Unless you play with a threesome, someone will have to hold their clubs in the back seat. But this is no problem since all will enjoy the ride.
"I've been running my LTD since 02/10 on mostly 87 octane and haven't heard a single ping. The engine has a knock sensor and will adjust the timing according to the fuel it is fed. Toyota says peak performance will happen with 91 octane. With a lower octane you will get slightly less performance. I don't find this to be an issue. Even with 87 this car has more flat out performance then I care to exercise. I've been to 105 a couple times and have chickened out. This car just wants to go!
MikeS."
Yesterday I had some (a lot) of time to kill while the wife went shopping. I was playing with the door locks and reading the 05 Avalon owners manual. Right there on the back cover it says 87 octane or higher. So 87 octane is right out of Toyota's mouth.
MikeS.
The trunk is big enough to fit 4 regular-sized golf bags, of which 3 (but not all 4) can also have pull carts attached, if you follow a tip that Old Groza shared with this forum some time ago. First take out the drivers, tall putters (in my experience, any clubs longer than a 3-iron). Then place the bags top-forward into the trunk. Place the longer clubs across the top, or better, along the (flat) floor in front of the back seat.
havalongavalon
zekeman1
havalongavalon
You have got to be kidding. I just put my bag and my wife's bag in the trunk and there is no way you could get 2 more bags in there let alone three with pull carts. Now, if you want to jam a set up against the sub-woffer you might get 4 sets in but no way can you get 4 sets with 3 pull carts. :P
Hi kinzua. No, I wasn't kidding. Are your bags regular size, or oversize? If regular size, did you try to put the bags in lengthwise, after removing the drivers and other long clubs? Four bags fit tightly within the width of the trunk, but nothing comes even close to the speakers. If you include pull-carts, the wheels stick up at the very rear of the trunk, and laterally into the wider cavities behind the car wheelwells. The trunk is deep enough, there is no issue with closing the lid. The limitation I found is that there is not enough room for 4 pull-carts with regular (wide) wheels. Maybe 4 carts with old-type thin wheels could fit, but are no longer allowed on courses around here. There is enough room for 3 bags with carts plus one bag without cart. Aside from the volume occupied by the cart wheels, the carts only add about an inch or so to the length of the bags and less than that to the bag width. If you don't have carts, ladies' fairway woods may stay inside the bag, but you will always need to take out the drivers because their length exceeds the depth of the trunk.
Try it, and let me know again.
havalongavalon
PS- My Blizzard Pearl came was delivered today. It has the Ivory interior and (gulp) we had dirt/dust showing on the door sills just from climbing in and going over some of the goodies with our sales person. Me thinks this is going to be a nightmare to keep clean (especially with boys 5 and 8 in the back). I'll post pictures this weekend.
Email me if you want me to send them direct to you. ULV@bak.rr.com
mmg1
p.s. We are on our way to the mountains in N.C. for a week,trying for cooler temps!!
Dan
Viking, I think the wife did put something behind the car seat but I have no clue what it might be. I'll ask her tomorrow if she knows and will get back to ya.
Try keeping one of the dark colors clean! I have the Indigo Ink (dark blue) and I wash it at least weekly. I find that the bottom rear corners of the back car frame gets dirty. Oh heck, too hard to explain, I'll post a pic in the morning.
MikeS.
Dan, I have the LTD and drive it down the freeway a lot at 80mph and it is sooo quiet. I'd hate to have anything less.
MikeS.
Wednesday I had traveled about 6 miles on I-81 with the laser cruise set at 80mph. I pulled off the freeway and into a gas station for a fill-up. I left the car running. When I pulled back onto the freeway I hit the resume function while doing about 35. The cruise kicked back in and brought me back to 80. I was suprised!
So in the last 2 days I've tried this with our other 5 Toyotas and none of them would work. We range from a 96, 97, 99, 00 & 03 in assorted cars and trucks.
MikeS.
havalongavalon
None of the bags are tour type oversize, just plain old cart bags you buy at walmart.
Took the Driver, 2-4-5 utility metal, 5-6-7 iron, umbrella, ball retriver and normal size putter out of my bag and the remainder fits lengthwise. I will agree with you that if I remove over half of the clubs in my bag plus needed accessories it fits lengthwise.
So I stand by my original statement, "someone in the foursome has to take their clubs to the back seat"- which given the room in the back seat area is no big deal.
Coincidentally, Blue Mirage was our 1st color choice and a Caddy CTS was my 1st purchase choice. But, since my wife will be the primary driver, she did not want to go back to rear wheel drive, snow tires, etc. & I agree. You are obviously familiar with Western PA winters & hilly terrain. Good luck with your new ride! jeffm5
Have My 2005 XLS Avalon about two months now and have a few very minor complaints
The passenger seat belt annoys me if it is not put back in exact position and I wish I did not have to manually check it so it does not bang around Thanks to this forum the seat belt fix was easy but dont like needing to repeat it on regular basis
My other complaint is limited vision when backing up from rear window. Has anyone looked into or installed back up camera system ??
Thoughts , opinions ???
The requirements to create this sound seems to be traveling in excess of 40mph and a very slight breeze. The volume is not affected by speed or intensity of outside wind conditions.
Does anybody have any thoughts the dealership states that this is a desigh problem. Thanks in advance
Here is the link to my album:
http://photobucket.com/albums/b305/viking644/
The public password is: viking644
Enjoy.
