Or maybe you left the gas cap loose....
"took it to a mechanic."
Who would more likely than not take advantage of you even if the problem were as simple as above.
Good Luck,
9119911
P0441....Evaporative Emission Control System Incorrect Purge Flow
P0455....Evaporative Emission Control System Leak Detected (gross leak)
Any one who understands the tech side of this is welcome to explain it to everybody.... but it really doesn't sound that complicated if you repair cars and sure doesn't look like $600...
Just curious, so we worked out the top end is probably about 140mph on this car.
Just curious how the heavy VW R32 with a far less powerful 3.2 L motor claims they limited the top end to 155mph if the more powerful Avalon motor could not even reach this.
Is this claim of 155mph on a standard 3.2L V6 with no form of turbo realistic? as I was thinking it would be a weight vs horsepower scenario to see how far the motor could get the chunk of metal.
The weight from what I read for both cars is about 3500 lbs, so weight is near equal.
Power on the avalon is claimed at 168bhp @6200 with the VW claiming 250bhp @6300
Torque for the avalon is claimed to be 248 lb.-ft. @ 4700 rpm where the VW is claimed at 236 @ 2,500-3,000
So if you have a car that is pushing a fair amount less power+torque at about the same weight, how is it possible with aerodynamics that I dont think could account for a limited 155mph let alone anything over that?
Just curious for the more technical folk here.
Thanks and happy holidays everyone!!
Sheldon
Sheldon
The weight of a vehicle has very little to do with vehicle top speed, whatever it is. Reason: "Objects in motion tend to stay in motion...."
The weight of a vehicle has everything to do with how long it takes to acheive top speed from rest. Reason: "Objects at rest tend to stay at rest...."
For top speed limitations the single biggest factor is air, also known as aerodynamic drag (Cd). A smaller engine of less power can easily propel a different vehicle to a higher top speed if the body of the second vehicle is more aerodynamic. Physics 102...
Enjoy an Avalon today... Great Cars..
Very true, I did not think of that.
I've seen video's though with a (supposedly) stock standard R32 hitting 170mph, I wouldnt have thought the aerodynamics of the vehicle would have allowed it to get to that speed without more power.
Especially on further research that for the 2008 R32 the Drag coefficient is listed as been .32 where the Avalons body is listed as been .29, would this not mean the car with the .29 coefficient would cut through the air better?
Thanks again
Sheldon
The "check engine" and VSC lights came on, so I took it to the dealer. They tell me that I have to replace the O2 sensors and the intake manifold.
The cost was $1,800. I have 45,000 miles and just passed 36 months.
There is a Toyota Service Bulletin (T-SB-0114-08). Does anyone know anything about this? Is it common? What about the repair cost? Help! I am livid...this is supposed to be Toyota's top-of-the line car. So what's with a repair like this, only 9,000 miles out of warranty?
The intake manifold itself is a major engine component and, absent some very unusual situation, is seldom replaced. You need to ask "why" as to this part. In addition, it may be part of the powertrain warranty and replacement may be free, if needed.
Suggest you try another dealer, this one is very suspect, based on your information. Post your results. Hope this helps.
Ok, aerodynamic is a big factor in many designs. Coefficient of drag for most family cars we see on the street doesn’t differentiate to the point to account for significant difference in vehicle speed.
Here’s this question: which will accelerate faster from rest, a two-cylinder motorcycle (standard specs; no fancy bike) or a Caterpillar truck generating, say, 2000 ft-lbf of torque?
and for the sake of this argument, the bike will leave the Caterpillar in the dust too.
Do you all think it is only the drag factor that will give the edge to the bike? If so, think again.
Amaury
'08 Limited
The bike that may push out far lower torque and bhp also has hardly any weight to deal with, which of course is a different story with the caterpillar.
Least thats my thought on it
Cheers
Sheldon
As an object (bike, Avalon, truck, etc.) accelerates, the weight of the object becomes less important and the aerodynamic shape, if you have air as a factor, becomes more important, all else remaining constant.
You have the concept essentially correct, as does the post after yours. It can be confusing at times... but it's really just basic physics. Toyota engineers know what a vehicle will do before it is ever built and tested on a track just like Boeing knows what a plane will do without ever flying it. It's the things you missed that make engineering exciting....
There is a factor in design between the motorcycle and the Caterpillar that explicitly tells you why the Caterpillar, with its massive engine generating about 2,000 ft-lbf of torque and ~ 600 hp, has a top speed of just about 50 mph whereas the bike, with its tiny engine producing just a fraction of the truck’s energy and power output, has an equal or greater top speed.
Better yet, explain why the Space Shuttle Crawler Transporter (the flatbed that transports the shuttle from its hangar to the launch pad) generating way over 5,000 hp has a top speed of less than 1 mph (at this speed aerodynamic drag is insignificant). I can assure you that my Avy, just like the bike, generating a meager 268 hp, will leave the Crawler in the dust too in no time.
The modern-day Somalia pirates are taking full advantage of this difference in design by simply using common sense. Their tiny vessels are capable of intercepting and outrunning the huge ships out in the Indian Ocean.
Yes, as you said it, it’s all about physics, Newtonian physics to be precise. But you still keep missing the answer.
Amaury
'08 Limited
Considering buying a couple of Avalon’s for a Taxi service and have some questions.
Any opinions on using Avalon as a Taxi
Trying to piece together service recommendations for Avalon any one have a copy of Toyota recommendations.
