NWBLIZZARD
The basic idea is to prevent cold outside airflow into the cabin due to forward speed on a cold or coolish morning before the engine warms up. Once the engine water jacket is warmed to ~130F the blower will start and the servomotor will begin moving the air outflow routing to the footwell mode.
While the idea of baffling the (potentially COLD) incoming airflow (due to forward speed) by forcing a complete reversal of flow direction is quite sound, the recirculate mode in HOT weather is nothing but stupid.
Luckily for you I understand that there is now a C-BEST option which allows you to have an automatic unselect of the recirculate mode during hot weather startups.
Regarding the rattle coming from your passenger seat area, this has been and continues to be a disappointing problem I've had with my 05 Limited. I actually had my car back to the dealership at least three times and although they could hear the rattle, they were not able to isolate it. I then found the source of the noise was coming from the passenger side of my moon roof ( the dealership had previously told me that wherever the noise was coming from, it was not the moon roof ). I found that when I put upward pressure on the front passenger side of the moon roof, the noise went away. Well, I then had the Toyota rep meet with me and he too heard the noise and confirmed that it was coming from the moon roof. They gave me a loaner and 3 days later I pick-ed up my rattle free car. They had to realigne the metal guide brackets in the moon roof. Well, unfortunately, two months later, the noise is back, so I need to set-up yet another appointment. This may not be the source of your problem and, if not, there are a number of post which describe noise issues and fixes. Good luck and let us know how you make out! dan
OK..Here's another problem with my 05 Limited...
When the climate control is on and the screen indicator is showing that the air should be coming out of the floor vents, I still have air coming out of the outboard dashboard vents. I think that this means the damper motors are either sticky or bad. The dealer is saying that is part of the normal operation?? I've had other cars that have had this problem and it WAS a bad motor.
Anybody have this problem or is this just a Toyota problem?
Also, I check to see if the seat rattle was coming from the front seat head restraint position, but it was all the way down. So I'm going to do some more driving and try to do some more concerted isolating/fact-finding.
Funny, when I got the first rattle in this car, I figured it out myself. The way they've positioned the front passenger seat belt, makes the buckle of the belt hit the "B" pillar when not in use. I'm regularly repositioning it so the buckle doesn't hit the pillar.
Every Toyota that I driven all do the same thing (00 Solara, 03 Avalon, 06 Av) I think it helps clear the side windows. In the winter I have always just directed the air away from me, or you can just shut the vents off.
Do I need a new transmission or can it be repaired. Thanks, Wayne
Take care!
I can't see why you wouldn't have a warranty. The U.S. Avalons are built in Kentucky alongside ones destined for export to Canada. Almost everything is the same except for the speedometer and the bi-lingual airbag stickers.
The computer screens read fuel economy in litres per kilometer rather than miles per gallon. Canadian Toyota dealers should have no problems servicing an Avalon built for the U.S. market. Toyota's warranty comes with the car and should be valid in North America.
A call to Toyota or an email to Toyota should give us an answer. I'll try to find out if possible.
You have a valid concern. You should get the answer here....a knowledgeable answer.
i think i'm goin'a get popped by the HOST on this one.
The idea is that the cooler air coming from those vents has been dried via the A/C and therefore will help keep the side windows from misting up/over.
The Avalon received AAA's highest rating in the $25.000 to $30,000 range. They are off on the price (at least for the XLS and Limited models), but it is nice to see the Avalon up there on their list.
I certainly agree with them and couldn't be happier with my 2006 XLS. A great car!!
By the way, for those interested in other trivia, I paid $300 over invoice and I'm having factory door-side protection moldings installed.
On my '06 Touring, on the roof control panel where the map lights and sunroof controls are, I noticed two tiny little blue/white (LED?) lights. These point foward, toward the dash, but don't seem bright enough to actually light the dash. You also can't see them from the normal seating position, you have to lean forward and look up to see them.
They seem to be on anytime the ignition is.
I can't begin to guess what these are for. Anyone got a guess?
When the key is in the ignition but the dash lights are off, and it's really dark, these two lights provide a very faint, subtle bluish illumination of the instrument panel, in particular the audio system cover and center console. If you block these lights with your hand, you can tell that they do make a difference. A nice touch!
havalongavalon
I too wonder what Toyota Canada will say. We should be able to buy an Avalon in the US and import it into Canada and have it warranty-serviced here. Avalon price differences continue to increase as the Canadian dollar gains value. Looking forward to your findings!
havalongavalon
Bookmark | Reply | E-mail Msg
Are there By-pass options that will allow the Navigation to be used while the car is moving
___________________________________________________________
anyone ??
