I am hoping someone out there knows how to reprogram the remote/key. I recently bought my BMW and I know the dealership can do this, but the nearest dealership is an hour away and it appears the dealership wants my car for 3 days everytime I take it in for something. Very inconvenient and frustrating. Thanks.
It seems it makes sense as I have been told the diag showed there was too poor or too rich a fuel/air mix in some cylinders. I will check when I am back in France ( the car is there)
The car is running OK. It is regrettable the BMW electrics are so fragile. I sometimes have some error messages saying the rear plate lights are not working (they are) or the coolant level to be checked (even just after a BMW-service).
I regret they don't take electrics reliability courses at Toyota's. They wouldn't have trashed the 2002 model this way. (sight)
My 1994 BMW 740 IL (93-94, E32 model) won't start. This was slowly starting with the symptoms of taking longer and longer to crank over. I changed the spark plugs and even change all the ignition coils. It will crank, but not turn over. In the past, when it would eventually start it ran fine. It just started taking longer and longer to turn over until now where it will not start. When it was running I ran a can of BG44K through on a tank of gas. Any ideas I can check myself before unloading my checkbook at the repair shop?
Recently purchased the car and do most of my own work. Is there a factory service manual available on this model? If not, what is the best service manual available for this vehicle?
This may be a dealer only item and I'm not sure they even have a 7 series beyond 1994 (E32). It's not a car most people work on themselves, so probably not enough demand. Bentley Publishing does the best job for German cars but they only have BMW 3 and 5 series for year 2000 and up cars.
Funny how that check engine light keeps coming on. I just bought a 740il and within 24hours the check engine light came on and said coolant level needed checked. So we took the car back to dealer and he sent it to BMW dealer where they said it was a sensor and replaced it. Well, it has been one month and the check engine light came on two days ago and it went off today. My husband said to take it to the dealer, but it is two hours away and if the light went off, I'm thinking it is just a short or something dumb like that. I keep reading about the check engine light having problems. Hopefully it isn't anything serious since the light went off. How is a person to know whether to believe it or not???
Well it's hard to know because the engine light being on doesn't always mean you have to do something like RIGHT NOW...on some cars only if the light blinks are you in an urgent situation...not sure about your model...it would be worth reading up in the owner's manual to see if you have a check engine light with both a steady and a blinking mode.
Sometimes the engine light is activated by minor things like a loose gas cap.
Even if you read the codes the computer scanning tool doesn't tell you the defective component, only the circuit or system that is affected. So even if the dealer reads a code and is says "check the so and so", you still don't know exactly what the problem is. No car computer can do that (yet).
'97 740 IL, looks and runs great, 135K miles, when driving over 60 m/hr I get sort of a humming sound coming from the front end. Car has 2 week old Kumho sport tires, so I know it's not the tires.
See if the noise rises and falls in frequency as you speed up or slow down. See if it goes away if you shift momentarily to neutral and let the engine idle down (be SURE no one is behind you!). Try it on different road surfaces, such as concrete highway or smooth black asphalt.
I would recommend just checking on ebay for a Bentley manual (Bentley is the name of the company, not the Bentley cars) or Chilton's or Haynes manuals. You can probably find good deals on used books (or maybe CD-ROM, if you prefer).
I checked Bentley---they don't show a manual for this year and model on their website. Maybe Chilton's or Haynes makes one, but don't expect much out of it. Bentley is the best, AND factory authorized, too!
ok...head gasket is what i thought after i changed the pump...question...is it hard to replace? is there a chart or diagram somewhere that i could see to figure it out...i have changed heads on a chevy 350...never messed with a bmw...maybe i should just sell it as is...
Yes, I have had the same problem. The battery on my 740iL has now died 4 times in the last 18 months. Did you ever discover exactly what the problem is? It is a very frustrating issue and I don't blame you for thinking of turning your car in (I'm about to the point of doing the same).
okay, i checked for water in oil, no luck there. i bled the system as well. motor is fine for about 5-10 minutes and then it overheats. it sounds like the water is boiling in the motor. like i said, first time with bmw. how can i tell if gasket is blown or head is cracked without taking it to a shop. how hard is the gasket to change? thanks
You can test the coolant for combustion gases. I beleive such kits are available from like Kragen or Autozone. That would be a sure tip off. Such a fast overheat suggests a blockage or a combustion leak. A cracked head could heat coolant without adding oil to coolant. If you have high pressure in your coolant overflow tank, that's a bad sign.
