The dealer said it is most likely the dash unit that is bad and he said he had at least one other car with that same issue. The part(s) are on back order so for that other customer he swapped the unit from a new car in inventory and will put the new unit in the inventory vehicle once it comes in. He said he would do the same for mine.
Just curious if anyone else has had that happen to them?
Joe
Getting my XM and spoiler installed tomorrow -- oh joy! Looking fwd to breaking this baby in on my road trip at Xmas -- let the good times roll!
-Dirk
-Dirk
I agree it's good that the intelligent cruise turns off in the rain. However, you CAN use conventional (fixed speed) cruise with the wipers on.
To activate conventional cruise control: When cruise is off, press and hold the "cruise on/off" for about 2 seconds.
Pete
Dealer couldn't find an exact match in inventory, so I ordered it - I'd rather wait to get exactly what I wanted.
Black over graphite with aluminum
Journey and Tech packages
Aero
Now the hard part...waiting until it gets here!
Z
Waiting is tough! I ordered mine in August and it just came.
You may want to work with your dealer to see if they will monitor the cars that come into the country to see if there is an un-claimed one matching your order.
Either way - it should be worth the wait!
How are you liking it so far?
Any surprises - either good or bad?
Z
Am considering the M35 AWD but concerned how it will drive in bad weather.
Currently drive SUV..
Wish I could have more confidence in the QX 56, but reviews have not been good.
Any thoughts would be appreciated
I am one of those lazy types who does not want to switch-out tires every season. I am sure it would be better on turns with snow-tires.
I noticed once driving across Nevada at high speed with a car with an instantaneous fuel mileage readout that it took most of a half hour before the mileage quit going up, and that was with a morning temperature no lower than 40 deg F. It'd probably take an hour or more at 40 below.
Next summer, take your car out somewhere warm and drive it at a continuous 100 - 120 kph until it's fully warmed up. Your mileage will have varied.
Bottom Line - The car is great and I made the right choice!
But here is some go the Good, the Bad, and the Ugly:
GOOD - The car drives great - just like I remember from the test drive many months ago. Not that you care (assuming you are actually in Dallas) but I picked up the car on the day it snowed a few inches and I took it out on some unplowed streets. All I can say is WOW! The M35x can take snow filled streets and do turns at 30+MPH with out leaving the lane. You can really feel the computer adjusting the brakes, transmission, and engine to keep you in control. My wife has an all wheel drive car but without all the added stability systems - this is truly the next generation of control! WOW!
If this is the first car you have without a key - you will love it. Easy in and easy out - I never take it out of my pocket - this is an example of worthwhile technology. I set up one key with all the seat and mirror positions for me and the other for my wife (if I ever let her drive it) and this works perfectly!
BAD - The tire pressure monitor is a pain thus far. Since it is cold, the pressure goes down naturally and this damn thing is beeping. Ignorance was bliss before they invented this technology - now I need to pay attention and deal with the issue. I guess this is safer - but this has become such a constant bother!
Also, I like to put my briefcase on the front passenger seat. It is not large or heavy - less than 20 lbs - but it is setting off the seat belt alarm.
As reported in these forums, gas mileage has been really bad - about 12 or 13 MPG even though I am driving very conservitivly- I assume that it will get better as the car breaks in.
UGLY - Make sure the dealer orders your car right. Go in there and look at the order - make them give you a document. After waiting since August, my car came in with the wrong sat. radio. Also, make sure the dealer is checking inventory coming in - these cars constantly come in and unless you ordered some really off the wall configuration - they should be able to find the car sooner. My dealer has lost a lot of points with me because that said they would do this but they did not. They ended up finding me the RIGHT configuration in stock at another dealer to fix their order error. I feel I could have had the car much earlier than I got it.
Hope this helps!
Good point on the seat belt. I don't have my M45 Sport yet (looks like a 2-3-month wait) but does the M continue to nag you re seat belts (my E500 only shows a warning light but I've been in other cars that "shout" at you every minute)? If yes, there must be a way to get the dealer to disable the dinging or passenger sensor...
Just have to ask, what happens if you connect the seat belt and leave it connected across the back of the seat when there is no person in it? Too simple a solution?
I also have the DVD and moonroof rattles. I believe there are fixes for the latter from your infintihelp post above, but have you had luck with your dealer fixing the former? In addition, I also have the ticking in the rear and the squeaking of the dash after sitting in the cold.
Any one of the above is not really enough to warrant a trip to the dealer, but this thing is a symphony of creaks and groans...
