00 dakota 4.7l
here - long story.
Anyway, I'm back but don't have time to read the
1,000s of posts I missed on various topics - so if
anyone asked me something sorry, I missed it, but
feel free to ask again.
Now we'll wait and see if the insulating properties are sufficient to eliminate the condensating problem in the tube. For those of you who are interested I'll report back in a couple of days.
"No MIC BUS Message "
The description is
"No CCD/J1850 messages received from the Mechanical Instrument Cluster (MIC) module"
What does is all mean? The Service Manual describes several different 'categories' of failure 'modes'.
- Pending
- Conflict
- Suspend
"Pending" failures have to be detected under the very same 'conditions' before they are really considered a failure. Given this, and the fact that your MIL (Malfunction Indicator Lamp) did NOT come on, I suspect you are seeing what is known as a "pending" failure that has only been seen once in the last 40 warm-up cycles under the very same conditions.Ill bet you Dak has not SEEN 40 complete warm-up cycles since the battery was first connected. (There is a definition for a warm-up-cycle in the manual)
Give it some more time... You mentioned yourself that it only has 100 miles on it. The on-board computer is still "learing" how to control the engine/transmissinon. The system is quite complex and must be given the oppertunity to program itself under the various conditions. My Dak is still 'learning' how to idle under some unique conditions and I have over 4K miles on mine.
I highly recommend to anyone that has an intrest in the computerized engine management of the DAK 4.7L... Get the Service Manual.
Keep in mind that I am the type that enjoys a good read through a service manual. Too bad all of the 'good points' from the various auto manufactures couldn't be combined into one vehicle.
Some turn the alternator on/off depending on engine load and to assist engine braking.
Others (Like dodge) have extensive diagnostic capabilities that are quite capable.
Still others have different intake tube lengths that are 'selected' for torque improvements under certain conditions.
One (I am aware of) even 'programs' the valve timing on the fly for great power and superb economy.
Unfortunately, very few of the 'grease monkeys' that work on cars are even aware of these technological abilities. Thus, I am very critical about who works on my automobiles.
thanks,
robert
Basically, has anyone notice water or foam where it really matters...in the crankcase / on the dipstick?
Chad
I follow many fora (not just edminds.com)in an attempt to get the best possible basis of this 'condensation problem'. I can say for CERTAIN that no one has reported any emulsified oil on the dipstick of the DC 4.7L engine.
WIth that said, I have read of the oil-fill-tube being completely filled with the so-called 'foam'. I hav also experienced it personally. This condition plugs up the PCV system creating even WORSE conditions within the crankcase.
Best advice... Wipe out the oil-fill tube regularly.
I soak 2 paper towels every few days since I found the plugged PCV system initially.
On the following modes:
A/C Max
A/C floor/vent
A/C vent only
heat floor/defrost
heat defrost only
Off the following modes:
heat floor only
heat vent only
I use the term heat only to diffrentiate between A/C on and A/C off since even in "heat" mode, the temperature dial can be turned to the coolest setting and be blowing fresh unheated outside air.
Chad
Bees
-POWER (SMOOOOOOOOOOOOTTHHHHHHHH)
-LOOKS
-CONVENIENCE(DOES ALL I NEED)
-ROOMINESS
-FOG LIGHTS (HAD TO RE-WIRE MY MUSTANG FOR FOG
ONLY ILLUMINATION)
-HEATER(IT HIT 50 DEGREES HERE TODAY AND IT
WORKED WELL)
-PRICE (WHEN COMPARED TO SUV'S)
DISLIKES
-SEATS (TOO MUCH LUMBAR BOLSTERING)
-FORWARD CAB PILLAR(OBSTRUCTS FORWARD VISION)
-PAINT QUALITY
As you can see not too many dislikes. This thing HAULS [non-permissible content removed] for a stock pickup and I should know as I have owned an F-150 Lightning(1993. Its not quite as fast as that was but I am impressed. And is it smooth? Hell yeah. I also own a 1995 mustang gt with an AUTO and before I put in steeper gears and a few extra goodies I believe I would have been hard pressed to beat this new truck. She only has 400 miles on her so far so as the mileage increases so will my posts.
Wire is quite flexible and can be 'trained' to go where you want it, Just bend it with your hands as sharply as needed. (I used to wire $500,000 computers for a living) NEVER PULL ON A CONNECTOR!!
Again-- The valve-covers are of magnesium which has very different properties than steel or even the plastic valve-covers on some engines. The shop manual warns against ANYTHING touching the valve-covers or risk wearing a hole due to vibration.
combo? Someone said the shifting can be a bit
rough.
