Nissan Quest 2004+: Problems & Solutions
My wife drove our new Quest with the Parking brake on for about 6-8 miles (at ~50mph). According to her, it was ok below 40mph but once she went over 50, she got a clunky noise in the engine (obviously). Anybody knows if this will cause any short term/long term problems?
According the specs, while the door is closing, when you put an object or apply a force in the opposite direction, the door is supposed to open automatically and should not close all the way. It works fine when the door is about 8 (or less) inches open before it fully closes. But the first problem is when you apply the pressure earlier (more than 8 inches open) it does not work. It keeps closing. I think it should open automatically at any point when there is a pressure in the opposite direction. The second and more serious problem is that while the door is half way or more open and when you put the pressure and keep the pressure on, it keeps closing all the way!!! I tried it several times and it did the same all the time on both doors. I put a medium pressure with my hand and pushed it the other way. It keep closing all the way till the end and I had the pull out my hand just before the door fully closes. PLEASE BE CAREFUL WHEN YOU DO THE TEST, THE DOOR IS HIGHLY LIKELY TO FAIL AND CAUSE A SERIOUS INJURY.
Next, I will take the car to the Nissan service and keep you updated on this issue. Please let me know if yours work fine or if this is how it supposed to work in general with power sliding doors.
There is no pinch protection in the power windows the windows will automatically go up and no force will stop it, so be very careful when kids are around, Nissan should fix this, i don't know it is a problem in my van or a design issue.
can some verify one touch power window up function and check pinch protection. does window come back when you apply reverse force on it?
Great vehicle to drive, but all the little problems are driving me nuts. When you spend $40k on a vehicle, you expect to do nothing except basic maintenance for the 1st couple years. Mine has already been in the shop for 6 or 7 days w/o many of the problems fixed. Don't know what to do at this time.
Apparently, the problem is not wide spread as I have seen no other posted comments.
I went over a bump or rough spot in the road, it sounded like the door was bumping up and down; as if it not properly seated.
I have not as yet taken it back to the dealer. I'm waiting to include it with some other minor items on the 1,000 mile check.
The car is extremely comfortable but I am very dissapointed in the quality.
Anyone else having these problems?
you indicated they admitted this is an emerging problem area, and in a previous post, a fuse blew when opening one of the doors. Seems somebody should have more information on your problem. you should not have to guess what is being protected by that fuse. Nissan should be explicit with you.
in the spirit of cooperation, i'd inquire if it would be OK to lower the amperage rating of the replacement fuse. if it is currently 15A, i'd be hesitant to be doing continued "monitoring" (that's funny) using anything but the smallest amperage fuse possible (say 10 or 5A) to support those functions. how much current is drawn by 6 or so interior mini-lamps? have them calculate that total for you.
Geesh.
fuses blow because a circuit is sinking too much current. the fuse protects the circuit and the rest of the system by melting under high current flow conditions and opening such that the current can no longer flow.
i am not an expert...but i find it hard to believe any "memory functions" or interior lights draw much current at all, let alone anything close to 15A.
so anyway, i'm thinking you and your investment are safer and also you're more likely to incurr repeated fails (and thus determine causality) if the rating of the replacement fuses is smaller (maybe 5A). if the event is transient, then a smaller rating fuse isn't going to have the (don't know the term - i'll say ride out) capability of a larger rated fuse, so it will be prone to blow which in your experiment is GOOD.
anyone?
FWIW, I imagine some company produces a device that actually does monitoring of current/voltage...a real-time sampling system, that when it detects an uptick in current flow, or say a droop in voltage, starts sampling and storing date/time and measurements at a rapid pace. with it, one could determine event duration, magnitude, frequency, periodicity / aperiodicity, etc etc.
Tell Nissan you want them to research that and put one of those in your car.
Not to make you paranoid, but if it was me...
...this car would not be parked in the garage until the source of the problem was determined and corrected.
Something is sinking a good deal of current. Maybe (hopefully) you've got a bad light recepticle which is shorting to gnd, or across/around the bulb.
Let's say you can go with a smaller amp fuse, then i'd see if they blow with any frequency when a door is opened. i'd also try wiggling or tapping each light recepticle one by one with all lights on to see if the fuse blows.
good luck.
