Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to [email protected] by 1/27 for more info.
I need help on what to get, 2003 Chevy or Dodge?
I'm Looking into buying either a 2500HD chevy or a 2500 dodge ram (diesel). I look on almost every site for pros and cons on these two trucks. Both trucks look good and sounds good. I just want to get more info and see what more ppl who may own the two truck.
I'm not a Dodge or Chevy fan. However, I DO wish I could get a Ford with the Cummins engine.
I dont like the chevy having aluminum heads but I guess they know what they are doing, LOL.
Our oldest trucks in the fleet are Dodge RAMs, '97-'00 and our only 4x4s. They've been very competent performers. The track bars were replaced early but this has not resurfaced as a problem.
We stopped buying Chevys in '96 because of reliability issues after having them in the fleet for twenty+ years. Rear axle and transmission failures were above average for '91-'96s and the most notable problem area. They were far from trouble free with a number of problem areas. They also were the first to rust, thus reducing resale value considerably. They were replaced by F150s starting in '97.
Our total PU fleet is 81 units. We have no diesels at this time.
Dusty
After I look at warranty the Dodge and GMC both have 36,000 mil bumper to bumper, then on the power train Dodge have 7y/70k GMC 100K on engine only.
This warranty I have been in my mind, I may end up with the Dodge because of the warranty.
What's you guy think?
Standard transferable 7-year/ 70,000-mile Powertrain Limited Warranty‡
Notice the little symbol after warranty?
Heres what it says
‡See dealer for a copy of this limited warranty. A deductible applies.
Looks like it isnt free
I tow a 14,000 lb. fifth wheel trailer and the 2500HD GMC/Chev was the only one that came close to that tow rating.
For my truck with the 5'er you mentioned, here's how the numbers would stack up. I'm assuming the truck is loaded and ready for the trip, complete with passengers, and the 5'er properly loaded to its gross weight of 14k lbs.
Truck - appr. 7,500 lbs
Pin weight - 2,800 lbs
Total truck weight - 10,300 lbs (My truck has a GVWR of 11,200 lbs, so I'm good to go there.)
5'er gross - 14,000 lbs
Minus pin weight - 2,800 lbs
5'er axle weight - 11,200 lbs (This is the weight that would probably show up on the scales for the 5'er axles.)
5'er axle weights - 11,200 lbs
Total gross weight - 21,500 lbs (I would be over the GCWR of 20,000 lbs.)
So, IMO go buy a truck that will not only tow the 5'er you want within its specs, but one that is big enough to handle the load with ease.
I am waiting to see the 2004 with Lalemie option, there is none in my city.
