I'm curious as to how you can get your car in only 10 days. My dealer here (Pasco, WA) says that all cars are sent by rail to the regional HQ (Portland) where they are then distributed by truck to the various locations in WA, OR, ID and MT and the whole process from start to finish takes 3 weeks or so. I was told that my LTD was to start being produced "GT0905" (Georgetown, September 5th) and I could expect it by the end of the month. Did your car begin production a couple of weeks ago?
From what my service rep showed me, at certain air velocities, the inner-deflectors on the vents start to vibrate back and forth, creating the ticking noise. My question here: Is anyone else experiencing this noise?
Steve
zekeman1
It's interesting, rdlong47, that your car was produced one or two days after mine (you are number 72844 and I'm 72509....and the 335 unit spread is about what they're producing a day, based on the August average), and yet you're driving your car already. I don't know what a "hot drop" is (although it certainly has a fascinating ring to it!). I'd like one. Living 15 miles from the factory has advantages!
Concerning unit numbering, I'm still curious to know the unit number (and date) when they shifted over to '06 production.
And a note to the Salt Lake City dealer who told my wife, with great conviction, that the '06 models wouldn't be available until next January (in order to peddle the 05s he had), THAT'S the kind of devious tactic that causes people like me to seek out more honest dealerships, like the one in Great Falls.
I can see/feel an improvement as a result of these changes, and the car is more smooth than before, at any speed.. but as far as I am concerned they have not addressed the main problem which I have and which I have tried to demonstrate to them. I don't even know if they can see/feel my problem... the passenger seat still vibrates and there is still a low frequency droning/rumble/vibration (whatever you call it) which starts about 100Kmph (that's = 60 Mph for you guys) and peaks at about 130Kmph (72Mph)
it is quite intrusive if I am playing piano or classical music at the time.
The technicain says the front passenger seat often vibrates without anyone sitting in it, even on LEXUS's..!!! and any noise/vibration I am now feeling is coming thru from the engine... and it is "normal"....
The only thing which they did not change (despite my suggestion, to which they gave a funny look) was the 'rotors', as you suggested earlier (I assume you mean brake discs) the technicain was amused by that idea...
I think I will get writing to the head office and push for more action, as this should not be happening on this type of car....
Apart from this one nagging thing the car is great...
cheers CD
I think they started with 000001 on Jan 1, 2005 or with the new redesigned '05 models in February, and thye're still numbering in that squence. Maybe I'm wrong, but I think there is a unit number somewhere around 58-64,000 that is the first '06 -- where they changed over from '05 to '06 and kept numbering in that sequence. I'd like to know the number of the last '05.
I know it's academic, but I'm trying to determine how many '06 models were made before mine (number 72,509).
Also, does anyone know when TOYOTA will wake up and make BREAK-AWAY OUTSIDE MIRRORS???
Regards
Hoop43
I also looked on the Autobase website since they conveniently list the VIN number and found that the highest numbered '05 was 61,565 and the lowest numbered '06 was 62,709 so somewhere between these two number lies the first '06 produced.
OUTLINE OF NEW AVALON FEATURES
The following changes are made for 2006 model year.
1. 2GR-FE ENGINE
The heated oxygen sensors are changed from the normal type to the super stability type.
2. BRAKES
The brake control system (ABS with EBD, brake assist, TRAC and VSC) has been made available on the XL grade and the Touring grade as optional equipment.
3. ENGINE MAXIMUM OUTPUT AND TORQUE
Maximum output and torque rating is determined by revised SAE 1349 standard.
For details, refer to “Major Technical Specifications”.
4. EVAPORATIVE EMISSION CONTROL SYSTEM
The EVAP (evaporative) service port provided on the ’05 models is removed from the ’06 models, in which the key-off monitor evaporative emission control system is used.
The canister pump module performs fuel evaporative emission leakage check. This check is done approximately five hours after the engine is turned off. So service technicians may hear a sound coming from underneath the vehicle near the luggage compartment for several minutes. It does not indicate a malfunction.
Quiet!!!!!
Ride was excellent!
Seats were comfortable as all get out.
No rattles or vibrations
A shade over 30 MPG going east with a nice tailwind and AC on the whole way. Coming back west with a slight headwind and no AC was right at 30MPG.
Average Speed around 70 or less (constabulary everywhere goign east average on the way back was just under 75.
Kept it on cruise when traffice permitted.
Navigation system is still a pain in the butt to set up with the joy stick. TL nav was much easier. I set my sons address on the Nav though I know how to get there. I was surprised to learn it really did not want to travel on toll roads. While we were on 476 it kept telling us to get off and go another way though the Turnpike was clearly the fastest and shortest route. I will have to do some reading up on the Nav to see if I have to reset some defaults.
XM radio dropped the signal quite a few times during the trip east but not so on the way home. Similar weather conditions so not sure why it was different unless it was because of the ton of semis on the road going east.
All in all I was very pleased with the car and feel better about my choice every day now. Oh I almost forgot.. The toll booth attendant on the PA pike told me I was driving a really nice car ..What is it? A Toyota Avalon... COOOL was his comment as I drove off smiling.
Jim in WI.
Results:
I was given a case # by each and essentially told that they are sorry that I don't like the seats and they will report it to engineering but thats it.
I'd like to know if anyone gets the XLS seats installed.
No problems with my 2005 - having it checked out on the steering recall.
I truly doubt there was a 10% increase in MSRP. Dramatic price hikes only happen when cars were all selling out at full list price at the old price and that was not the case with 2005s.
P.S. This is my third avalon. I love this car
took it in this morning, dealer had the steering column replaced in about 2 hours - apparent cost of the fix about $300.00.
went over to the parts dept. while I was there to pick up a set of wiper blades - nobody in the dept was aware of what kind of blades are actually on the car. After some time trying to find it in the computer, came back with a total of $54.00 for both blades and they would have to order it! Anybody out there know a way around this?
It has happened since I got the car (5K miles) but was infrequent then and I attributed it to the ABS. Now I am not so sure, and it is happening more.
Anyone have similar experiences? Any ideas?
D.
turnoverantenna on the rear parcel shelf. Reception is pretty good so far.As far as activation goes, I contacted Sirius via their 800 number, told them that I had a new Toyota with Sirius installed and they said that I would get the first 3 months of service for free.
I checked it out. I went to Google and typed in Toyota Avalon recall and got a website that describe the steering problem and gave me the phone number to call. I guess since my car was purchase in June, they fixed the problem at the factory or the dealer. Again, Thanks!!!!
Do you have the Limited Avalon and are you integrating it with the existing Stereo?
Thanks for the info
LJS
I have owned 2 Acuras and now a Avalon Limited. The major difference you should consider is that I have found Acura to offer far superior service. While i am aware that this relates to the individual dealer, I have found that when speaking to each on a corporate level Acura responds in a professional manner while Toyota does not. It is truly a shame because I think the Toyota is a better car Just my 2 cents.Good luck!
