00 dakota 4.7l
Ron S.
Ed
oil change - put in 5 quarts, then add about a half quart when started, warmed and then shut down to 'top off.' one of our posters puts a little oil in the filter first - before installing it; if you do that put in about 4 quarts, then top off after running a couple of minutes (shut it off first). just DON"T overfill the crankcase.
Bookitty
times, however anytime you do you risk
your life and others on the road with you.
Be aware some nite when your driving 110MPH
and you come up on a slow vehicle..........
lets just say it won't be pretty. And besides
what fun would this chat area be if we have to
keep breaking in newbies all the time.
p.S. I have carried a Mont Blanc pen for over
2 years now. It is the finest writing instrument
I have used.
Later Renegade
He was running S rated tires (I don't know if these were stock or not - macguy you may know), and he considered these ample for his needs. S rated tires are considered good for speeds up to 180km/h, 112mph. He was clocked on the main straight (fastest point on the track) at various speeds between 120 and 130 mph. I believe the fastest speed was around 131. Anyway the rubber overheated and his left rear failed in a major way - looked like Mansell in Australia all those years ago.
He never raced again.
If you are going to drive fast, get the equipment. A stock Dakota is not designed for it and something will fail. It may not be on your truck, it may not be today, but sooner or later if people overdrive their tires, or their vehicle, it will fail. In all probability you won't get another chance to make that mistake.
Mont Blanc for as long as I can remember.
Opinions are like ball point pens...
.......well all have one. LOL
renegade
We are talking 4x4 trucks here with AT tires etc. Hardly the recipe for a street legal race machine.
Rode in the SuperCrew for 50 miles (wouldn't let me drive it) and drove the Dakota to the office and back (10 miles). Bought the Dodge. Didn't even wait to order one. I have since driven the SuperCrews for several days each; white one for 3, black one for 2 (300+ miles total), and been offered my original cost back to me to trade for the Ford. I've also driven a Sport Trac for 35 miles. They just are not 'quite' what I want or need. But for many others either Ford will be a fabulous choice. I have since talked a good friend of mine into a black Sport Trac.
Send me an e:mail for an off post detailed discussion if you'd like. I might have some other thoughts that would surprise you.
robert
I have a cab-high cap on my Dak. and have traveled several thousand miles in it. Sure, there is some flexing of the frame but this is exactly why the cab/box are separated from each other. All real trucks have the cargo section separate from the passenger compartment for isolation and other reasons.
I know of a Veterinarian that travels from farm -to- farm with a Dak. The box has a special 'insert' that has compartments all around it.(Doors, drawers ...etc) This man WORKS out of his Dak. and carries a load at all times over several hundreds of miles a day. He has gone through many trucks in his career and says that the Dak. is by far the best yet!!
It's not so much what I'm going to haul as the Ford guy made it sound like he's seen Daks driving around with their beds flopping around, regardless of the load. He also hinted that the Daks beds are not structurally sound and would breakdown off the frame after heavy usage! Man, these sales people are really tough on each others brands! When I came in after the F-150 test drive, the sales manager was like: "just ask yourself this: how many Chrysler products are in the Top 10 vehicles sold every year in this country? But, there are 5 Fords and 5 Japanese brands. Enough said!"
Okay, dude. let's kick the competiton around a bit more, eh?
What's your take on the interior construction of the dak vs the Supercrew? I've seen posts on the Ford board about the Daks front bench/buckets being thin and subject to wear, and also uncomfortable on long trips (which I do a lot of).
Pam & Brigitte at Benny boyd in Lampasas, Tx. executed flawlessly. They never tried to sell me ANYTHING; instead they asked what they could do for me. Over and over. And I worked them very hard. They're still doin' their job for me and will continue to get my business. But they are the exception - not the rule.
I say: research your needs / wants, drive the trucks that your research shows to fit, back away and do some more research, narrow down your choices, drive em again, go get some other folks' opinions if you want, drive em again, etc. Until your choice is CRYSTAL CLEAR. If it's not: repeat.
From personal experience with several trucks and zillions of miles: if the truck bed is not moving (way) separately from the cab, you're gonna be in BIG trouble really quick. Separation is also the reason nerf bars or tubes shouldn't EVER attach to the rear bed frame AND the cab. They should NEVER be tied together.
And ya'll might take a look see at what the salesmen have at their residences. Not what the dealer has them drive home. I did a couple of years ago and it just blew my mind. foodforthought
Bookitty
Bookitty
Also, keep in mind that the Supercrew sells for 5-10K more than the QC.
Bookitty
The big difference is the console. The bucket console is narrow, but deep and is permanently mounted to the floor. The bench console is really the back support for the middle fron seat laid down. This means it is wide, about 10 inches, but also shallow. For those into drinking, you also get better cup holders with the bench. The buckets have fixed-size cup holders whereas the bench's are adjustable to handle a variety of drink sizes.
Buckets have the 6-way power option, but that is not available for the bench.
Hope this helps...
KnK
Satisfied now because I really need the fold down center console for my job. If you don't, seriously consider the buckets. My only issue with the buckets is that deep, narrow center console.
mwolak: is the legroom the same for the entire back seat in bench vs buckets and only improved upon in the center for the bench? If the bench offered more rear legroom along with the fold-down console, that would be enough to convince me.
KnK
asta - w/ the rear seat 'raised' as it is, legroom is really quite decent. And I believe (though could be wrong) that with the buckets a little better for taller drivers, it could be that they're a little lower - closer - to the floor. Anybody?
As far as the added leg room in the back center, it could be that the console, being attached to the bench, can be moved forward, while the console with the buckets is fixed. I don't know what those dimensions are. My order is in restriction limbo. Maybe folks can take a tape measure out and measure their bucket/bench min and max knee clearance.
Allen
I did fret about the difference between the two as well but the clincher for me to go with the bench was when I noticed how comfortable an armrest the lowered center console was vs. the narrow plastic of the buckets. I think it comes down to personal preference though. The extra inch of room is almost negligible (at least for me it was). It looks like it'd be a nice writing table too...
But the bench seats are nice with the center armrest and the drink container is a great idea that is adjustable all for $200.00 less than the bucket seats.
Jim
#511 of 511: No spark plug wires (bpeebles) Fri 10 Mar '00 (06:33 PM)
(jcody1) You are just touching the tip of the
Iceberg on this engine! The 4.7L is very different
from the 1960s-based engine it replaces.
It can be classified as a true Hemispherical
engine. The spark-plugs are BETWEEN the valves.
Here are a few URLs that provide more info on the
4.7L.
Award:
http://www.wardsauto.com/best10/99info/dcc47v8.htm
Mechanical Review:
http://dodgeram.com/technical/cammer/4_7_v8.html
http://www.4adodge.com/glossary/torque_charts/index.html?quad
The plant where it is built:
http://www.autointell.com/chrysler10.htm
http://www.autointell.com/chrysler22.htm