I have placed an order for a 2K 4x4 SLT Club Cab 4.7 5 Speed. The dealership is in Kellogg Idaho. I live in North Pole Alaska. The drive will be about 2300 miles. Does anybody have any suggestions concerning a long trip as soon as I leave the dealership. Are there any special things I need to do or watch on the drive? Thanks for any info.
Greg
Greg
As I recall the owners manual has one driving pretty slowly for the 1st 40 miles. Then "occasional bursts of full-throttle acceleration" for some time after that.
My experience with breaking in a modern 4 stroke OHV engine is that one must consider the seating of the piston rings. Much of the rest of the engine has such tight tolerances that traditional break-in is not the same as it once was. (ie...The seating of the valves is exceptional in toady's new engines)
Keep it cool and make sure there are occasional bursts of acceleration and deceleration. The oil is very busy keeping things cool and washing away any machining residue. The deceleration is the best way to seat the rings. (high vacuum in the combustion chambers.)
The 'tension' of the piston rins on the 4.7L is considerd 'high' for a modern engine. However, this has been shown to increase the reliability of the ring-sealing on high-milage engines.( The cast-iron block and carbon-composite girdle should increase reliability too!!)
DO NOT MAINTAIN A CONSTANT SPEED FOR ANY LENGTH OF TIME!
Thanks...
i hope this helps
Bookitty
You don't say what the rear end is - I assume the 3.92, but it sounds like you are trying to tow in excess of 7,000#. Sure the truck will probably do it - but you will invalidate the warranty in an instant, not to mention wear out the engine, clutch etc.
My personal rule is never to exceed 80% of the stated weight limits for any length of time, but that is probably overkill - certainly no more than 90% for me though.
houtslaw - a chip in the 4.7????? Guess we're just going to have to disagree on that one.
This part will not remove the top speed limiter.
Thanks Marty@jet."
A Houston Dodge performance tuner that I have heard NOTHING but good things about, replied (& I mean while I was on-line @ 2:00 AM on night): "no info on the speedltr, but we;ll have it once we have the computer...
doing lots 4.7 work here..take care mpi" jghunter@nol.net
Hypertech is still pondering sales figures.
However, I'm interested ONLY in mileage - this truck is 'way muy fasto' for me. The HP curve is 'peaky,' and my 20 years of racing experience with spiked (re: flat, tall curve - high redlines, and quick dropoffs) Porsche & Vette engines is that chips very, very rarely help overall driving... spend your money on tires & fatter antisway's. Your big power gains will come from the simple cat back/header/air cleaner/underdrive pulley/added fuel delivery stuff. PLUS, this engine has those odd little plugs that may make supertuning a bit troublesome. Especially with a chip at this point. But what am I talking about - this is a TRUCK, not a race car! Let's get some more mpg first.
My speed limiter is 'not working at this time' (patience bookitty, nearly ready to divulge - I DO value my warranty), I'll tell all soon - Promise.
Sd maybe in the spring; I use my 4.7 auto as a daily driver and very light hauler; boxes to storage, crap to the boat, Costco/Price club warehouse type runs, boxes to storage from the office. Thing really rocks as it's set up so I guess I can live without a chip. V8 power makes me grin all the time; the other little truck people don't know what to make of it with their 4 bangers and sixes; and the size of the truck is so perfect. Tundra's and F150's have a huge step up and the 2 wheel drive version of the Dakota is just an easy entry deal with the club/crew or whatever they call the extended cab provides a place for very occaisional people hauling and locking up of briefcase etc.
Now that the clicking has stopped I'm really getting happy. Miles are approaching 3k and it's really starting to run. Been varying the speed a lot and standing on it at 60 with the OD off to get it to kick down into the high gear end of second. Cool.
If anyone figures out why the clicking fixed worked, let me know. JOHN
The old adage about looking a gift horse in the mouth comes to mind, but then since you paid norht of $20k, it makes sense to know what "makes things tick." :-) [I know, bad pun....]
KnK
4.7 whisper down the road and roar when i ask it,
and its all thanks to (houtslaw), that tsb fixed my
ticking and my truck is so quiet i cant believe
its the same truck, the dealer was so confused that
this would actually work, but whammo, ticky gone,
ticky gone gone.
the tsb is for trucks with the 4.7 made before nov
23rd 1999, so go get this done now, it will change
your whole outlook on your truck.
robert
Ed
covers will wear trough if the wiring looms are
touching them because they are a lighter softer
metal?
Would like to hear,
robert
4.7 . It is for a Dodge 5.2/5.9 engine .
The cheapest I found was at Auto Zone for $45.00
Johnboy9
henne - scroll up to Post #46, this Topic for bpeebles' answer. Works for me.
performance chip for this knew bad boy on the block?
would like info on cruise and speedlimiter eliminators
robert