Do they have factory running lights as standard as I am in Canada but will probably buy from the USA
What grade fuel are you running is it happy enough on regular or do you need premium
What should I look out for when buying used specific to Avalon.
Thanks in advance
I own a 2006 Avalon Limited and have nothing but praise for the car! It is powerful, roomy and runs on regular! Yes, the owner's manual even says it runs on regular.I think this car will be perfect for a taxi. I have over 100K miles now. I have changed tires once and front brake only. It is quiet and drives very smooth and "effortless"!
Just an update. I had tsb st002-06, replace steering box, clunking noise, done DEC. 07. That was at 28k, noise stopped everything ok. At 38k, noise started again
, brought back to dealer at 39k, Jan. 09. Since out of warranty was told it would be on me. Sent email to Toyota, from Toyota.com page. I stated this seemed to be premature failure and did they think this was right. Toyota contacted the dealer, who contacted me to make an appointment to check car, (Avalon xl 2006). They first tried a new tsb-0296-0819, this puts lots of grease in the steering assembly.
That didn't help. The Toyota reginoal rep. said they would pay for a new steering box even though it was out of warranty. The service manager at the dealer said since I paid for the failed attempt tsb-0296-0819, cost $121, the dealer would pick up the labor for the steering box. Work done, noise gone. The service people still are not sure what causes failure. Some think spline gears wear and cause free play. Service manager thinks it's the universal joint, (in steering box), wears and causes free play and
clunk noise. All hoped new part (steering box) was better engineered and problem would not recur. New part warranty one year, I will be watching closely. I thought Toyota did the right thing when they did not have to. It gives me a little hope when people stand behind their products and work. Happy Motoring.
My wife's Bonneville has done the same thing. Dealer replaced some steering parts and the noise was gone for about a year. Its back again big time. This will be at my expense and about $300.00. May be a universal design problem for some cars.
as a courtesy, gave me and additional extended warranty at no additional cost.
I am feeling much better about Toyota now. Thank you for having this website.
Call 1-800-530-5789, Midwest Toyota, Hutchison, Kansas, for info. They have close to best prices if available. I paid just over $600 for zero deductable, Platinum Warranty for my 07 Avalon.
I have changed all the Computer Boards and it keeps blowing out the Main Computer hence not taking any charge to allow it to start.
I AM DESPERATELY IN NEED OF HELP. IF YOU ARE EN ELECTRICAL GENIUS AND CAN FIX IT PLEASE HELP. Nearby Toyota Garage is Useless, they cant help.
Why any Toyota garage can't help is beyond me, maybe they don't want the headache.
I'm having the same problem with my 06 XLS. It gets worse as the outside temperature increases. I originally thought it was a strut mount issue, but the box may be the problem.
I wish it didnt cost that much. Its really Low milage though. 4800. The previous Electricial Mech advised to buy New Harness for the car but it costs too much.
So really at a cross road.
Any help / advise wld help.
Regards.
This is my first avalon, shall I take the offer or not? Thanks for your comments
Cheers
Sheldon
How much It could cost to have it fixed permanently?
Is that toyota plaitnum extended program? It seems different Toyota dealers sell the package in quite different prices.
let me start from a few items not covered: Paint, exhaust system, carpet, glass, upholstery, soft trim, weatherstripping, battery, clutch disc(manual transmission), tires, disc brake rotors, spueaks, rattles, water leaks, wind noise.
Vehicle components covered:
Engine: engine mechanical, lubrication & cooling system, fuel system, intake/exhaust manifolds, engine electrical, emission control systems, electrical fuel injection/ECC
Power train: transmission, propeller shafts differential, transfer case;
Steering system:
Front and rear suspension:
Brakes:
Road wheels:
Body& Interior
Electrical: body electrical, heater & air conditioning
Audio & Video components: cellular, Audio/ Video/navigation, mobile entertainment system
Would Steering Column (or Shaft) Noise jeopardize the driver? I mean is there any potential threat to the driver's life? like loss of the control of the car,.........
Otherwise, I would let it be, since My 05 avalon is out of warranty and the noise is not that much. So far, the steering operation is still smooth, except the clunk noise when making a turn in local.
My Toyota dealer tried to pull a fast one one last week. When I started the car it missed like running on 5 cylinders and the check engine like came on.I drove 4 miles and would not go cver 40 mph. Parked it in the garage. Took it next day, the light went out. The service mgr. told me they found nothing and normally I would be charge $89.00 for checking the computer, but would pass this time. My contract does not cover this if they fine nothing wrong. Lesson learned, take car immediately so they can see for themselves. Why didn't the computer record the check engine light? ange
I went back to Sears, and the technician had all the four new michelin tires rebalanced. Unfortunately, the shimmy is still there.
Finally, I went to some Toyota dealer. They checked it out and found out that the two front wheels were incorrectly balanced. And they charged me $79 for it. There is NO more shimmy, then, even I hit 90 mile on highway.
Does Toyota dealer really have some high-tech balance machine? or It is due to the careless work at Sears? I thought tire balance is NOT a hard job and could be done at most garages.
BTW, do you think I need have the two back wheels rebalanced too at Toyota dealer for another $79?
After several decades of driving on Michelins I can tell you, my opinion, the problem is Sears. Normally Michelins are OK without the on-car balance job. They are great tires. But any ride is better with tires balanced on the car. If you feel no vibration from the rear leave them alone unless you cruise at 90+, then just rebalance all four when you rotate. There is no special machine at the Toyota dealer, just a service manager and a tire tech guy who are more interested in the job than the people at Sears......
