2000 Sierra Vibration Still??
I am about to place an order for a 2000 Sierra 2WD
Ext Cab 5.3L 3.42/open differential rear end. Am
told that it should take 8-10 weeks to build. Has
GMC solved the past vibration problems by now with
factory fixes? If not should I wait for a while
till the engineers get it solved there, instead of
doing dealer re-fix?
I understand from past posts at this site that the
vibration is more common/likely with ext. cab.
Should I go for the 3.73 rear end, or would I be
able to tell the difference from the 3.42 with the
5.3L V8?
5.3L V8?
2WD or 4WD?
- Tim
The ingredients are too worrisome for me, especially the two piece drive shaft. But other items are suspect also, including the B8 hubs, rack and pinion preload, P255 General tires.
I thank my lucky stars every day. The truck I chose, a regular cab, Z71, 4WD, 4.10 axle is probably a horrible sounding choice if all you need is a 2wd truck that loafs comfortably down Texas highways at 20 mpg. But having said that, the combination of shorter wheelbase, one piece driveshaft due to 4wd transfer case, P265 Firestone tires, 4.10 axle, and recirculating ball steering gear has been utterly smooth and vibration-less at any speed for me through 12,000 miles.
Would love to stop reading these vibration posts however, and have someone say how wonderful the rack and pinion steering is. Oh well.
I have a requirement for the ext. cab. I will be ordering the truck, so there is no opportunity for a test drive before the sale. Looks like I will have no choice but the 2-pc driveline, unless I go to another nameplate other than GMC/Chevy.
Thanks for your input!
You should be able to drive it when it comes in before you buy it.
I drove mine about 10 miles 2 days before it was sold to me.
Good Luck
- Tim
- Tim
If Toyota's vibration problems were five times worse than GM's, you'd still read just as many reports about vibration in GM trucks as Toyota, since they will outsell Toyota 5:1 if both meet their sales objectives. Put another way, if Toyota's vibration was no worse, or the same as GM's, then GM will be penalized with 5 times more complaints based on sales leadership alone.
Hope this helps.....
Steve
I don't have too much data so far, but noone who has had Michelin tires seems to have had a problem. Thanks.
It would be interesting if anyone who fits this description can possibly not have the symtoms?
By-the-way, when they changed out the drive shaft intially, it came off a GMC (1999 I believe). So that means that the shaft from the GMC was bad also. Manager says they're the same.....
Well anyway, guess I'll see what happens with drive shaft work.....
Anybody with good info, please post.
Just kidding, sorry to here you are having trouble with your new truck. Please keep us up to date on your problem. Since my truck is being built in a few weeks, I hope to hear the words, "They fixed the problem" on your next post.
Good luck,
Mike
Anyway, I waited to buy 2000 problem because I've been reading all the vibration problems in 99s. Funny thing is, my best friend went ahead and bought 99 model and his truck is fine. He's laughing his a@# off at me now. Four days in shop, but I'm not giving up on Chevy--always loved them. Hopefully they will fix problem before it's time to trade in. Let me know if anyone has any advice or info I have missed.
John
John
What about your friend who bought the '99? Is his 2wd, extended cab.
Friends truck is the same but 1999.
chevy4me: vibration is very bad when towing trailer: steeling wheel, cub holder, seats, dash, everywhere. Usually occurs at all speeds when towing trailer (dash vibrates so bad I can't hardly read the clock). Vibration not as bad when not towing but still occurs at 70-75 mph, but not as bad.
Dealer on 9-1-99 adjusted "driveline angle" of drive shaft but did not do any good. Now he thinks it's the tires (Goodyear Wrangler) and will replace front 2 next week.
Personally I don't think it's the tires because, according to service manager, he tried another set on lot and the same thing happened.
Any ideas or solutions I can suggest to him?
So far, according to my very un-scientific methods, it still seems to me the highest probability for getting the driveline vibrations, or steering shimmy is on a 2wd, extended cab, 3.42 axle, P235 General tires. It might not be one thing, but a situation where several things conspire, or add up.
My 00' 4.8l, 3.42 Ext. cab Sierra is being delivered next week. I will definitly drive it for 20 minutes or so before signing ze papers.
I'm hoping the all goes well. Anyone have an idea of how to test for vibration on a brand new truckwith no load?
Long story short - the 8 ply goodyears and steel rims result in a rock steady truck at all speeds, this is the first day with them on - so far I really think its fixed the intermittent vibration. It would seem the heavier rotating mass has cancelled or nullified the slight driveline vibration.
I did a lot of reading before I bought my truck and you would be suprised to know of the problems other manufacturers are having with their trucks. There is a mysterious wheel vibration on some of the Tundra trucks when accellerating. My neighbor is trading in his 98 F150 because of massive reliability problems with the transfer case, and the suspension. I think these things just happen to a percentage of vehicles.
It probably comes down to a crap shoot. You either get one that works or you don't. If you don't, you have to get it fixed. Then it's on to the next thing.
Steve
end and 4.8L engine. After sending it to the
dealer service center 4 times for vibration et.al.,
I began to investigate the highway speed
vibration. My opinion is that the truck frame is
flexing to a point where it is causing the bed of
the truck to move up and down causing
reverberations from the bed to the front cab. I
noticed this by viewing the bed of the truck in the
rear view mirror while driving at a constant
highway speed of 70mph on an open highway. Adding
weight IN THE CAB (~500-600 lbs.) seems to make a
big difference as the bed does not appear to bounce
up and down, almost like it stops the frame from
flexing therefore reducing vibrations. All of us
with this problem should verify and report results.
I am not an engineer but do know about chassis
bending moments on tube steel. I will be taking my
truck to a chassis shop next week and they will run
truck on a drum driving device to simulate driving
conditions at various speeds. Only costs $42 so I
feel it is well worth it.
Jeff
Jeff
In the back, there is no camber, caster, toe etc. In the front, linkages everywhere.
Jeff
Said this before, but the test road has to be perfectly smooth. Sometimes we get used to a road, and for us it becomes our benchmark, whether deserved or not. A little undulation can cause hobby-horsing, or pogoing action of the suspension.
Then again, I said all that because I made a connection to what you said, that it feels like its transmitted from the back to the front. You may be right, could be 2 distinct concerns....but much vibration at the rear seems a stretch unless it is wheel balance related.
who are having the most problems with vibrations ?
I believe the real problem is rack and pinion, while improving steering feel and feedback, is too sensitive, and has insufficient damping.
My 4wd doesn't have the vibration or R&P steering box. But if it did, the solution I'd look for is to install a steering dampener. Good luck!
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
