Visitor Agreement.
http://www.pickuptruck.com/html/newyork/mazda/bseries.html
The 2.3L will be available in the fall. That's up from 119HP in the current 2.5L. I'm not sure if it is all-new or a derivative of the 2.0L used in the Ford Contour and Mazda 626. I read somewhere that the same engine will be in the Ford Escape/Mazda Tribute this fall. Right now, the Escape/Tribute uses the 2.0L.
134HP is only four more than the 130HP 2.0L, but I assume it has been tuned for torque not HP.
The article is about the 2001 Mazda B-Series but it'll have the same engine in the Ranger.
Anyone else have any good rates going on.
Floridian
I feel the same way about my S10. I remember when I thought about trading my S10 in for a nissan in 1997. I test drove the nissan. I felt like I had just cheated on my wife. I was glad to get back into my truck and drive home.
The only way I would consider getting an new truck was if I traded it in for a new ZR2.
Does anyone know if chevy plans on offering an 2WD with a lift like the prerunner??
This is a bare-bones Ranger....no air, no radio...the luxury is separate seats, not a bench!!!
I also have a 91 S-10 4cyl 2.5L with an auto. It just turned 100k miles. I've owned it since 60k miles and the only thing I've had to replace are front brake pads, and a water pump, which I did myself for $40. The TH 700R4 auto transmission is a very strong and consistent performer and it makes a good argument for automatic transmissions. At lower speeds, this truck has more power than the '99, and actually gets about 1mpg better or so.
My friend has an 87 S-10 4cyl 2.5L with 4-sp manual which has been used for work all it's life. It has 291k miles on it, original transmission and engine. It is rough and shakes but refuses to quit. It starts every day and goes to work. Treated correctly, the Iron Duke runs like the Energizer Bunny.
The Ranger and S-10 are remnants of a simpler age of automotive technology. Simple, overhead valve engines, live axle, regular shock absorbers, leaf springs, and an honest to God manual shifter that connects directly to the transmission. It's ashamed these kinds of vehicles are being phased out. Mustangs with IRS and big Chevys with front wheel drive are signs of the future and it's ashamed.
Bottom line, the 4cylinder is perfect for a commuter vehicle and light hauling, but I wouldn't try towing with it.
Jeff
Sorry for the topic change!!
Mileage:1800 km, 3 weeks old- erratic speedometer and sticking,squealing rear brakes when driven more than 80 km at a time. Dealer said there was nothing wrong.
Mileage: 25000 km, 9 months old- rear U-joint goes bad.Take it to dealer for repair.Moron GM mechanic botches the job by damaging rear seal on the transmission,resulting in an oil leak and destroyed transmission two days later. Dealer denies all responsibility, forced to go to another dealer to have transmission replaced.
Mileage: 35000 km, 10 months old- very noisy lifters when engine is cold.Dealer says this is normal.
Mileage: 80000 km, 2 years old- fan clutch fails, truck out of warranty, pay GM parts dept. $120 for new one. Fan clutch fails again at 120,000 km. Buy an aftermarket fan clutch,no more problems.
Mileage: 105,000 km, 2.5 years old- failed lifter.Take truck to family friend mechanic. Checks engine out, discovers collapsed piston in addition to the failed lifter and worn out cam. Gets engine rebuilt for me. This truck was never driven hard.
Mileage: 125,000 km, 3 years old. Paint is flaking off bottom edges of box just behind the cab. I check out other 1995 S trucks and discover this is a very common problem.
This is the Best One! Mileage 170,000 km, 4 years old: Stopped at a traffic light, a Jimmy blows by me at 60 km/h on the grass to my right. He barely missed me and the three people standing on the corner. I drive on and start to wonder if I have working brake lights. I don't. I got the truck home and pulled out the wiring harness for the tail lights. Discover that the ground connection was weather proofed with duct tape!!!! I gave a sharp tug on the corroded wires, and I had instant brake lights again! YEE - HAW!!!! Love that GM life threatening quality!!!!
Mileage:120,000 to 225,000 km: chronic hard starting problems with even the slightest bit of moisture in the air. Replacing the ignition module helped for a little while, but did not solve problem. Distributorless ignition is a good idea, but not when it is placed low on the motor where it is constantly being hit by road spray. Something the idiot GM engineers must have realized, because later versions of the 2.2 motor have the ignition module and coils near the top of the engine.
Mileage:225,000 km, 6 Years old. get rid of this GM abomination, replace it with a 2000 model year Mazda B3000. No squeaks or rattles! Tight and solid! Good paint! A motor that isn't completely gutless! No more electrical problems! What a relief!!!!!!
wannaranger
Good luck in your search.
Harry
I'm definitely test-driving a 5sp 4cyl when it comes out. I'm interested in maximizing the MPG on my next truck (I currently have an old V6 Ranger). Obviously, I only need a light-duty truck.
Whats with that,last year you could order options seperately, this year it's all or nothin.
If I buy a 2001 ranger 4 cyl standard shift I wiil to Truck shop and have asliding rear window installed and a electronics store to have a cassette/CD alarm installed at fords lost.The only thing I won't get is a 7 foot bed,oh well.
BIGMAX
Also my mom just got a 2000 S-10 LS w/ 4.3L V-6 auto with 5,000 down from her father and I tell her all the time how much it sucks. The fold out seats in the back squeak over every bump in the road. She went to the dealer numerous times for it and they claim they tightened bolts, but the problem still persists. The passenger seat has to be all the way back because it doesn't latch. That's what I call cheap. This truck costed $23,000 and it's only a 2WD and no power anyhting except steering. I changed the oil in it yesterday and I foufn out that the oil plug had magnet on it to trap all the particles in the engine. I thought, that's the most intelligent idea i've heard from them. The truck has almost 16,000 miles and I say it's okay, but I don't think that truck will last 100,000 miles.
So if anyone would like to disagree about Ford, go right ahead! For you Ford fans, if you would like to know something specific about my truck, Email me. I will be glad to answer your Emails. I do not have pics at the time, but I'll try to get some if you would like to see pics.
Steve O
My current truck is an old 2.8L 4x4 5sp V6 that is reliable but barely gets 19mpg on the highway. If I buy a new truck, I'll definitely want better MPG.
AND FOR ALL THOSE WHO WHERE CONCERNED ABOUT SAND BAGS FOR WINTER DRIVING...JUST MAKE SURE THAT YOU PLACE IT OVER THE REAR AXLE AND THAT THEY ARE HELD DOWN SECURE BECAUSE THE LAST THING YOU NEED IS SHIFTING WAIT TO ADD TO THE SLICK SURFACE!
4BANGERSURESHOT!
wannaranger
