Can too much oil damage your engine ????
Can anyone out there tell me what is the first thing damaged when you drive with too much oil. When the engine is cold now it raps until it warms up. Is this the valves, guides, seals or something ?
See Also: Stop Changing Your Oil!
In other words, if you ran too much oil too long, you have trashed your engine.
Harry
Harry
Your noise could be piston slap or it could be a sticking hydraulic lifter or it could be a loose wrist pin. There are other possibilities as well but those are most likely.
The above comments are spot on, seals and the oil being turned to foam by the crankshaft are issues.
However, with that being said, I run about a pint of extra oil in my SVT Contour, could probably run a bit more.
Why? Well most of the driving is at higher RPMs, and this is a DOHC engine, so by the time the engine gets running, there is at least a pint of oil in the heads.
So, when I'm charging those 40MPH exit ramps at 80MPH (when I can safely do so) I don't worry about my oil pickup sucking air instead of oil.
(That will certainly lead to a catastrophic failure if it goes on for any significant length of time.)
But for 99 and 44/100ths percent of all people, you want to run the recommended oil volume and no more.
TB
The other was a '90 or '91 350 Chevrolet marine engine (in a boat, of course). I am not really sure how much oil was in the engine. It was hard to tell since about a 7 inch round hole was punched through the side of the block between number 5 and number 7, caused by number 6 breaking off at the very top of the rod. Another piston had begun to separate at the top ring groove. When we got the engine out we noticed that one of the block bulkheads was cracked from the main bearing cap almost all the way to the top of the crankcase cavity.
Yes, too much oil can blow a engine.
Dusty
It reaches a point though, where the oil reaches the height of the rotating crankshaft, and this whips the oil into a froth. Oil with lots of air in it does not lubricate well. The result can be the same kind of problems you wuold have running a car without oil...e.g. bearing failure, catastrophic damange.
I personally am not familar wtih leaks resulting from overfilling. Can anyone who has seen these first hand please give us any details. How much oil are we talking about?
For the vast majority stock automobile engines this will never be a problem. As someone has already indicated, the engineers who designed the engine probably knew what they were doing. Overfilling any engine beyond the recommended level could be perilous. It most certainly isn't going to provide any margin of protection for a factory engine driven on the street.
Dusty
I was visiting some people in FL and took my car to a quick change place. They gave it back to me somewhat above the full mark. I complained loudly and even called the owner, but they would not take the time to adjust it. Called the service manager at my GM dealership in PA, and he said...a little bit over is not going to hurt anything, so I just let it go.
I am now changing my own oil, so this is not a problem.
I am not recommmending such practice...just answering your question of "why?".
