are creaking loudly. Tech confirms failed trunk hinges. Replaced under warranty. I've had several rust buckets and never had a creaking hinge.
8. Car from new stutters like it's going to stall and dealer says can't find any codes, nothing wrong. My 06 Outback did the same thing.
9. Misaligned glove box (left side sags) from new. Dealer said no fix for this.
10. Large gap on left side between trunk & body. Tech found trunk latch out of adjustment.
11. @ 3 1/2 yrs (38,000) tires losing air. Dealer inspected couldn't find anything. Charged me to diagnose. I have two sets of tires, so I monitored the condition w/ the other set. It has been a somewhat slow but noticeable leak, added air.
12. 4 yrs (41,000) In to mount tires. Dealer called, transmission lines leaking. I told them I didn't see fluid on ground. Dealer said that it's rubber & something may have cut, or it wore out. I was suspicious but told them to replace. covered by warranty.
13 . 7/12 (43,200) In for oil change. Tech finds drivers side front outer axle boot was cracked & all grease leaked out. Dealer asked if I heard noise while driving. I'm very aware to sounds & will not neglect my vehicle. Even though all grease leaked out but I didn't hear sounds they only replaced the boot & not shaft/cv joint. I think the shaft/cv joint should have been replaced since boot leaked grease, possibly getting dirty & failing early. In time, the cv joint might fail prematurely. I explained to dealer & was assured it was okay. Dealer said, boots are rubber & fail over time. My 7 yr old Impreza never needed a boot & that car survived harsh VT winters, long commute to work & no garage. Maybe Subaru is making them thinner.
14.. 9/12 (43,000) I spray soap/water mix find bubbles @ base of metal tire valve. Call Subaru warranty to find out if TPMS failure is covered. They confirm it is. Taking car in Nov. to put on snows, will wait till then.
15. 11/12 (45,000) Tell dealer I found air leak @ valve stem. They tell me that it could be corrosion & wouldn't be covered under warranty. Tech confirmed 3 were leaking & I said it's premature for them to leak. The TPMS is 1 unit & it doesn't come in separate pieces. Dealer said there is "no code for leaking valve stem." They replace 3 sensors & tell me" we"ll tell Subaru it wasn't corrosion & make it covered under warranty somehow." I will inform Subaru of failure. At this point, I don't think it's worth my time.
Call us when your cat, head gasket or transmission go.
Paint chips - that's just par for the course. Paint nowadays is not as durable as it once was, and experience will differ based on road and traffic conditions from one day to the next.
Headlights? Yours might need some realignment, but the "sharp cutoff" is an artifact of projector-style headlights. Your visibility wouldn't necessarily be better with non-projector headlights, but you wouldn't notice the transition as much.
Windshield - I feel your pain. For what it's worth, though, the '08 glass was more durable than later offerings! It's tough to get good glass now, and even the best stuff can crack with the right chip.
Interior squeaks, rattles. Yep, that's what makes a Subaru, a Subaru.
The other stuff:
Wheel bearings - documentation is pretty stout with premature failures here. Frustrating that it took them 13K miles to fix it, but at least you documented it early. That could make a difference as you near the ext. warranty end (too bad you didn't go with zero deductible!).
Boot failure - happens. Like with paint and glass, you can't really compare one situation to the next, as there may have been debris that contacted the part or some other condition not present in a past example that hastened this one's demise. That said, I would have insisted on axle replacement under warranty for exactly the reasons you specified. Had it been out of warranty, I wouldn't be opposed to a fly-by-night boot replacement to extend the life of the axle a little before having to replace the whole thing. The axle joints don't generally fail by themselves - the boot fails first, followed by joint failure under accelerated wear conditions.
Brakes - can't help you there. I've also had four Subaru vehicles, and the brakes have worked great on all of them. If yours really does travel "all the way to the floor," then, as you and I both know, they're not working correctly.
TMPS failure. I'd count myself fortunate! Put regular stems in there and never look back!
i'll just kep it they fixed it it's so cute I really miss it
My buddy needed brakes and tires at 21k miles on his Range Rover Sport and it was over $2k!
Some of the things are know issues - ie: wheelbearings, and some of the things are wear and tear.
Paint? Yeah - the front of mine is chipped and looks like it has been sandblasted with rocks. I do live in New England and commute in some of the worst weather.
Windshield - replaced when hit by a rock from a newly paved highway. Chipped it a week later on the same spot. FWIW - every Subaru I have owned has had a windshield replaced at least once.
Brakes and Tires - two sets, not bad for the mileage. And depending where you live, the aluminum rims are suspect to leakage. I have had all four tires popped off and re-sealed, along with the stems because the road salt got into the beads.
Other repairs - various sensors, intake manifold gasket and wiper motor totaling about $1200.00 out of pocket after the 100k warrantee was over.
Yes, my seat creaks and my dashboard squeaks, but given total cost of ownership over the years - and the enjoyment this car gives me, the car is worth every cent!
We have a 2010 Mercury Milan and it gets the same treatment. Also have a 2013 Outback 2.5i Premium. Very good brakes with a firm pedal and little travel. CVT whines under acceleration but I was told that this behavior is normal. Fairly good on gas but I was not expecting Prius like fuel economy either.
Body panels fit together nicely and the gaps are within 1mm of each other.
I've driven a 98 Accord for the past 5 years b4 it (245K mi & still running
Heck, the new Fb25 engines Subaru has puts the filter at the top of the engine so it would be no comparison. Also 7500 miles vs 5000 interval for the Sienna.
The first time it occurred, I had just pulled off the blacktop and onto a small, washed out dirt path for a little off-roading adventure to an abandoned bridge near the highway, so I thought maybe I had picked up something in a tire (and was none too happy with myself), but after stopping and inspecting, the tires were all fine (rears were still at 45 PSI, right where I set them).
I started out again, and, after ten minutes on the highway at 70, the light re-illuminated. After that, it recurred the same way any time we were on the open highway in 90+ heat.
Regards...
