WHITE PAINT PROBLEM
I have a 2000 F-250 SD Crew Cab. It is a Lariat model with white paint over the gold trim. Just recently I washed and started to apply a coat of wax. I noticed pinpoint sized rust colored specs all over the vertical surfaces. I didn't see any on the hood or roof. The specs will rub out with a lot of manual effort. Has anyone else had this problem or know the cause?
The best removal method is by using a clay bar. You can find it at most auto parts stores. The one I use is called Clay Magic and costs around $10.
Simply spray a small section of the vehicle with the soap solution provided in the kit and rub gently with the clay bar. It works wonderfully!
Best of luck!
Do Ford trucks have rear discs?
I have had/have several white Caddies and never noticed.
All my trucks are black tho...and are a PAIN to keep nice!
Chris is right though, the clay bar treatment is the way to go to remove the paint imperfections (whatever they are). It takes the surface contaminants off, but doesn't impact the clearcoat and paint. Just be advised, for a crew cab you better block off a whole weekend to if you want to do the entire truck. :-(
Since my truck is a '99, rail dust is not the cause. I thought the same thing about one of my rotors being eaten up. But a thorough check of all four revealed no clues. The vast majority of mine came out with a moderate wax job, I'm sure the rest will when I wax it again. Funny thing about those rust spots, they go away if you don't look too closely! ;p
