Acura has not been sympathetic they just tell it’s normal for the car to rattle.
Acura quality is about the same as GM or Ford at twice the price.
The website was corrected as of this morning. (http://www.acura.com/models/model_gallery_showroom.asp?module=tl- )
Has anyone gone thru arbritration with a car company? Seems like the next step if the vibrations continue . . . .
I have --- on a 2000 Prelude. Where I live, there are no lemon laws. Only recourse is arbitration administered by the local BBB. By the way, I won the arbitration, and Honda was forced to buy-back my 8-month-old Prelude at full purchase price.
I am almost sure it has to be related to the fuel pressure. I never have this problem in the morning. The problem is most evident when I need to drive the car back to work after lunch.
But the dealer cannot reproduce the problem. Saying everything checked out fine.
Anyone has experienced similiar problem? Any suggestions?
The new tires do not flat spot but the car does vibrate a little. I'm not sure if there is something wrong with the suspension or perhaps the vibrations are due to the rough ride that seems inherent to 17 and 18-inch tires. I think 16-inch tires with a larger sidewall give a much better ride. In any event I feel for you. I feel like a dam fool for spending 35k on a very mediocre car.
PS: My neighbor recently bought a Gran Prix (about 24K) and it rides much better than my expensive Acura TL! I’m just no longer sold on Honda or Acura products
Let me know if you hear about any real fixes... my dealer will try anything to solve the problem.
I've noticed several of the 04 and 05's on the lot that share this common problem.
If you roll down completely, all of the windows on all of the doors, when you shut the doors, usually the front driver and front passenger doors will rattle or vibrate on shut because of a loose internal door panel. It occurs on some TL's.
Rear doors however are fine and give a solid shut sound.
Strangely, if you put all of your windows up, then the door shut will be solid and free of vibrations on shut.
I wonder if there's a mathematical engineering formula that prevents bad weight distribution of cars.
I've had my 04 TL for about a year and it has always had a slight creaking noise (in the door) when i go over a small bump. I've taken it back to the dealer on numerous occasions but they can’t fix the problem.
Is this the same or similar noise that your talking about.?
Just put your window completely down and shut the door (sit inside the car). You'll hear a vibration/rattle sound which does not occur with the rear doors. Note: it's not the window that is rattling, but actually the inside door panel. I found this out accidentally while I was in the showroom and the salesperson was stunned. He didn't even have a response because he couldn't use the usual "it's normal" excuse.
This occurs on ALL 04 and 05 TLs. It does not occur on the 04 RL which i tested. Strangely, as mentioned, the problem does not occur with the rear doors.
Surprisingly, no one has complained about it on the owner site so Acura never made the fix.
has anyone noticed this?
I guess they really don't want you to run out of gas.
I've been back to the dealer several times and all they can say is that "it's the nature of the beast".
Poor quality for a $35,000 car.
HAve you taken yours back to the dealer for repair?
They could have been lying ...they are quite good at lying!
My 7 year old Buick has a better ride!
You hear the rattle/vibration the moment you shut the front doors.
thanx
See Post 1164
Just out of curiosity, I want to run an informal poll as to how many of you (who have problems with excessive creaking/squeaking/rattling) would actually consider getting rid of the car simply because you find the noises too darn annoying to live with?
Is your dealer useless on resolving all these noises? What if someone is sitting on the front passenger seat would you still hear all those noises from there?
This creaking stuff is one main single thing that's between me and my getting a TL. But from the TL threads, and my personal friends who have an 04 TL, not everyone gets these annoying stuff.
The only two things my friends complained about on their 04 TL is rides a bit firmer than typical sedans (expected), and that when driving on 50+ mph with rear windows down, the car would vibrate hard (anyone has that?).
<rant>
It's just that this has been explained several times in this forum and the post to which 'cerauli' replied had already been answered. Why can't people just use the search tool?
</rant>
Long tough week. I need a beer.
1. Rattle above driver left ear
2. Vibration in floor/gear shifter periodically
3. Vibration/buzzing noise coming from rear winshield?
4. Occassional knocking/pinging in engine (yes, I always use high octane gas)?
5. Seems as if the tires are never balanced?
No to 2, 3, 4, and 5.
Only 800 miles so far, but no creakes or rattles.
Bookmark | Reply
The thump is normal. The ABS system has to do a self test and pressurize the brake system. It doesn't occur when the car is warm as the brake system is still pressurized.
HERE THE ANWSER FOR THAT .BUT I DIT NOT TALK TO MY DEALER TO CONFIRM THAT MATTER.
Many on this forum, with new TL's, have said that their cars came with Michelins. Are the Michelins being offered only to certain regions while the cars delivered to southern california retain the Bridgestones? That would seem unlikely but I guess could be possible.
Any thoughts? I didn't question the salesman, as I've found, from reading this forum, that the members here can be more knowledgeable.
Anybody else with this problem? Any suggestions? It is a new '05 TL non-navi. Thanks.