Any light you or anyone could shed on this would be great.
S
With a few data points this winter, IMO this setup handles better than previous FWD cars I have had with all seasons on.
I am a believer in snow tires.
S
I've had my M35 Sport with Journey&Tech for about 6 months and I definitely can't complain...well I guess I CAN complain a little.
Not that it's that big of a problem but every now and then when I start the car it sound like my speakers give this weird feedback noise. I tried taking it to the dealer but it wouldn't make the noise (go figure huh?)
Any suggestions? It seems the noises are becoming more frequent and I'm considering making another trip down to the dealer.
My dealer on Long Island (Atlantic Infinity) had a difficult time searching for my M35x (Premium Package)
He did call me to give me a Vin number for the exact vehicle (Sand with Wheat interior) but had to go to another dealership. After making inquiries about the Vin number with Infiniti Corp, (1 800 662-6200) they informed me that the car left Japan on December 6th 2005. Here are my questions: Can this car be tracked as it crosses the pacific and heads for the east coast? (any website for this?) Also, the car is coming with the high polished Chrome wheels (18 inch) which I told my salesman I didn't want. Do you think infiniti will let the wheels slide or replace them with the standard 18 inch titanium hubs?
Finally, if it left on December 6th from Japan, can anybody approximate a date when It would arrive at my Infiniti dealer on Long Isalnd NY?
Anyway, glad to be a new member here
TIA for all replies.
Alan Russell
I did experience severe wobble above 45mph due to the snow behind the wheel that I couldn't remove.
........ $51750 without tax.
Was this a decent price?
Alan
I have a M35X with ~5000K. I have been lurking on this forum since July and have found it very helpful. Headlight adjustment instructions was a tremendous tip!
With the arrival of snow, I am wondering what people's recommendations are about which driving features to turn on/off when there is fresh snow or ice on the road. The manual isn't very helpful. Should snow mode be on? Should VDC be off? They seem to do the same thing but in the opposite direction.
Any advice appreciated,
Jon in Philly
Here's what the manual says:
For driving or starting the vehicle on snowy roads or slippery areas, turn on the SNOW mode switch and the indicator light on the switch will illuminate. When the SNOW mode is activated, engine output is controlled to avoid wheel spin. The vehicle should be driven with the Vehicle Dynamic Control (VDC) system on for most driving conditions. If the vehicle is stuck in mud or snow, the VDC system reduces the engine output to reduce wheel spin. The engine speed will be reduced even if the accelerator is depressed to the floor. If maximum engine power is needed to free a stuck vehicle, turn the VDC system off.
IMO the car is intelligent enough to work with both and take advantage of both.
They're both intended to detect slipping and respond accordingly. The snow mode sounds like it adds additional protection. So my guess is that driving with both in snow will generally be the safest approach.
Pete
I am new to the site as far as replying but have been following several forums for some time now. Haven't seen to many people posting that have bought in Chicago. I am interested in where you purchased your M35 and what kind of deal you got. I need opinons and feedback on deals on either the M35x or the M45, best deals and easiest dealer to do business with.
Thank you....
from what I understand the snow mode is there to make sure that your AWD is engaged, i.e. the power to the front wheels is there right away. I don't have the snow button on my M45 sport so I gotta believe it's only for AWD cars.
As I write this there is a G35 loaner in my parking spot because my car is in the shop for oil/filter change and the headliner/sunroof/DVD rattle. I hope the tech who works on it today isn't the Beltone Customer of the Year, a problem I've had in the past, where they say they can't hear anything. My wife and kids admit to hearing it and they think I'm way too aware of the rattles. We'll see what happens.
Otherwise, the snow in Chicago has allowed me to see how this (M45) baby handles, and i must admit, it was better than I had expected. When I get back from vacation I think I'll throw some snow tires on. The dealer likes the Blizzaks but I had great experience with the Michelin Pilot Alpins on my 2000 S500. Apples to apples (no snows) this handles MUCH better than the Benz in the snow.
Right. I believe it's only on AWD cars, and was answering with that assumed.
Pete
I purchased my M35X at Fletcher Jones on LaSalle St in Chicago, they dealt a bit off the list ($2000) and were extremely pleasant, low-key, to work with. I had a bad experience at Infiniti of Lisle, they wouldn't deal and were pushing hard the colors they had not the one I wanted so I left. This is my second bad experience with Infiniti of Lisle but I can certainly recommend Fletcher Jones. Service department at Fletcher Jones is average though.
