BMW 7-Series Maintenance and Repair
                    Hello All:
I was out for half year, and I dis-connect the battery for my 97 740il. I came back over the weekend, and I was able to start the car after I put the battery back on.
Here is the problem: at the early begining, I couldn't lock/unlock the car/truck by using the car key. So that I have to do it manually. And then two days later, all a sudden, it works fine! I can lock/unlock the car by using the car key.
And now I still have another problem on the trunk. If I want to unlock the trunk, then I have to RE-LOCK the car again, and use the key to unlock the trunk manually. I remember back to the old days, if the car doors were unlock, then I can go ahead to push the trunk key-hole, and the trunk will be unlocked.
Does anyone know how to fix it? I called dealer, and they said it will cost me $79.99 to reset. And this is too pricy. Thank you in advance.
you could try your own "reset" by disconnecting the battery negative ground cable for about 30 minutes. seems like you cpu is confused and stuck in some sort of software anomoly. before doing this, make sure all of your physical systems are as close as possible to the same position, i.e., the locks all are unlocked. hopefully, when you reconnect the cpu will reset itself with all physical systems "synced".
My radio is OK. I just don't know how can I reset the computer. Can you give me some more directions? Thanks!
Second question, notice black weatherstripping inside front right door was painted with must have been door area, rubber is black on left side (painting is also on same side mirror cover came off), some body painting was done, job is perfect, dealer knows nothing, nothing showed up on Carfax, is ther another way to find out history of 740, and if details of work done? BMW Corp. said I can go to original dealer, but not sure if any record, anyway to find out exactly what work was done?
As for the mirror, don't do anything so permanent as epoxy. Perhaps a silicone that sets up would be better.
Hope this helps.
I've disconnect the battery on my 93 750 on several occasions with no problems whatsoever. In fact, there is a panel under the right rear seat cushion, with a negative ground connection for exactly that purpose! Disconnecting the battery resets the antitheft codes, but all that means is that you have to punch the codes into the radio and on board computer. Why is this some sort of big problem?
I am completely terrified to do simple projects on my cars and trucks. Thats why I have a 1994 LandCruiser that i have put a lift kit, Kumara Turbo Charger, and rear differential lockers on it with no help from any service department besides the one that i purchased the hard wear from.
I have owned a 318 i (88-90) 535i (90-2000) and currently a 740iL (2000-present) I take pride in the BMW's that I have owned and would not want to screw anyone elses up.
For all we know disconecting the battery might not do a hill of beans. Mge just shoot you local dealer an e-mail, they might beable to tell you in a response
I bought my 97 740il a little over a year ago and have begun noticing that it sometimes shakes a bit when I brake at about 40-50 mph. It still drives really smooth at high speeds, but this shaking is frieking me out. Any thoughts before I go to the dealer? Thanks!
I tried what you suggested tlcman and didn't feel anything in the peddle. The shaking/vibration also sometimes occurs when I'm on the accel, but only right around 50mph - any faster or slower and it's pretty smooth - and it doesn't occur on all roads, definitely a strange problem. Someone who had a similar problem thought it may be a balancing issue (I recently went with new 18" M-parallel wheels with Conti sport tires) and suggested I get "centering rings." What are those? Any thoughts? Thanks guys.
The steering is very sensitive on the 7-series, and any imperfection in balancing or roundness can be detected at the critical speed. As expensive as they are, many aftermarket wheels are not well balanced or round like the factory wheels are.
I checked with my local high-performance tire dealer who told me he sees this problem frequently on BMW's when the mileage starts to creep up. Normal wear on the suspension/steering components make them extremely sensitive to tire wear patterns, balance and quality. I replaced the tires (Pirelli PZero Rosso's) last week with Michelin Pilot Sport A/S. Presto, no more problem! I will say that the steering does indeed feel "looser" than it did at lower miles. Anyone know of an adjustment that reduced free-play in the steering?
If you 18" wheels are not OEM, make sure they are "hub-centric", or fit snugly around the hub or dust cap. If there is any free play, you'll never get the wheels to stay in balance as they actually shift on the hub. I had this problem with some beautiful Centerline wheels on my Suburban, and Centermine did not make a centering ring for a good fit. Ended up replacing them with Axis wheels which are hub-centric and no more problems.
For anyone contemplating new tires for the 18" wheels, steer clear of the Pirelli's. They rode beautifully when new and were much quiter than the Michelin's. However by 6k miles they began to cup and get extremely noisy. The dealer rotated them (side to side) which did not help at all. At 12k miles the noise was intolerable and embarassing. Also, the rear tires were worn to the center bars. No better experience with the Continentals either!
The specific cause is (are) the upper control arm bushings, or "thrust arm" bushings as they also are called. They take a big load during braking and tend to wear out rather quickly on these very heavy and agressively driven cars--I got 55k out of the originals before vibration set in.
Unfortunately, before I discovered the root cause I managed to burn through a set of new oem rotors in only 12,000 miles--everything seemed "cured" for about a year and then the vibration returned. The next time around I replaced both the rotors and the bushings, and things returned to normal.
And if you have any kind of cylinder wall damage, well, god have mercy on your soul.
Regardless, I agree that you absolutely do NOT want a BMW that has overheated. BMW uses a torque-to-yield head bolt system, where the bolts are INTENDED to fail in the event of overheating. The reasoning is that by failing the bolts, stress is relieved on the head and block castings, preventing warpage. And that is, in fact, what happens: The block and heads (heck, sometimes even the gaskets) survive unscathed, but you are stuck paying major dinero to a mechanic to dig into the motor and install a new set of bolts, provided he will do this and will not cover his hinney by insisting on a complete rebuild.
Also, relying strictly on a gauge to give you the facts isn't always the best idea. Gauges are usually electric and hence subject to voltage variations, which affect readings. Also, I suppose you could have a little air in the coolant system. If coolant was ever added with bleeding it, that might be a possibility.
sure BMW makes mistakes. Ask anyone who ever had the upper plastic neck of their radiators crack and blow off.
Maybe your interpretation is correct. I was just mentioning that given the load conditions, ambient temperature, and water pump flow, minor oscillations of the water temperature may be a normal operating characteristic. However, wild fluctuations would still be abnormal.
I own an 88 735i. Today I turned on the A/C (I live in Florida) & the air was VERY weak on both the driver & passenger sides. It worked just fine the last time I used it (about 4 months ago.) I'm not mechanically inclined & I'm fearing the worst. Any idea how much this will cost me to get fixed? (Other than this the car runs great 201k miles.)
a) freon leak that needs to be sealed and refilled (couple hunnert bucks tops.
b) dessicate bag in the dryer has exploded sending particles into the expansion valve, clogging it. (very typical 735 trick). Figure 6 hours labor and $250 parts. (dryer, valve, freon).
c) your compressor is getting weak and this has similar symptoms to a clogged expansion valve.
If you know where the expansion valve is you might tap on it with a screwdriver handle and see if that does anything.
At the very least you should have the engine compression tested before purchase. If there is more than 10lbs variation between cylinders, don't buy it.