At the very least, you can use voice to "Go Home".
Have you noticed that on radio stations that give digital text messages, you can't read them when the car is moving either? Same story. They want you to watch the road.
I just noticed this recently, so my amazement at this system continues..... :P
btw, why couldn't there be an interlock with the passenger seat, using a pressure sensor combined with the seat belt, to allow operation by a passenger?
Good idea! For passengers who weigh over 60 lb, a sensor is already there; it turns on a not-always-well-appreciated Airbag On light on the instrument panel...
I think they could used a better set of editors on how the features work. That thing where all of your travel data is erased when you turn the car off (Info Screen), the radio screen issue, the not allowing a passenger to operate the Nav System. The everytime I turn on the car, I agree not to do unsafe things with the Nav system.
But...I still like the car a lot!
A cement block....maybe..??
NHTSA Recall Campaign Number: 06V096000
Component: AIR BAGS
Details: ON CERTAIN VEHICLES, DUE TO IMPROPER ASSEMBLY OF THE AIR BAG INFLATOR, WHICH IS USED IN THE SIDE AIR BAG, THE CURTAIN SHIELD AIR BAG, AND THE KNEE AIR BAG ASSEMBLY, SOME INFLATORS WERE PRODUCED WITH AN INSUFFICIENT AMOUNT OF THE HEATING AGENTS NECESSARY FOR PROPER AIR BAG DEPLOYMENT. IN THIS CONDITION, THE EXPANSION FORCE OF THE GAS MAY BE INSUFFICIENT TO PROPERLY INFLATE THE AIR BAG WHEN THE SRS SYSTEM IS ACTIVATED DURING A CRASH.
Consequence: THIS MAY INCREASE THE RISK OF INJURY TO THE OCCUPANT IN THE INVOLVED SEATING POSITION IN THE EVENT OF A CRASH.
Corrective Action: DEALERS WILL REPLACE THE SPECIFIC SRS AIR BAG. THE RECALL IS EXPECTED TO BEGIN DURING APRIL 2006. OWNERS MAY CONTACT TOYOTA AT 1-888-270-9371, SCION AT 1-866-548-1851, OR LEXUS AT 1-800-255-3987.
Units Potentially Affected: 133
Recall Initiated By: MFR
Date added to NHTSA datbase: 04/03/2006
Internal use: 4/3/2006
It looks like this only affects a small number of cars. I guess I will call the Toyota toll-free number.
Will let you know as soon as I hear.
Take care!
MFG Bulletin Date: 20060301
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM
Details: EXCESSIVE SULFUR ODOR. *TT
Date added to datbase: 20060418
Avalon Ltd.Am siding towards the Avalon but I am a couple of months away from buying any info would be helpful.
Soldier,have you looked at the Garmin Nuvi,it is not dash
mounted but looks good.
Just curious if any other '05 Avalons have experienced this same problem with the A/C?
Ed
Just got a reply from Toyota re: warranty on vehicles purchased in the U.S.and imported into Canada.
RESPONSE (TYRONE CADLE)
Quote "Warranty coverage is applicable to any vehicle registered and normally operated within the United States,
Alaska and Canada.If the vehicle is relocated outside the United States, Alaska, or Canada, The local dealership may not provide warranty service because the local Toyota distributor may have no obligation to provide warranty service to your vehicle. Additionally, your Toyota vehicle may not comply with the regulatory and / or enviornmental requirements of certain countries. please contact the local Toyota distributor applicable to your area for more information.
Thank you for contacting Toyota!
Your email has been documented at our national headquarters under file # 200604260144.
If we can be of further assistance, please contact us.
That's it in a nutshell.
I take it from this that Yes, The Toyota warranty would be good in Canada.
Take care!
Hmmm... after reading it, I am less optimistic than you, I'm afraid. This response is inconsistent, perhaps deliberately vague. On one hand, they say the US warranty technically is "applicable" in Canada. But on the other hand, Canadian dealers may not provide warranty service and may have no obligation to provide warranty service -- say that again? This could be a rider meant to discourage cross-border purchases, while still providing some assurance of warranty service to, say, U.S. tourists visiting Canada.
Maybe it's time to buy that cabin near Mount Baker... Say, would you be interested in a time-sharing arrangement among BC Avalon owners?
havalongavalon
