2000 Chevy Silverado vibration
espdixie..you are right, vibration problems. So why did you post the last message?
Have a nice day.....
Well, I just posted about Doudis' good news and my order, then scrolled down to this post and see 6 more posts supposedly about Chev and, therefore, GMC vibrations.
But it turns out to be nothing at all about vibrations (sort of like that famous topic "Silverado Frame Failures"). Meanwhile, I've had heart failure believing that a topic about vibrations is really about more shake, rattle and roll, not about Doudis inadvertently stirring up a hornet's nest over too much enthusiasm over his new baby.
Perhaps we should all chill a little except me of course since I obviously have a perfect right to pace the floor and chew my nails hoping that my new truck is as good as the one Doudis seems to have.
As I've said before, it is not the wait I mind as much as the worry about quality.
The tow/haul program/feature is the only thing that hasn't been checked on my truck for towing vibration. Anyone know how it's connected to tranny, etc.?
Thanks John
Anyway, I'll play with the tow haul button tomor. and see is anything changes. I didn't think of tow haul problem until I finished towing.
Thanks for info. again........ John
I'm still vibrating at 65-80 mph, appears dealer gave up on fixing, got a BS answer and they performed no work last trip.
Called 1-800 Chevy customer service and opened an official case with them to get into buyback mode. They were supposed to call back and didn't. Called them again 10 days later. Nobody did anything with my case, just left it out there with absolutely nothing done on it. Same Old Stuff.
Thanks in advance,
Ken
I can't find the # for GY but it was the 1-800 Customer Service #. I spoke with several people and amazingly enough they all knew about the problem and explained it to me. Gm changed the spec in Oct. 99 so all tires before then probably will not solve a vibration problem. That explains why all the guys wiith '99's that have had 4 and 5 sets of tires still have the problem. If I were one of them I'd go back and insist on tires built after Oct 99. It seems to me that if GM changed the spec they are admitting the original one was inadequate and they should replace them. I now have about 700 miles on mine since they were replaced and all is well. There is road feel on certain surfaces but overall the problem is solved for me. The guys that have had tranny's, driveshafts, etc replaced are still likely to have vibes if they have the GY's built before OCT.....that explains why they do!! My dealer has been wonderful throughout this and the Svc Mgr has even been to a Silverado Vibe Class!! You are correct...my originals were date code 409 and the new ones 459...five weeks later!! If you can't get ahold of GY get back to me and I'll dig some more....I got the # from my local GY Store.
espdixie
Ken
Talked to Chevy Customer Service to get a status of my complaint. I was told Chevy has cancelled the buyback program for trucks because it is not a safety problem and will cause no abnormal wear on the trucks. Chevy says their technical assistance is working on the problem and are working toward a resolution by the end of March.
I think they've been working on it for about 19 months already, what makes them think they can fix it in another month or two?
Looks like we're hosed again, because folks were letting the dealers try to fix because the buyback was always an option if they failed. No more.
I am aware that the Generals also have the problem!! BUT...on 2000's General is no longer a supplier for the 235 x 75 x 16's that are on my truck so it wasn't a player in the conversation. When someone refers to a spec that refers to a general soec for all tires...it says that the tire has to be within a certain roundness and sidewall firmness/hardness. GY is the ONLY one that has built tires to that spec at present. Prior to Oct it was possible, but not likely that any tire met the new spec.....because the roundness CAN be effected by frequency of the mold being cleaned and other human factors. GY didn't, nor did I, say NO tires prior to Oct met the new spec but rather that ALL tires after that did.....understand now? While I was waiting for the replacement tires I spoke with GY, Micelin, & BFG and ALL of them said that currently they had no other tire that was suitable for the new GM spec on the 2000 Silverado. I asked GY about upgrading to one of their better lines and they said they didn't recommend it. If you read the article on the DUNLOP HOME page on troubleshooting tire vibrations you will understand what the problem is. It is NOT defective tires it is tires with heavy and/or light spots in the sidewalls that are not mounted to to the proper relationship with the wheel. If a tire is real consistant it is much less of a problem than with one that isn't. If you are lucy enough to get a tire fresh out of a clean mold then you might be ok.
espdixie
I will still contend that the vibration is caused by some design or manufacturing problem, not the tires, although I will admit that by getting "perfect" tires helps the situation alot, maybe to the point of disappearing the vibration. The real problem is that the truck is way too sensative to the tires, because all the other vehicles on the road manage to get a smooth ride out of wide range of standard production tires. Even though the vibes are fixed by perfect tires with perfect balance, I believe the vibration will return as soon as the tires wear, since all tires wear unevenly and somehow get out of balance. What would feel like a slight out of balance condition on another vehicle will feel like a major one on these trucks. That accounts for the reports that after tires and balance, the vibes disappear for 300-500 miles, only to return. Other vehicles will run smooth for a few thousand miles before needing to be balanced.
If you accept that hypothesis, Chevrolet is barking up the wrong tree with the tires. They're treating the symptoms, not the problem. That will provide some temporary relieve, but it's not permanent, and not the fix we deserve.
Anyway, whatever the problem was it sounds like the measures taken in October 1999 corrected the problem.
By the way, I've got about 150 miles on my replacement tires (GY Wrangler STs), and haven't noted any vibrations yet, but continue to monitor them closely as they were made the 12th week of 1999.
Ken
NO MORE SHAKES, PINGING ENGINE, HARSH SHIFTS....
Thanks John
(I gave them another chance) after I won my NY state lemon law case on my 86 pickup, then ordered a first year run of 88 1500 Ext. Cab that took 17 weeks to obtain. Iv'e had that till I ordered my Y2K 2500 2WD
No Regrets on that purchase in 88.
Ray T.
Anyway, it's a problem I can live with right now. According to the dealer, the new leaf springs that corrected the 99 launch shutter, doesn't apply to 00 models.
Thanks ... John
Cam
Ray T.
I'm looking at the 2000 Silverado, considering the 2500 excab longbed as a tow vehicle with the 6.0, man trans, 4.10 gears and 2wd. It looks hard to beat from the sales literature.
Thanks for your input.
Cam
Whatever it is it does not sound normal from your description.
Ray T.
Does anyone know the filter number that is the anti-siphon one????
Cam
