Visitor Agreement.
Any help would be greatly appreciated and if there are any other known issues with this model, do tell.
Thanx much for any help.
Eug65
oh I fogot, my battery light did come on one about amonth ago, we had a freak snow storm and i drove through alot of slush. i shut the car off at work and started it when i left the light went out and never came back on.
again i just love mine, it has pwr and gets up and scoots and it's the 1st purple car i've owned. (thank god i no longer need a minivan) kids are driving themselfs. LOL
Liz
You should realize that the engine has a timing belt that must be changed at 100,000 miles. If the belt breaks the engine will be destroyed as it is not designed to be non interference. Other Xler engines are non-interference. If you are mechanically inclined, it will save you some money to do it yourself but it is not a job for amateurs either. I understand it is quite expensive to have it done by the dealer or professional. At the same time the idler and tensioner bearings should be changed, and the water pump. The theory is that it is an expensive/difficult job to do, so replace it all rather than have to go back in to fix a bad pump or bearing. It really does make good sense. Other than that, I find the car quite reasonable. I have also had to replace the fan thermistor that controls the blower fan speeds and the LH front wheel hub bearing. These are pretty common problems for any vehicle and these items were recent at around the 145,000 mile mark. My son drives the car and likes it. HTH One guys opinion.
What happened? Did the abs kick in when it wasn't supposed to? What is the likely problem? Thanks much. Randy.
My experience with crank sensors is that the engine runs or it won't restart when hot. Not heard of missing as a symptom, not to say that is not possible, I just don't know. This engine is known to develop low oil pressure, best and cheapest fix is to replace the oil light pressure sensor (to be safe) and change the oil to a slightly heavier weight . Not much else you can do. Oil light symptom is more apparent in hot climates or hot running conditions.