Any ideas on how to effectively make this puppy be quiet? The wonderful engine is virtually silent, so these other sounds are complete intrusions.
Also, any idea whether insulation can be sprayed in the sliding door cavities to quiet the rattles and squeaks from them? And what about undercoating to silence the excessive road/tire noises.
Today, I went to work with my Honda Civic. It is very interesting that the same thing happened again. When the Civic passed 30 MPH, I heard the "wind noise" on the "new constructed, smoothly" cement road. But the noise disappeared under the coarse highway. The noise with the Civic is almost the same as the Quest (not that much on both case).
Why did I not notice the noise with the 2001 Civic before? I think I did never pay any attention to it and most of the time I turn my radio on. But with new Quest, I paid "too much" attention. LOL.
I did check the air-Conditioned Vent and other rattle noise as well. Luckily, I did not find any problem on my wife's new Quest. I received a call from Nissan dealer yesterday and they wanted me to give the "survey paper from Nissan" to them in exchange of a full tank gas. Weird. They could fill the survey with all "excellent" remarks, I think. However, it seems they do care about the customer's opinion.
Has anyone else encountered this problem?
The engine service light on our 2004 Quest S model came off after 1,200 miles. Does anyone here have the same problem ? Can we reset it ? or we have to take the van to the dealer for them to check ?
Thanks in advance !
Have a wonderful day !
I have the SE and I noticed some rattles inside the van.
As I started hunting them down I was able to get rid of most of them.
First, sit on the 3rd row and notice some of the plastic covers that hide the screws for the skylights are a little loose. These vibrate when the car is moving. There are 4 of these things, one per sky-window. Also, the same thing on the column that goes up into the ceiling (a round lid/cover). If you open these up you will be able to stuff some "filler" inside that will push against the cover to prevent it from vibrating. ( I used paper for this but you can get more creative ... dry silicone?).
After taking care of these, I noticed that there is only 1 rattle left. Its minor and only happens on really bad roads. It comes from the front of the ceiling console. There are some screws there and I might try to tight them up.
I have not experienced sliding door rattles. My Van has two electric sliding doors. Could it only be happening to "non-electric" doors?
The treatment that I did was for rust prevention, road noise reduction, paint protection, and interior protection (carpets, seats). The paint feels so smooth now to the touch and dirt does not seem to stick to it as much...
I paid $895 for it in case you are wondering.
And we also noticed the big noise the rear wiper makes! To add to our vow, we noticed the paint chipping from the front dash! Did I get a lemon?
Don't know if it's the big doors or what, but we all need to start making noise to Nissan so they will get on the stick and issue a fix.
Saw a lot on the issue of unwanted driver side feet heating. Called 1-800-NISSAN1 since the dealer I bought the Quest from (Stevens Creek Nissan) was being absolutely abnoxious. The service professional, Jason, I spoke with claimed that he heard this from only one other customer. He also claimed that there was no official word on this problem. Can anyone comment on that?
At speeds between 25-35 MPH, there's noticeable drag and the gears don't seem to downshift. Did the others with the problem get it fixed?
A couple of instrument panels (radio controls over the driver side sliding door, bottom runners, etc.) keep popping out! Others seen this too?
Finally, mileage does suck (have a bad commute though).
I am looking for a better dealer to take the vehicle to and will post after I get back.
On the plus side, haven't had any problems with cabin noise (could have decent conversations with a full load on the freeway at 80 MPH) or AC cooling.
Vee Gee
The dealer inadvertently left a circuit breaker (rather than a fuse) in the slot. I decided to keep it for awhile and the thing hasn't blown in a week. Hmmm?
We just took the van on an 830 mile road trip--an even mix of high-speed interstates and semi-rough side roads. I noticed no undue wind or road noise (never have) and no rattles. I may have lucked out on those problems but I think the undercoating probably helped to reduce the road noise. Car performed fantastically!--tons of room, smooth ride, great handling, and plenty of power when I needed it. We averaged 24 mpg.
Well after weeks and weeks of reading these posts and doing much research, we decided on the Quest. I just picked up mine yesterday after a long search for the Smoke SE fully loaded. No one has been able to get it here in the bay area for the price I wanted. I got mine for a few hundred over invoice and am very happy with it. It drives like a dream, and everyone who sees it is totally impressed.
