A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
The dealer has determined that the allignment was very bad on the read and somewhat bad on the front, a situation that came at delivery. They have replaced all 4 with identical tires. Thank you to Subaru for standing behind their product.
DB
I drove it on a long (3300) mile road trip this fall and notice that it got remarkably better miles per gallon than it had been getting on similar roads at home. I attributed this to the learning process and I would like to keep the car's IQ in the upper range.
Does anyone (Craig) know what's really going on under the hood?
DB
I have had the Nokian WR on a Ford Windstar for 2 1/2 years now with maybe 30000 miles on these tires, run all year round with Wrs, have probably half tread still. they did seem to wear rather quickly the first year then settled down.The Windstar is obviously a lot heavier than an OB!
I have the older NRW on my Legacy for winter only and they still have half tread after 3 seasons.
Have just put WRs on the Tribeca, too soon to tell.
I had the CS on a Winnebago for 2 years all year round, those wore a lot in the first year (it really freaked me out at first) and then seemed to slow down. Seems to be a peculiar trait of Nokians.
I think if you drive them till they are down to legal minimum tread, they probably will last 50K if you are not a "rough" driver. But they may not be adequate for snow travel before then. Hope that helps.
They are not as good as hardcore ice tires like Blizzaks in winter but are far better in the dry and in the summer are very decent compared to stock all seasons.
way to go Subaru!!
or maybe this is old news, so why is it on the radio waves today??
The only learning I am aware of happens in the transmission and ECU (engine). The transmission will tune it's shifting style to match your demands, though it's less of an issue with the 5EAT and it's many modes. The engine's ECU varies timing depending on driving style and fuel. It tries to advance the timing, but backs off when knock is detected. And that's where premium fuel helps. From what I understand, the ECU attempts to make the timing adjustment frequently while the engine is running (probably every few seconds or so, but I don't know the exact interval).
On the WRX, there was a well known way to trick the ECU into maxxing out the timing -- it involved a reset, and then gently boosting the turbo while in third gear with the e-brake set (this just happened to be a safe way to do it, nothing magical about the combination). The other way was to immediately drive it like you stole it. Both of these tricks would only be sustained if you ran premium fuel in order to support the advnaced timing without spark knock. If the engine knocked for any reason, the ECU would retard the timing.
Craig
One other thing to note -- though I have new crossbars, the ski fixtures are about 15 years old. I imagine you have newer ones? Maybe there's a difference in the styles.
Craig
I need a new car to replace the 98 GT and which my daughter can then use in 2 years, would prefer a Legacy with VDC which doesn't exist. So if I go sans VDC its a 4 banger, no way is she getting more than 10hp/year of her age! Which is why she ain't getting the WRX! Besides her cello don't fit in that anymore anyway!
The WR's are expensive enough where I would not buy them as winter snow tires, I would run them all year round. I had not heard much feedback on the tread wear rating of 50K and whether that was realistic or not. Most people seem to use them as winter tires and I am not sure I can justify the price. On the other hand, I am not real crazy about the handling of Blizzak's on dry roads. In Minneapolis the majority of winter days have clear roads with plenty of bad days intermixed.
Thanks again.
Karl
The Miata's is side mounted on the side of the engine block (worst place possible for it) so I use a diaper, of all things, to catch the oil that inevitably spills out.
-juice
Man, the Subie was a rock. I have only been living in the midwest for a few years, and we've only had the Legacy a few months, but that was definitely the most comfortable I have ever felt driving in snow. And that was even with the somewhat lacking RE-92s.
I realize that it doesn't help you stop, but even just getting started on something slippery and having stability when driving over sub-optimal surfaces was so much easier.
I have been following the snow tire thread, I am thinking about trying to score some WRX/Legacy wheels off eBay and putting snows on them, just to make sure the car has every advantage possible.
I really can't get over the difference between the Subaru and our FWD car.
205 55 16 Michelin Artic Alpins w/ approx. 4k mi
$395.00
I just got a 05 GT wagon and 16in rims will not fit!!
MSRP is $23,200 (has a few trim options), and I was offered it for ~$200 below invoice, or $21,050. Deduct the 1K rebate, and I would be at $20,050.
Can't argue with the price, just have to check it out to see if it offers exactly what I want. Other problem is that the one they have is not a color I like (black, I wanted blue).
Will go take a closer look on Friday and see how it feels.
-juice
JC
I didn't actualy make the deal as invoice - anything. A friend had gotten that offer (the 2%), and they said they were doing the same for me.
In any case, I know the MSRP and the selling price, which is just about 2.2K below sticker, before the rebate.
