Visitor Agreement.
So far no problems.
If you will read on page 19 of the owner's manual, it says,
"The air conditioning compressor will operate in all modes except (lower vents only) and (upper vents only). However, the air conditioning will only function if the outside temperature is about 50 F or higher."
Thanks for the info, I just passed the 500 mile mark and I was going to start clocking gas mileage. The AC would have dragged that down a bit.
I'm starting to wonder if I'm missing something in my owners manual package. I looked carefully for that other post that described turning off the rear audio controls by pressing 3 & 5 together. I still can't find it in my manual. :-( But it does work. :-)
You register your VIN number and can look up different info about your vehicle. I imagine in time you will be able to track your dealer maintenance and other stuff.
Well, heated mirrors and a rear window defroster are on my '00 Dakota QC along with a V8 and a stick shift.(0 to 60 in 7.5!!!)
I'm getting ready to purchase a Sport Trac. I'm just having a difficult time deciding what method of purchase is viable at the moment. Are the dealerships beginning to stock more? Or, is my best bet to purchase online (carsdirect.com, ie)? Any helpful clues would be extremely appreciated! By the way, I'm located in Phoenix, Arizona (if that helps).
http://www.immelmotors.com/pdf/Exp_SportTrac.pdf
the site i got the link from is:
http://www.immelmotors.com/sporttrac.htm
then go down to the specs link
I like my st a lot too but as far as new and exclusive: Chrysler has had an in dash changer for at least the last 2 model years on some models. The bed extender is also on the F-150 and JC Whitney has them in hteir catalog.
petty1:
You can have a rear window defroster on a moveable rear window. I had one on my 82 Jeep Cherokee.
The bed extender that Ford offers (ST and Super Crew) are the ONLY factory installed bed extenders offered in the United States. Ford has an EXCLUSIVE agreement with the manufacturer.
The unit that Nissan puts in their advertising is a bit misleading. You can NOT get a factory installed one on the Nissan. It is only an AFTERMARKET unit. If you look at their unit closely, you will note it is far inferior in its operation. It has these cheap nylon straps that hold it in the extended position, unlike the ST which has the two positivve locking, color coded mechanical devices. A MUCH better design in my opinion.
I have been searching everywhere for grill guards for my ST, has anyone found them yet?
From what I hear the tonneau cover from Ford won't be available until sometime this summer.
The bed is 40" between the wheel wells and 49 1/2 above the wheel wells so a full sheet of plywood will fit inside. The bed is 50" front to back with gate closed, about 70" long with the tailgate down.
I have similar plans to haul the occasional sheet of plywood or lumber in mine.
Being a little peeved at Ford for their lack of response to my queries, I reacted to a recent writers advice and went to the "Owner Connection" for an answer as to "what is the reason for such incredibly slow delivery times." They came back via e-mail three days later with this answer. "Please accept our apologies for the delay which was due to a combination of parts and assembly delays."
That certainly clears things up. The answer has to be that the large dealers are getting the inventory. Ford knows where the bread is buttered.
Such are the ways of life.
Your material hold is probably the tonneau cover. Read the other emails reference the probable availability date--I think its July.
As for the build dates, I'm in the same boat as most of you. I ordered my ST on 3/30/00 and I don't have a VIN yet. Ford customer service told me that the order is awaiting assignment. More importantly, the "system" is only updated once a week. Hopefully by Friday, I will have more encouraging news. Yes, I ordered from a small dealer in MO.
I took it back and upon several hours with the vehicle they found hairline fractures in the moon roof drain tray, or something like that. They said it's definately a manuf. defect. The new parts came in today, so I am hopeful to get the truck back. They are also going to replace the headliner (2 months).
I can't wait to get it back. The Escort loaner just doesnt cut it!
http://www.fordcredit.com/esp/
Can the softtop be secured or is it a high (easy) theft item? Again thanks...