My friends that own the Ody., want this one. Everyone so far thinks it is cool and we as a family of 5 are happy. This is our first mini van (if you can call it that). As I said before I did do much research and reading all of these posts have helped.
I do have a few comments. I knew that I might encounter a few problems, but also knew that it would probably be with any of the vans I picked. I do notice the obvious rattle noise coming from the drivers side sliding door. Happens all the time, bumps or not.
I did also notice something strange today. You know when you start the vehicle up, the nav goes on (if you have nav.) and the accept part is highlighted. You can either push the toggle button to accept it and then you see the map as you are driving or you can just ignore it, and it will go away after a few seconds and then just go to a blank screen. Well today it didn't go away. The warning message just stayed on my whole 10 minute drive. Got to where I was going, turned off the car, then started it back up 30 minutes later. This time it worked again, I ignored the message and it went away. Just something to keep an eye on.
I have not experienced any other problems, including the air conditioning issue a lot of you have posted.
I just got out of a Lemon with my 2001 Chevy Suburban and so I am very aware of any problem a vehicle has. Have it all documented and hopefully these are just some minor bugs.
I really do love this van!!
As for hear2ear post....I know what you are talking about with Stevens Creek Nissan in SJ, Ca... I delt with them in August and had a problem with one of the people there in Sept...Needless to say I went somewhere else. I called a lot of dealers in the bay area and ended up with Hayward Nissan. It was a little farther drive, but Shah is awesome there.
He kept me posted on the inventory and never played games with the price. Infact, Falore Nissan upt the price as they said they found one somewhere else, and would have to do a dealer trade. I called Shah and told him there was one in the bay area. He said he would try to track it down, and he did. He faxed over his inventory to them and they wanted a 04 350Z for mine. He drove out to Salinas, Seaside Nissan and got me my van. He called me at 9:00 pm and said he had my van. I went down the next day and got it.
Keep me posted with the door squeek. I will let Shah know and hopefully we can get this fixed. I just crank up the radio!!
My wife drives the van 90% so the only few chances I get it, I try to spend as much time as possible. We did however notice something strange today, something that has been reported on this forum. The sliding doors don't open all the way if you manually open them. They stop after about a quarter of the length. Both of them. But, if we use the remote, they go all the way back. Also, if we use the buttons inside the van (the black buttons to open and close the sliding doors), they don't open/close. Initially I thought it might be because all doors weren't unlocked. But even after that, the buttons did not work. Didn't have too much time to research it today. Perhaps over the weekend.
But we haven't heard any door rattles (we've had the van close to 2 weeks now). And it drives wonderfully. No major complaints!
As for the doors, I guess I haven't noticed the problems you are experiencing. I do use the remote to open and then the kids love hitting the black button to shut the doors themselves. It's like when we are on vacation at the hotel and they fight over who gets to push the elevator buttons and open up the room with the key.
Keep us updated with your door situation. My little black buttons do work. Just have a rattle in the one door.
This van is amazing for those of you out there trying to make a decision.
You seem to have got to the "bottom" of the problem coming from the top ..
Edmunds need to step up and so does Nissan.
I am waiting for my van and should be able to get it this weekend..
vax
This is retarded. Once the warning light comes on that's when you really care about the number of miles you can before running out of gas!!! Please let me know if someone has this issue or not. Thanks.
Problem is that it came on first for one tire and then yesterday all the tires were showing a pressure of < 27 PSI @ cold. We do leave the van outside these days since the garage is sort of cluttered. When the van and tires warm up, the pressure goes up to about 32 PSI. Finally this morning, I topped all 4 tires to 35 PSI (since the gas station is less than a mile away, I am assuming it is cold).
Anyway, does this seem unusual to anyone that all 4 tires have low air pressure? Recommended is 35 PSI @ cold. Could this have anything to do with my drag problem I talked about before in 71?
I am taking the van in on Monday to Falore Nissan and will ask them to look at this as well. I know spoiledleo1 didn't have good things to say about Falore, but I am hoping that was the sales dept.
Will keep you all posted when I get the van back after diagnosis or repairs.
-- Regards,
-- Vee Gee
He said that there is a clip inside the door panel that was broken. He had replaced the clip.
When I get the car back, it was better than before but there is still noise when the car is moving but it is much much less noticeable than before.