I don't care what they say it is as related to invoice, I just care that it is a good deal that satisfies me. But, they sure ain't making much on the deal, but they made the offer to me, so who am I to argue.
When the ECU is reset, there is no historical data so what it learns becomes it's current setting. Immediately after the ECU is reset and the engine brought to operating temperature, it's primed to "learn" as much as possible.
By subjecting your car to a load at not-too high of an RPM, the ECU will try and deliver as much power as possible by advancing timing. With the turbo cars, ECU is able to produce maximum boost in gears 3 and and above, hence the process mentioned with the WRX.
I've tried it on my Legacy GT and it really does work. In my case, I manually chose 3rd gear on my 5EAT and kept the engine at around 3-4K RPM going up a hill.
Ken
Pretty cool.
-juice
I did a test with the balance and fader while listening to 'walk the line' While moving all sound to each one of the speakers, I was amazed that ALL bass came out of the front right speaker. Absolutely zero bass in the other 3 speakers.
Has anyone else noticed this or is there some setting I need to make?
They particularly liked the GT, big surprise there.
I know Subary's NAV costs more, but the integration is worth the price for me.
Anyone knows if it is possible to order and install the Subaru's GPS unit on the 2006 Outback 2.5i Ltd?
Where do I look for it? What parts do I need to buy? Does anyone has the service manual to tell how complex is to install myself?
On the 2.5i SE, they are not, so you could fit any in-dash unit that is DIN or Double-DIN sized.
-juice
You'd think it'd be easy but apparently it's not.
The advantage of the aftermarket units is that you can take it from car to car (especially useful if you travel and use rental cars) Also you can preprogram routes on your computer and then download them into the nav. Much more cumbersome on even the best built in nav systems out there (of which Subaru's is not- IMHO)
Plus, it's much less expensive.
tom
I did see one custom solution in a Forester, they used the storage bin at the top and made a surround like the one used for that optional guage pack.
-juice
tom
Is there at least an easy way to get a power outlet installed inside the "dashboard storage compartment"?
Can I do it myself?
I was thinking with an outlet in there cable mess could be minimized.
Mark
One issue was getting clearance under the wheel, for sliding in and out, but I think that was mostly because I had the front of the seat all the way up when I finished the ride.
handles real nice. Non of the front end sliding you get used to on an FWD car. Very responsive too.
Seemed to cruise nicely at higher speeds. I hit 70 on a back road (didn't mean to. Honest), and it was very calm. RPMS seemed to be at about 2,800 at 70, but it was a quick check. Certainly more relaxed than my Scion.
The shifter was a bit long in the throws (especailly over to 5th), but I plan to get the STi shifter if I get the car. Played with one in the showroom, and the shift pattern seemed nice and tight and precise.
Good visibility out too, something else I'm not used to with my tC.
now just have to decide if it is worth the $$ to move from my tC into a new set of wheels.
At least the price (19.8k for an SE 5 speed) is attractive.
To briefly recount: I had tried Goodyear TripleTreds and found the ride to be jarring. These were then replaced with Goodyear Comfort Treds. Much softer ride, but the car was much less responsive and not as much fun to drive.
I have had Bridgestone Turanza LS-Vs put on and this is combination that I've been looking for: better wet performance, fantastic handling, and the ride is nice as well.
In my earlier posts, some recommended the Turanza right off. Thanks to these folks - it was those recommendations that stuck with me and moved me to the Turanza as the likely tire for what I was looking for.
Hopefully my tire test drives will benefit others looking for a great tire for the Outback.
Glad to hear you like the Turanza's....we still can't get over the improvement from the original Potenza's. We really are enjoying our '05 Outback Limited and have had zero problems in the first year of ownership.
We intend to keep it for many years...hope it is as reliable as the previous '97 outback.
Doug
Daily commute 30 miles highway averaging 75-80mph/5 miles local roads
California gas
-Summer average: 23-24 mpg, best 26 mpg
-Winter average:20-21 mpg, best 22 mpg
Ken
Any real world results for a non-turbo stick shift (if anyone actually owns one of them!) regualar sedan?
26-27mpg at 55-65mph
Back to square one. I guess this means no GPS for now.
Thanks for the suggestions any ways.
It all depends on where you live. Will it make a difference? Yeah, probably. Do you need studs? Probably not. I have never had an issue with an AWD Subaru with snow tires (non studded). I have never come close to getting stuck. I also haven't driven in 20 inches of snow however.
Many places studs are illegal.
My opinion, not knowing where you live: If you are concerned, get a good set of snow tires and call it a day.
Studless snow tires are TONS better than the best all-season.
~Colin