when you say pressure, i am thinking of the water blowing out of the tank, and it does that. how hard is the head to replace. is it somehting i may could do? if not guesstimation of repair cost for this kind of job? thnaks
The problem is, if you suspect a head gasket and you open up the top of the engine, you have to be prepared to deal with whatever is necessary. Also this is a great time to replace belts, hoses, etc. If the head is cracked you will need a rebuilt head or a used head. Here's a link for that where you can get pricing:
So you'll need a new head or head gasket, a repair manual, an top head gasket set. I'd take a rough guess that on your own it would cost you maybe $1,000 and at a shop $2,000 or so. Even if it's just the gasket you'd want to have the head shipped out and checked and cleaned up at the machine shop.
Given that these cars aren't worth very much, you may need to consider if it's worth it, after you've determined the problem.
I purchased a 750Li earler in the year. The recommended oil change is 20,0000, that seems like a long time before an oil change. Any thoughts would be appreciated?
Some people may get as much as 20k (if you tend to drive long highway miles, not many cold starts, etc).
All BMWs dynamically calculate the service interval based on the driver's driving habits and style. Some people will get as low as 10k between service and some as much as 25k. Most people get right around 15k.
The primary reason they are able to go so long between oil changes is the use of synthetic oil... far superior to standard motor oil.
As far as your question of "what's the point of such a long interval", my response is "what's the point of short intervals like every 3000 miles?" I would rather not have to deal with 4-5 oil changes per year. Just doing it once per year is a heck of a lot more convenient... not to mention the car tells you when to do it, anyway.
By the way, BMW's been doing this for almost 15 years now.... If there had been any issues, I think they would have run into them by now.
Thanks for the response, I have just turned 10,000 miles. The cars computer is saying I will need an oil change in about 7,500 miles. I am considering paying for an oil change out of pocket instead of waiting.
I meant it was your call to stick with what BMW says to do in general or to adjust for your own driving conditions and comfort level. I run severe service conditions in my cars so I don't adhere to the generalized manufacturer recommendations.
2001 740 IL with sport pckg, 70K miles, I'm second owner since 52k. car had clean history, and really no problems. I recently got caught close to empty on gas and 'check engine soon' light came on. after filling tank and waiting a couple of days the light went off. 1 week later, it's back on. I thought it might have been gas cap but it seems secure. Is my catalytic converter to blame? car is off warranty and before I bring it in with carte blanche for mechanic I could use some ideas. Thanks in advance.
Two weeks ago, I purchased my brother in laws 2002 745i off lease for my wife with 27,000 miles. He now is leasing the 750li. He had the maintenance package and all records and service done correctly. I drove it from Dallas to Cary, NC. During the trip, I noticed an engine noise and took it to the dealership under the 100K/6 year warranty coverage. The car has been at the dealership since, after two days I was told their was a piston knock in the cylinder and the cast was defective and I might need another engine. Then more ideas and service test/request from BMW, the dealer says BMW is sending a field rep out next week to inspect and I will probably get a new engine. What should I expect/or do?
The "diagnosis" sounds pretty fanciful at this point (not the noise, the reason I mean). How in the world does someone spot a casting defect in the block without completely tearing apart the engine and examining it internally. And if they did that, why do they need a factory tech to verify a casting defect?
Doesn't add up. A "knock" generally means something has worn down or collapsed internally...or....sometimes it is nothing more than a bad piston wrist pin, which isn't so serious.
But the good side is that a tech is coming. He can not only verify the problem but also authorize the repairs. So you should make sure the tech is prepared to authorize the repairs for the dealer. The dealer will do nothing without authorization I don' think because the cost is going to be really really substantial and he's not going to gamble on having the cost bounced by BMW.
How close is "close" to empty? There is a section in the owners manual that refers to getting too close to empty, (I believe less than 1 or 2 gallons which can create a problem. Check this area or call BMW customer service and they can answer this for you.
By the way, as a note for future reference; I have a 740i 2001 with 88,000 and the lower coolant level sensor that is located under the reservoir tank fill area sprung a leak of anti-freeze recently. Just 2 months earlier the upper radiator cracked and had to replace; but my point is there is a design flaw in the sensor placement as when the leak occurred the only way to repair it was to replace the entire reservoir tank as the sensor part did not have a gasket that could be replaced. The plastic mount just gave out and the sensor was fine. Very expensive for what should have been a minor item. I will call BMW to see if I get any sympathy. Has anyone out there experienced this? Earlier someone said to just figure $200/month for maintenance and repairs for their car. I can see why. Good luck!