I have also reached out to a couple more aftermarket accessory companies looking for someone to step up to the plate and produce an aftermarket grille. I'll post if/when someone wants to do it. By the way, while I was at the dealership, the parts department confirmed that the grille is a separate piece from the nose of the car and can be replaced without having to cut it out.
I also found that you have to remove ALL the woods and some long irons. Even my wife's clubs don't fit lengthwise. Maybe those Canadian Avy's have longer trunks.
I think if I tried hard enough I could squeeze 4 bags in crosswise, but I haven't tried yet. We do it all the time in friend's 2005 Lexus ES330, with exactly same trunk volume (14.4 cu-ft). I just use my 2000 Avalon for golf trips - 4 bags fit EASILY. It's a shame Toyota shrunk the trunk, but I bought the car anyway.
Max
I was home over Memorial day weekend. The toyota dealer we have used for over 20 years would not test my car while I was home because I belonged to another district but told me that the dealership and the technical person had to work with me to resolve my car hesitation/transmission shifting or lack of it issue. So I went back to my dealership and made an appointment for the oil to be changed (3200 miles), the cargo net anchors to be replaced and a drive with the service director. He has yet to drive the car with me in it. They did the service work and I stayed for the "Welcome New Owners Meeting". I had some maintenance questions but figured this was not really the time or place to discuss my car problems so I did not bring the issues up during this meeting. However, the service director did. He told the other 6-7 new owners that that I was filing for arbitration and there was nothing wrong with my car. He has never driven my car, he was basing this on what other people have told him. He also stated that all toyotas with the fly by wire system have this hesitation problem and I should just get over it. Hmm.. There is nothing wrong with my car.. but all toyota's with a fly by wire system have this problem. Hey guys, I did not have to say a word. I think he pretty much said it all. He also stated that Toyota was having a tough year due to the Avalon's transmission issues?? I thought I was hearing things. I guess he figured he was amongst friends since at least one of the seven customers was an employee. There were no avalon owners at the meeting.
I did find out that the optimal air pressure for my tires is 32-36 with the closer I keep them to 36 being the best. I still did not understand why my brake pedal had more resistance to it than the gas. I did not understand how you can tell the brake is worn outside of the wheels screeching as you stop. The avalon has 4 disc brakes. They are different in that as they wear additional brake fluid comes down into the brake and compensates for the worn pad until the pad is worn to the screechy warning material that should let you know that you need to change your brakes. On the Camry, there were 2 disc brakes and 2 rear brakes and the difference in brake level that I always felt was the result of the back brakes wearing or needing to be adjusted. Finally, it made some sense to me.
I have not filed for arbitration although it is quite possible that I will at some point in time if the transmission problem is not addressed.
While the service director seemed to have some answers. I am wondering if I should be looking into going to a different dealership? Anyone in the DC metro/ N VA area you would recommend?
Is the Navigation voice activated - the Canadian 2005 brochure says it is - I thought it wasn't?
If it is, are climate and radio also voice activated?
Mikeroch
zekeman1
Mikeroch
Radio yes, Climate no.
It is indeed possible to fit 4 regular golf bags inside the 2005 Avalon trunk without removing any clubs except the drivers and fairway woods (and long putters and ball retrievers, if you use these). Two or 3 of the bags can have attached pull-carts. The bags can be placed inside the trunk as shown in the first picture:
First, two bags with pull-carts attached are tucked against the sides. This way, the cart wheels fit in the lateral trunk cavities.
There is room for two more bags (shown here without pull-carts) in the middle of the trunk. Both are oriented diagonally toward the same side, to gain some more length, and one sits partly on top of the other one. I placed a tape measure to show that the effective trunk depth in this diagonal direction is about 38 1/2" at the bottom and 43" near the opening.
The second photo confirms that a regular-sized bag with a full set of men's Ping Eye clubs, even a #2 iron, and two Jazz fairway woods, fits fine. The only club removed from this set was the driver:
The last photo shows that the drivers and fairway woods that I removed from the 4 bags fit neatly along the floor in front of the back seat. (Some of you will surely note that I'm still using the all-weather floor mats; it's still raining a lot around here...)
There is room to carry one more pull-cart, that in my case could be attached to the green bag; but I don't think I could fit 4 bags with 4 pull-carts inside the trunk. I'll leave this challenge for someone else who likes to solve 3D puzzles!
Hope this helps,
havalongavalon
Seems like a throw rug or carpet sample that matches interior color should do the trick.
Tee
Tee
You must have connections. I get my gas from an ordinary nozzle.
Very impressive - nice pictures. Nice to know that it CAN be done. For now, I think I'll keep using my 2000 Avalon for golf.
Max
Hopefully this helps you.
:sick:
We discussed earlier in this forum that the Avalon brake pedal and gas pedal pressures required are quite different. This seems to be a normal design feature, not itself an indication of premature brake wear.
Personally, I prefer brakes that demand a little more effort, to overly sensitive brakes that "grab" at minimal pressure (as I recall was the case in a TL that I test-drove). And with ABS, if you someday have to really step on the brakes you won't need to worry about causing a skid.
Best wishes with your Avalon. I know that you are unhappy with the transmission, but at least the brakes should not be an issue.
havalongavalon
