Mack
There are two settings.
Setting 1: the default is open the drivers door only if you touch the drivers side front door handle and open all doors if you touch the passenger side front door handle
Setting 2: Open all doors when either front door handle is touched.
Page 37 of the 08 HL Owner’s Manual
Switching the door unlock function (open all doors or just the drivers door)
It is possible to set which doors the (Smartkey) entry function unlocks
Step 1: Turn the “Engine Start/Stop” switch “OFF”
Step 2: When the indicator on the key surface is turned off, push and hold the “Unlock” button and the “Lock” button together for approximately 5 seconds.
You will hear confirmation beeps when the setting is changed.
The SmartKey settings toggle each time this operation is performed.
Soooo... you can do this and try it and if you don't like it you can change it back.
New Highlander Buyer
ET
But I don't think the ODD can be changed as this is part of the security system
However the dealer should be able to help
If that fails Miles / .6 Have a good trip
2003-2007 TOYOTA TO AUXILIARY AUDIO INPUT
Product Code: TOY03-AUX/S
http://www.pie.net/pie_store/shopexd.asp?id=646&bc=no
Also, is it easy to install?
http://www.ancoauto.com/oscommerce/product_info.php?products_id=159
Don't forget you need the harness also, also for sale on the same page.
The toughest part of installation was removing the panels to get to the radio, but it is doable, just be careful.
ET
You have to press the info button on the lower right side, Select Screen Settings on the touch screen and then change the setting of Transition to NAV screen from Music.etc. Setting.
Hope this helps.
I wouldn't suggest cutting those wires.
ROFLMAO!!!
Also body side mouldings are not available for the 2008 HL in Canada unlike the United States.
I traded in a 2006 Highlander Hybrid Sierra Gold with polished stainless steel step bars and color coded side moulding and mud guards for a Silver 2008 Highlander LTD Hybrid.
Thanks again for your reply.
