2000 silverado 2500hd vs. 1500
Is the 2500 hd silverado a better riding truck
than the 1500? Is the extra equipment on the 2500
worth the extra dollars?
I own a 2000 2500 LT.
Check out Topic 768 devoted to this subject..
- Tim
The 3/4 does RIDE better also.
You'll see.
- Tim
big brother of the two trucks. It's like Beauty
and the Beast. The Silverado 3/4 ton is simply bigger and tougher. A few things that make this
the 2500's trait is the thicker frame, heavy duty 4L80E transmission, Corporate 14-Bolt rear axle with 4.10 gearing option, larger front differential, stronger a-arms, and 8-lug wheels to name some advantages. However, a 1500 will do just fine in most cases, but a 2500 is just for the people looking for a bigger and better truck. The best part is the price, for the extra money you spend you get A LOT.
Madison@Softdisk.com
Once you have had 3/4....you will never go back.
All I can ask myself now is.....what took you so long?
- Tim
Heavier truck + good suspension = smooth ride
Another thing makes a truck smoother, the long bed. Just needs more room.
You never compared the two?
The 3/4 Firm compared to the 1/2 Z71 was sooooo much better in all departments. Both are hard rides..but 800 extra pounds takes the bumps better and is more in control on washboard type roads. Now while going down the roads and hitting a series of bumps...the 3/4 is rough...don't make no mistake..but still handles better than a Z71.
I've never driven a 1/2 Firm ride or a 3/4 standard ride to tell you what they be like. probably pretty darn mushy..
..Another Sermon wrapped up..Do you believe children?
- Father Tim
...(How did I go from Wrath to father?)
Only reason I jumped into a 3/4 was to see what the new 6.0 was like. little did I know that I has been buying the wrong truck all this time.
a 5.3 1/2 (that has 3.06 first gear) probably will out perform a 3/4 6.0 (with 2.48 first gear) off the line....after that ..well...it's just a 1/2 ton.
racing trucks is kinda dumb...I prefer to see cars racing.
When I'm on the Highway ramp and push it half wayu down...and go from 60 to 85 in nothing...I'm glad I got the 6.0.
it's all a matter of preference....and I found my new preference....
- Tim
I have a question on the firm ride option. My first salesman told me it included heavier leaf springs but all I've heard here is different shocks. We all know about the accuracy of the crack auto sales staff out there so I thought I would ask you all. I don't want a firmer ride than necessary with no load so I ordered the regular suspension. Since I'm using air bags for load assist I didn't think I needed the option. If the stock shocks aren't up to the task I can replace them easy enough. So what exactly does the firm ride option include???
Quad,
I drove a 3/4 Firm and a 1/2 Z71 on the same path when I test drove a while back. The last stretch was on a washboard dirt road that crossed over Rail road tracks in the middle. Me and my wife were in the truck. Both of us said the 3/4 handled better. Maybe it is the only road in the US where this can happen? I'm telling the truth here. Or maybe i have been lying all along on all these topics. Bounce is not happening with My 2500 as you say it will.
I don't know what more to say?...but the 3/4 handles better.
- Tim
You sticking with a 3/4 Chevy still?
- Tim
- Tim
My heart just stopped! What have you done?
Daffy said.."No NO NO NO!!..Not the wed one...don't ever push the wed one!!"
..I'm saying..."Don't ever say the "D" word.
Hope it works for ya.
I guess some will buy because of a 4th door.
Good Luck
Seriously
- Tim
- Tim
hehehheheeee
- Tim
Hope to see ya in a Chevy next time..
i like the 6.0 and would have loved to have it in a 1/2 ton, but had to settle for the 5.3, but hell im not complainin one bit!!!
BTW the z-71 is awesome if you go on a offroad or bumpy road or even over a bunch of railroad tracks, floats over like a breeze
i do like that the 3/4 tons look like a truck, the 1/2 tons look kinda small, but i'll just have to live
long live chevy
More yuppy designers at work....
Nothing like a V-8..Iron heads..RWD.
- Tim
Aluminum can warp if it over heats, but that's not going to happen on the 4.8L or 5.3L because GM has a "limp" mode to drive home in when you lose all the coolant. Basically what happens, is cylinders get turned off, and cool down by pumping cool air through them until they can be turned on again. You drive with reduced power, but also don't overheat the engine. They will last just as long. Remember, all the moving parts in the aluminum and iron heads, the valves, guides, seats, inserts, rockers, are all made from other steels. Aluminum is not used in a bearing.
Iron heads? Better own stock in Archer Daniels Midland Company.
Ryan
Pics are on the Silverado topic.
All are available in all trim.
- Tim
I turn my on sometimes just for seconds, when I want to plan ahead for something in front, maybe near the top of a hill, then quickly switch off going down.
The best setting for tow/haul is the one that minimizes needless gear changes.
Danjan,
I got a 2000 2500LT 4:10 (Just like Tim...What a coincidence).
Why do you say you should have got 4:10? I love them...but wonder how much less is the 3:73 with the 6.0? Is it just not enough when hauling at highway speeds for you?
While driving in drive, I experience a real lag in shifting on a long grade and occasionally it snaps with a bang into a lower gear with tow-haul on. In third, I don't notice this, but I also don't use tow-haul either. When I use drive only, on the interstate without tow-haul on, I lose speed on a hill in cruise and then experience lock-up. Maybe I should trade for a 2000 1 Ton. When I'm not towing, the truck drives like a dream and I experience none of the above. Perhaps my computer needs to be tweaked with a magic pill! My dealer of course says there is nothing wrong with my truck. Mr. Goodwrench sometimes knows less than the rest of us. No pun intended. I will be towing my trailer to Texas this Winter from here in Wisconsin and I'm really going to put this vehicle to the test. I also extended my warranty just for good measure. Transmission problems I don't need!
auto transmission. Given the choice for my
new Silverado 2500, should I get a manual
transmission or the auto with the tow-haul?
This chat group is the first one that seems
to have experience with this question. Thanks
- Tim
