Volkswagen Jetta 2006+
Try the old air-cooled Super Beetle. I remember sitting on the high-chair rear seat when I was 6, & my feet could barely reach the floor.
I had a '71 Super Beetle and loved it. Ran it until it just was more rust than metal. Would love a new "old Beetle". Don't like the new ones, they just don't have the same character.
--the new jetta is suppose to have significantly more rear seat room. i think the wheelbase will increase six inches.
Will this make it by 2005?
~alpha
One of my least intelligent transactions was trading in my 1964 VW Beetle on that 1970 Dodge van. However, winters are long and cold in northern Colorado/southern Wyoming and the VW provided no heat.
The water cooled VW engines seem to last a little longer than did the old, underpowered air cooled ones. On the other hand, Toyota Camry engines last 300,000 or 400,000 miles. I know one man who has 432,000 miles on an 87 Camry.
Oops -- I just noticed my own sin. This is the '06 Jetta discussion, so let's veer on track. Sorry 'bout that.
MODERATOR /ADMINISTRATOR
Review your vehicle
That's why the vintage VW I chose to collect & restore is the 18-cu-ft-trunk '84 Jetta Wolfsburg coupe. See my profile:
http://townhall-talk.edmunds.com/WebX?viewUserProfile!vuserName=c- - - - - - reakid1
But since the early '90's, the Camry's exterior got bigger w/o really increasing the wheelbase so therefore only slightly roomier than the already-impressive huge old interior. But the Jetta kept shrinking, especially the present Jetta IV.
alpha01, since I missed our short-exterior white-w/-grey-cloth-interior '83 Camry LE, I ended up collecting a white-w/-grey-cloth-interior '93 Camry V6 SE sedan for it's stereo sound quality, but that bulky exterior, turning radius & higher-belt-line lateral visibility just doesn't feel the same.
Still, these Camry's inferior steering & shallow suspension just can't match my Jetta I's chassis invented in the early '70's! Even today, the only thing the Camry excels is the quietness, & the '02's new platform doesn't ride so shallow anymore.
By the way, I bought both of these used cars the same day in March '02, & they're both white.
"And the electric power-steering works well with the chassis, delivering remarkable feedback."
No kidding!
i think that's been the general consensus but hearing it from a VW official sort makes it fairly credible.
Make it an option for people that want it.
I also wish they'd make it an option instead of standard. Heck, I'd pay money if it were additional cost to have the control manual!
Review your vehicle
When I use auto climate control, I have to set it at the lowest temperature, at a low fan speed, then turn off the A/C, & only intermittently turn on the A/C(usually during deceleration) when the temperature isn't cool enough.
The nice thing about the manual climate control w/ at least 2 stages of A/C setting is that you usually set it(& forget it) at the "econo A/C" semi-cold setting that's comfortably cool w/o the smell from the heated air. In case you need to apply additional braking force from the engine, you can always turn it to full A/C. Or for instance you're using the full A/C on a hot day, & suddenly need the max engine power for the next several seconds, switching from full A/C to econo-A/C will take care of the it but still revert back to turn on the compressor afterwards in case you forgot to so your hot date won't complain...
We got a good discount deal on a dark-blue sedan at just under $10k out the door in S California.
I am currently attending West Point and won't be able to get a new car for another 3 years (we're not allowed to have cars until our senior year) and I have always liked Jettas and was planning on getting one but now I just don't know. I might have to look elsewhere. Ideally I'd want a BMW 330i but those are expensive...
Take advanced driving lessons, be careful, or buy the Jetta- and still be carefull!
I put over 170,000 on a 1980 Scirocco, with no major problems, and that vehicle was probably not as reliable as the current VW's
In addition:
-Climate Control
-"Park" setting for winshield wipers to keep them from freezing to the window
-Full function compass
-Sunglass holder in roof
Sylvia Nov 24, 2004 10:43am
If you have some information, please let us know! Posting a comment about the new Jetta is the best way to get the conversation going.
Review your vehicle
I am planning on buying a car in the Spring (2005) and probably will compare the new BMW 3 series, new Audi A4, and the new body Jetta. I wonder how they will compare (e.g., size, hp, etc.) Anybody have any idea?
Okay, imagine an AWD Jetta...
you can also go to a more direct source for information at www.vwvortex.com
the redesigned model is actually going to still be a 2005 model apparently.
Review your vehicle
Find another catchy song for an ad, lessen the breakdown horror stories, and the Jetta could be off.
psryan that's nearly a $10,000 spread... you should narrow down your budget, and do look at the other options within your final price range. They should be similar in size (A4 the smallest I think?) and in power (if you're comparing the Jetta's top engine with the A4 and 3's lower-power choices). But the Jetta, A4, and 3 are FWD, AWD, and RWD respectively so they'll all drive pretty differently when pushed hard.
Was a rattle your only problem? You did mentioned huge problem so I assume this was the one that irritated the most.
I've been fighting rattles in my Honda for 40K miles (each time they can't fix it).
I'd be jumping up and down with joy if they gave me $800 for that problem; I'd head down to an independent garage and have them look at it.
The Corolla should server you well.
1. The New Passat. The pricing of the Jetta will be CRUCIAL. Anyone with more than $20k to spend on a VW will definitely be swayed by the sexy ways of the new Passat over the homely Jetta. Anyone buying a $21-25k Jetta may need to buy new and improved taste buds for 2006 (with a value calculator as well)!
2. The 2006 GTI. Another future grand slam for VW (dependant on pricing), is a sexier two-door with sharper eflexes and more room. The Jetta maybe the "Redheaded stepchild" in this triumvirate (sic). Good Luck!
Very poor product lanning, oh bye the way, by VW. Why release all three so close together? It's not like they sell 20 vehicles! They sell a handfull. NOw they al get hot at once, and then a cold spell could last for years (like it has since the current Passat's cooldown). Talk about destined to relive history.
DrFill
The new Jetta is a gorgeous car. It should have a low enough base price to be competitive in its segment. The high end Jetta, with a 200 hp 2.0T, price should bump close to the low end Passat. The 2.0T is the same as the one offered in the low end Passat and it's based on the same chassis.
People wishing for the higher end car, but with fewer options would then have the option to choose the Passat. I think they're trying to cover all the gaps in their product offering.
GTI, don't see how it will affect either (Jetta or Passat).
Released all at once; ideally I guess it should be staggered, but all the models needed replacement. They will also be releasing wagons at a later date. The next cycle release should correct this; or they could have significant mid-cycle changes to stagger the next round.
the new golf may be a hit with hard core VW fans but will as always be dwarfed by the sedans in sales.
As long as they don't drop the ball on reliability, it should be a success.
New Jetta
New Passat
New GTI
