Rotors rust, plain and simple. They're steel, not stainless.
This is surface rust... they're not rotting all the way through, but you will always see rotors accumulate some rust in the areas where the pads do not touch.
These ares will only show signs of surface rust if driving through wet conditions and then parking the car.
This is the cause of that dragging grinding sound the following day when you first use the brakes again.
Over the years, the vented sections in the center of the rotor will show the worst signs.
Completely normal.
The TL is a sports sedan which I find to have a good ride/handling compromise. One of the reasons I chose it over an Infiniti G35: The TL had a smoother, quieter ride. Now compared to a Buick or Caddy DeLandYacht, the TL might seem rough...
You can trade any time you'd like. Just be prepared, unless your dealer is feeling rather saintly, for a financial hit!
No, I don't work for Acura. Just enjoy my TL!
Maybe it is your tires/alignment? You could talk to the dealership/service dept. Let them know that your car seems to be much rougher riding than any of the TLs that you test drove, see if they have any thoughts.
My '05 TL is Abyss Blue, well shined and protected with Zaino products!
If it's black, that'd be an oil leak; green or yellow would be coolant, antifreeze, or something like that. As long as it's clear (i.e. water), you're fine.
It could be condensation from the air conditioner, which is normal for any car. This happens just after the car is turned off on warm days. Is this the case?
What do you recommend for keeping tires looking good thats not greasy?
How about something to keep dashboard clean and not greasy?
How do I keep my windows looking clean and great with no streaking?
#1 - Wax your wheels. Use whatever you use on the car and keep them waxed. This will prevent brake dust buildup, and makes the wheels super easy to clean.
For tire shine with no slime, I use Zaino Z-16.
You'll need an applicator to get the job done right... I use These.
You can get them right from Wal-Mart.
Interior products without the horrible Armor-All glare,
I like Lexol products.
A lot of people swear by Stoner's Invisible Glass. This can also be found at Wal-Mart.
I also use it, but it requires the glass to be cold, and you need a nice lint-free cloth.
Don't try using it in the sun when the windows are hot.
I suppose Windex also works.
Enjoy!
Thanks for your help!
Excellent advise, as I have also had the 3M film installed and I'm also very happy with it.
The Dealer will install this for you, but most outsource the work.
My dealer had a 3M certified installer on staff so I got lucky.
Ask the dealer before going elsewhere, since it's a much better idea to have it done before taking delivery of any new car.
Just be sure of the brand materials being used.
Some are very good....others are not.
I went looking for it, but couldn't seem to find anywhere on Acura's site where manuals can be downloaded or viewed....only ordered.
Acura's website is actually quite sad after comparing to others.
They have a fantastic interface with a virtual tour of every vehicle, which is actually really cool, but they fall way short on information.
I can't view a manual??? Silly, I tell ya!
It's not a wax though.
It's an oil based polymer sealant. The good thing about this is it's durability.
100% carnuba starts to break down at about 120 degrees, where as Blackfire claims to be up over 400 degrees. (as with most all synthetic polymer sealants)
This would be of interest to you if the car is parked in the sun a lot on hot summer days or if you only plan on treating the car a few times a year.
Nothing will ever replace the look and depth of a high quality carnuba, but these synthetic polymers come as close as they can, while offering superb durability.
A great carnuba should be replaced approx every 2 weeks.
Personally, I play with Zaino as a sealant twice a year (several coats) and then treat the car with high quality waxes between Spring and Fall sealant treatments.
Good luck!
Routinely? Absolutely.
Claying a car removes all of the microscopic elements that wear away at your car's finish.
That's why it's beautiful when it's new, and just worn and faded, with little spots of rust 6 years later.
Little things like acid rain, bird droppings, tree sap, brake dust, road sand and salt... all beat the crap out of the finish.
Claying a car removes this.
Sealing and waxing protects between claying.
I clay twice a year. Spring and Fall.
Spring to remove all of winter's horrible abuse and to get it all shiny and new for the summer.
Fall to prepare for the winter's onslaught of yuck.
Can I have this done where I've always had my cars serviced? If not, can I have it done at my local Honda dealer? The closest Acura dealer is 40 minutes away.
When the timing belt/water pump needs to be replaced I will not have it done. When they fail the repairs will be covered under the warranty and I will save about $800 which is more than half the cost of the warranty
The car, when new, came with this code on a card
If you don't know it, the dealer can help you after getting the serial number off the back of the head unit
Sounds like penny wise and dollar foolish to me.
I ask this because when I was calling around for tinting quotes, one tinting vendor mentioned to me how the TLs do not have window felt strips which require more $ because felt strips needed to be installed. I spoke to several tinting places afterwards and it was concluded that additional felt was unnecessary. Some vendors hadn't even heard of such a thing.
After noticing the fine vertical scratches on my driver and passenger side windows, I'm suspecting this is a result of the lack of window felt strips. This is the first I've noticed. What is going on here? Is this true?
Any ideas or advice? I appreciate your thoughts. Thanks!
When I start my TL-S in the morning, Check Tire Pressure indicator comes up. After 15 minutes of driving or so, the indicator goes away. What to do?
Low pressure when cold is because the air molecules are smallest. as they warm up hey expand, increasing the pressure inside the tire. The warning message is telling you your pressures are low but when you drive the friction on the tread warms the air and increases the pressure to above the low pressure warning threshold.
Very low tire pressure is the cause of most tire blow-outs. SO GET SOME AIR SOON.
Can you tell me the tire pressure recommendation that is on the door panel or in the owners manual for that size tire?
Thanks I appreciate it.
There are numerous places where replacement felt can be purchased to avoid the problem.
The tint guy is correct.
What he is charging you, however, may be a rip off.
Do some research.
