Summer Gas Mileage Arizona
I have lived in arizona for over 3 years and noticed when they put the summer gas in my mileage in all my cars drops drastically. Mileage drops from 3-4 mpg in all cars. Please let me know if you have experienced this and what your mileage is in the summer her in Arizona
My guess is the biggest problems with his summertime fuel economy are the reformulated gas (they use that in AZ?) and his use of A/C, which a lot of folks forget to consider. An A/C compressor really sucks power.
The air loses density 1% per 333 feet AMSL and 1% per 11F these are additive vs 32F and SL......at 5,000 feet engine power is down 15%........in 110F engine power is only down 5% from SAE rated 60F.
However most/all ecu have a summer protective mode where the coolant temp is monitored and the AC ON signal is considered........ignition timing is reduced and fuel is enrichened [to cool cylinders] to protect the engine above 195F coolant sensor reading.......this has at most a 10% effect.......but may be additive to air temperature.
Each manufacturer is different as to how exactly they attack these problems.
Wow. So I guess in a very slight way a FI engine could actually use more fuel than a carbed engine in extreme heat? Of course, it's nice not having to listen to that carbed engine ping itself to death, huh?