After back home, I keep searching for the source of the remaining noise. Later, I suspect the door is not closed properly when in close position. If trying to pull the door by the handle inside, I can hear the noise. There is no noise from the passenger side slider door when pulling the handle from inside. It seems that there is a very very thin gap between the car body and the door but it is not visible either from outside or inside. So when the car is moving, the door is kinda hit the body with the noise.
Anyone have the same situation or not i.e. the door is not close tightly when in close position?
I probably will bring the car to the dealer again (next week or so) and see whether this theory is correct or not.
I have set it for 1 minute but it didn't lock the doors after 1 minute by itself.
If I do not open any door for 1 minute, it should lock all the doors by itself. It is the expected behavior?
Did I miss any step in order to make it work?
Consider the gas warning a conservative estimate and don't expect more than that.
I have noticed the behavior that others reported, where on a warm day, with the a/c on, there is hot air blowing from the front floor vents. However, the volume of airflow is very low, and it didn't bother me. I also noticed that it only occurs when the car is fully warmed up.
To experiment, I decided to override the auto system, and direct all of the airflow to the floor vents. The air volume increased considerably at the floor vents (as expected), and it became cooler, but not nearly as cool as when the air was coming out of the dash vents. I wonder if the floor ducts might be routed near some hot parts that heat the air as passes through.
Last night, I also experienced a different problem. It was cool outside, ~60deg outside temp, and I had the auto temp setting at 72. Well, there was nice toasty air coming from the floor vents, but the dash vents were blowing cool air. I let this condition persist for a while, to see if it would adjust itself, but it stayed that way. The only thing I could do was again manually override the auto system to direct all of the airflow to the floor vents. Anyone else experience this?
Had the same problem.
My Suggestions:
Go with all the details: Let them know that you "know" what costs are. Research Invoice and
MSRP prices..
And if the dealer is rude next time - just tell
him keep ur car and walk out. Call Nissan consumer affairs and give the guy ur piece ofmind. This worked for me too.
Vax
well picked up my SE last morning.
( stephenwb and pulisubs were right about waiting)
dealer called and gave me the vehicle i wanted.
started talking about the review.
One thing - I read and re-read the manual
Is there a way to get hot air from the "console vents" Those vents get cold air blowing.
I guess Nissan trusted the "Hot Air goes up "
and let hot air come out of foot vents only.
The A/c is confusing to operate and I should get used to it over time..
Am taking it for a drive and shall let you know
how it behaves. The small rattle came from the driver side sliding door. Since I had read about it here , I did not panic. SHall make a problem list and show it to the dealer when serviced.
vax
I agree to the suggestion to make some noise about this rattler. I already called Nissan, and they suggested taking it back to the dealer. I am a bit concerned about they experimenting something if they cant fix a manufacturing defect, or applying some glue (?) to stick up the panels. I will post my experience when I take it back.
I do have door noise and warm air issue. The dealer doesn't know much and they called Nissan Hot line. They couldn't help. But said Nissan know there is concern from customers regarding Warm Air issue. They are not working on any fix.
If more customers call and register this issue Nissan might find a fix. So Please call. I have a call open for 2.5 months now.
Vince
I don't want to give my van to the dealership for experiments I am waiting until they have a bulliten from Nissan for the fix, until now the dealersip don't know the root cause.
so please call and get your problem registered. They will give you a reference number. Keep it for your status update.....
So the Quest is to the par of German engineering ;-)
(not sure is that is a good thing... )
> Considering buying a SL with NAV, but Hilltop Nissan
> on Route 10 East Hannover NJ has very rude
> unpleasant manager called Jeff. Pretended not to
> know invoice price and played games with us as ...
It happens even in the best families. There are tons of Nissan dealers in the US. If you do not like that one, go to another one. Bad mouthing them does not get you a better deal.
So my case# with Nissan is 4306098. Has anyone else opened a case# about warm air during a/c? I will test drive another vehicle and probably email Nissan with my results. So send me your case#'s and I'll include them.
I had the same problem with Hilltop Nissan. Do your homework on what you want to pay and present to another dealer. I suggest Route 22 Nissan, Warnock Nissan or Lynnes Nissan. It seems as though they are much more straight forward to deal with. BTW, we are still looking and have not yet purchased the Quest.
