Toyota Tundra: Problems & Solutions
I discovered the same thing with a 1986 4Runner after a prolonged play session in the mud and water. Make this note to yourself as well. 1983 Supras aren't good splash toys either. In my wilder days I caught an unsuspecting bus rider after a rain in San Antonio left a large pool of water near his stop. I got to pay a 225.00 stupid tax for cooking the altenator and being ornery.
Dr yodt
:lemon:
1. Auto transmission not engaging intermittently. Solution-got new transmission after 3 visits to dealer, and a total of 8 days in the shop. The fact that the check engine light came on, it wouldn't shift into fourth, slipped out of third, and had to be towed in finally caught their attention.
2. On-going problem: Have a whistling/whine sound. Occurs like clockwork @ 2500 rpm and above. Most noticeable when punching it. Shop replaced TRD muffler gasket, fan clutch, belt, and now claims problem is in TRD exhaust. A couple of visits later, and I still have the
My question is, what problems have been known for these trucks? I've seen transmission and brake issues named. Anything else? I noticed some rust on the one I'm looking at, is that common thing as well? Inside the front bumper on either side of the license plate bracket there is rust. I also noticed some rust stains (or else red mud stains) on the carpet inside the truck. The dealer says it's a Toyota Certified used truck, but it looks to me a lot like a flood victim.
I was very impressed with the ride and drive of the truck. The price they want is $15,990. Carfax showed 2 previous owners, but was clean. Any advice? Thanks,
idntnvu
Second, "Check Engine Light" for the oxygen sensors. The dealership says there are 2 of them, but I found 4, two on each exhaust. There is a recall on them but I missed it by mileage the first time and then again when Toyota extended it to 60,000 miles. About $450 to change both, but talking to others they agree there are 4. My light came on over 20,000 miles ago, I'm assuming it is one of the downstream sensors because my mile is still 16 with the K&N air filter. (another MUST).
My Left corner light cover was cracked and I bought a new one.
The light appears to be anchored by a plastic arm with a philips screw, however, it is not a screw but rather a plastic push pin?
Before I try to push it up and possibly crack one of the little plastic tabs, I was hoping someone might have a tip for safe and easy removal.
Thanks so much.
i have a 2000 tundra 4x4. The problems i have been having are, for one that everyone knows about, is the brakes, They VERY, VERY POOR, putting it politely. The O2 sensors go out. i have had to replace 3 out of the 4 on the truck at around i believe 140$ each. The trans. does not shift correctly. Having to send off the valve body to a performance shop. Cracks in the exhaust manifold. Drive shaft misalignment that causes shaking at certain speeds.
Bought a toyota because i thought i was buying something that would last. Instead i bought a toyota that has caused me problems. Toyota does not fix anything because they figured out the problems after my truck was out off warranty. TOYOTA DOES NOT CARE. I will not own another TOYOTA! :mad: :lemon:
Michelin LTX they stay balanced better than Goodyears and work very well on both trucks here in Texas.
I have 43000 on the Double Cab and no problems what so ever! Have replaced the tires rims with 20" Hot Wheels and Michelin 55 series LTX.
I have an 05 TUNDRA 4x4 the original tires are P265 70 16 and im thinking about changing it to LT 265 75 16. WOULD IT RUB?? i have stock suspension... the only difference is from 70 series to 75 series. and its also a little beafier.. P= passenger and LT= light trucks.
thanx in advance
BUT!!!! i only have one thing that is not good on my 05 TUNDRA, it happened twice now, when i first start it, the starter will stick and keep on turning but it dosent fire up even when i let go of the key...it would keep on turning untill i turn the key to off position and start it again then, shes fine............this ever happen to any of you???? pls let me know
YOUR KINDNESS AND CONSIDERATION REGARDING THIS MATTER IS HIGHLY APPRECIATED. THANK YOU
Its good to hear that your truck is working great for you. At 5000 miles, your maintenance light will turn on, its only there remind you its time for oil change. Now if you bring it to the dealer they will reset he light for you, but if you do your own oil change, youll have to open up your manual to page (i believe 179) on how to reset your maint. light. Now just incase this is how you do it. make sure your key is in off position, now press and hold the button in you speedometer mileage while turning the key to ACC position and hold it for 10 o 12 secs. until you see the mileage reads -000000 and then your maint. light is gone and been reseted.
