I do agree with your thoughts regarding Coastal. The company probably consists of one or two engineers familiar with the serial data communications protocol that Toyota uses for body electronics functions. He or she could then purchase a replacement part from Toyota that includes a multiplex transceiver. Then the task becomes primarily a software exercise, to, as you suggested, read and write Nav controller to Nav ECU commands.
has anyone out there got an answer for us..?
cheers
CD
NWBLIZZARD
zekeman1
Jim in WI.
I am not selecting 5th the gear shift is in "D".. it is selecting that gear itself.. I would expect the auto gearbox to work out that it has to change to 4th but it does not.. so the vibration/shudder happens...
note: I am talking in metric, kmph not mph, so 70 kmph is about 40mph
WHAT? $66 for an oil change with you providing the filter? I hope you had lots of other stuff done for that price.
No cheers for you unfortunately. If you have tried everything that I said, on the last post in reference to the vibration problem at high speeds (lets make sure we are still talking about the same problem), and you have excluded tires, wheels, balancing, rotors, and alignment then what you have is.... An AXLE, or INNER CV joint that is BAD or the runout in the axle is not true. How do I know. Had the same problem, and no one at Toyota Corporate or dealership, nor local dealerships could fix it. It felt like the car was vibrating and actually fighting itself going down the road at high speeds. No matter what tires or balancing was done, it would still fight itself.
Take it to someone who cares and will spend the time taking down the parts and looking at the axles turn separately. It is a big job to fix it, but what a difference it will make. I am pretty sure this is what you have but you have to take it to someone who just doesn't want to make another buck off another realignment and balancing. Toyota would not have done it. Too much time. They lost a customer after this car. Too bad on them but I like the car and plan on running it to 300K or so.
Let me know what happens. The part is even hard to get but it can be got/ordered.
abfisch
I noticed the button seems identical among different brand autos just like HomeLink buttons seem to all be the same even in different brand cars.
Mike
zekeman1
xm411.com
Steve
NWBLIZZARD
I was having the same door lock option problem. The instructions say to hold the door lock for 5 seconds however I discovered that it only works if you hold the lock for about 3 seconds. If I hold it for 5 or more it doesn't work. I used a stop watch. Good luck.
1. Ticking noise in rear-right of car. Dealer thought it was poorly installed rear windshield clips. Reinstalled the rear windshield with new molding, but didn't fix the problem. Finally acknowledged that it's associated with the strut tower (as some of you have mentioned) and fixed the issue by installing a shim.
2. Loose fog lights. Dealer tightened the assembly. Problem solved.
3. Auto shipping company. I decided to pay a bit extra and ship it in the same truck as my household goods. The cost is about $2100 for DC to SF.
Where is the sensor located? Perhaps I've somehow covered it? I have the standard inspection and registration stickers in the lower center, and a little parking tag hanging from the back of the rear-view mirror.
Any idea is appreciated.
NWBLIZZARD
The one remaining Avalon in the lot after I had drove off in my Touring, a Ltd. that had a dealer pasted price tag of $46K on it ($8000.00 of wheels and tires (ugly), and some other garbage stuff) - now that car could have gotten a helluva price on compared to the one I drove off in - probably 6-7k of extra profit in those wheels etc. - so therefore gotten a lot closer to what is perceived as 'invoice' cost. Paid cash too, hurts the dealer's ability to manipulate values with the trade-in to make one think he was getting a good price. Not to mention financing incentives....
Have some very good friends that own several dealerships - new car sales is not even close to a profit center for them - they make their money on service depts. and used car sales. Toyota dealers tend to do real well on the used car side of things and less well on the service side - imagine that!
Greg
Also found out that the lid on the big console box will slide forward to act as a driver's armrest. Amazing what you can learn when you read the book.
What? Read the manual? Surely you jest. Does anybody actually do that? :-)
Actually, I do. With all the features, I would also recommend doing that. Why have all the features and not know how to get the most from them? It will also reduce the frustration level when things don't work the way you think they should.
When I buy something that needs assembly, I sit down the night before I assemble and read the instructions. I highlite key things to make it easy to glance at the instructions during assembly and get just what I need, nothing more unless I need it. Works great.