-mike
Thanks for any input.
I have a 2001 Access cab and had a lot of problems with vibration after the truck hit about 30K miles. The only way to solve it without throwing a lot of your money away is as follows:
1. Load balance the tires (not just a quick spin balance). It costs more, but is worth it.
2. Have the front end aligned using DJ's Specs. You can find these on Tundrasolutions.com. The standard Toyota alignment specs are not the best and have too large of a margin for error. If you can't figure out the specs, give me your email and I will respond that way." :shades:
Cheapisgood
Ken
Hope this helps.
Ken
1) In your experience have you seen or heard of other tundra trans crapping out like this?
2) get a Reman trans from the dealer or let AAMCO rebuild it?
The following are copies of several messages off Toyota Solutions forum, hope it helps:
My Ticking Noise is Gone!
Our Sequoia had been suffering from that slight ticking noise that's been talked about here. It's the one that appears to be coming from behind the centre console. More audible in cooler weather. Varies with the RPMs and can't be heard outside the vehicle.
Well I had the truck in for an alignment and rotation on Saturday and I mentioned this noise to them. I also told them what I had read here about it possibly being due to the ground wire from the fuel injector wiring harness transmitting noise thru the firewall. Sequoias are pretty rare around here and they said they hadn't heard of that but would look. So about three hours later they call me and say the truck is ready.
They moved the ground wire, straightened up some of the wiring in there while they were at it, and added some insulation around the throttle cable. Boom. Zero noise. Not reduced, but gone. Completely. Man, am I one happy puppy right now. All I can hear when I'm driving it is the sweet sound of that V-8.
BTW, the work wasn't done where I bought the truck (they couldn't hear the sound), it was done at a dealer closer to me (same city), Tony Graham Lexus Toyota. Kudos to them!
AMAZING!!!! I just moved the ground wire on my '01 Sequoia from the firewall to one of the bolts on the power steering reservior bracket (my ground wire is actually mounted on the firewall on the passenger side of the engine)... started up the engine and NO MORE TICKING SOUND... something that I had been attributing to piston slap since I bought this crazy vehicle. Even took it out on the highway to be sure... all I hear is smooth running Toyota V8 sound now. Best 5-minute investment of time I think I've ever made on any car.
THANKS!!
It worked!! No more ticking!!! I would never had believed it if I hadn't done it myself. Amazing!! Thank you thank you thank you!!! (If you cant' tell, this was really an anoying little issue for me)
Took it in and left it with a Toyota dealer in Arlington, Tx for a full day. Got it back at 6 that evening as they closed up. Drove it all of a half mile, hit a road with small bumps along it, windows started rattling just as bad as they ever had.
A full day wasted with no change at all in the truck.
I've had a couple of Ford trucks that did the same thing. It's a channel problem. Difference is that the Ford mechanics seemed to knew how to repair it and the Toy mechs didn't.
There again it may be the dealer. I've bought 6 vehicles from his numerous brand lots here - 2 Fords, 2 Mercury's ( the Lemon Law was enforced on one of them) and 2 Mitsubishi's and I've never, EVER had any luck at all any with any of his service departments. Not once, to the point of where I won't even shop there any longer.
I didn't purchase my current Toy from there and must have been feelin' my oats that day I took it in. They're less than a half-mile from my office and I thought, "Well, it's only replacing the window channels. The Ford guys had no trouble at all ...."
Wrong. A waste of time. Shoulda known better.
Soooo, anyone care to discuss engine lifter clattering/knocking when you punch it ?