I was so low, I was worried I would get stranded. About 2 days after post, light went out again. now a week later, its still not lit and all is well. I read the same in manual. I suspect it has to do with fuel pump sucking air (is that even possible?), I would be interested if anyone can enlighten me. thanks.
I am considering purchasing a 1994 740il for light highway usage(@5000mi/yr). I want a performance sedan, and these cars seem to be priced low...Why? I was wondering if there were any "buyer beware" problems with these specific cars, even with low miles? If so, what other reccomendations might you have to meet my needs. Thanks
They are low priced because of punishing repair and maintenance costs. Buyers are shy of them consequently. So to make this work for you, you need: a) low mileage super cream puff used car + knowledgable independent repair shop willing to work on them and cut corners for you (used parts, installing eBay parts you find, etc.). But if you buy a car with needs and go to the dealer for repairs, you'll be staggered under the heavy blows the car will deal you I think.
Some indy shops won't even work on a 740, so check first.
Summary: best car possible + perfect shop + right price or else don't pull the trigger. Can be heaven or can be hell, depending on how you play it IMO.
Would you consider under 70K low miles for this car? If well maintained, what would you consider a reasonable lifetime mileage for a 740. If not BMW, then where should I be looking to mix my desire for a performance car with a fairly roomy sedan?
I bought the car as a CPO in 2002 as I didn't like the 745i's at the time and knew of the problems associated with them. The warranty just expired and dumb me, I didn't look into the lemon laws within that 3 year period. The car has been in the shop 26 times in now just over 40 months, 25 times within the 36 mo warranty. I have tried doing everything I can to get BMW to fix the car but they refuse to fix it under warranty even though the car was in the shop around 100 - 120 days during the 3 years. Now the car continually kills batteries. I am on my 3rd pair of batteries and now one of these is gone! I am getting this under the battery warranty. The car somehow discharges the batteries every day now. I have it in an independent BMW service shop. It's been in there now for almost 2 weeks.
i have tried getting in tuoch with the BMW ombudsman who advised me to send a certified letter to the car dealer I have dealt with in San Diego. After 7 days, I have had no response. The ombudsman indicated he will go to BMW NA. When I tried contacting the regional service BMW employee (who has flown in to San Diego on 3 occasions to try and fix the car), nobody will give me his phone number or email address. I have phoned BMW NA, in New Jersey, all to no avail!
I am extremely frustrated as I can't really even drive this car now!
The independent shop is doing an iterative process to see if they can find what is happening.
Does anyone have any suggestions? Surely I can't be the only 750 (12 cyl) with electrical problems?! Oh, by the way, ALL PROBLEMS FOR THE 26 TIMES HAVE BEEN ELECTRICAL RELATED!
i own a 1999 740I witn 162,000 miles. has any one hit 200,000 miles on any of the 97-2001 7 series models.... is your 7 series still running smootly at such a high milage?
This is exactly what happened to my 1993 bmw 740il. Did you ever determine the answer. I haven't dug into it, but it sounds like the same issue. Started slowly taking longer to start, and then one day nothing at all. I too changed the spark plugs and noted that they were a bit wet with what apppeared to be oil, but had a gas smell to them. I was thinking to check the ecm, fuel pump, but after that I'm at a loss. It cranks over, but doesn't even act like it wants to start. Any help would be great.
Does my 1992 735il also needed valve body repair kit ? Started as intermintent problem in drive then reverse (when it would go in it hooked up with any slippage) and now will not move at all, all other gears are fine.
I have had the engine rattle problem with my 2006 750i as well. At first I didn't notice it as much but one time, with music off, windows open and driving on an empty quiet road, I could hear the rattle, specifically when accelerating at low RPM's at low speeds, might get worse when I select the S sports mode transmission program. Took it to the dealer, apparently seemed to have fixed the problem with a computer upgrade. After they have serviced the car, I didn't hear the rattle noise and the acceleration was better, but I noticed a different feel from the steering. In the work order sheet they stated to have reset the steering angle, any input on that?
Nonetheless, now I am starting to hear the rattle sound again, though less frequently and not as intense as before. It comes intermediately and especially when accelerating. There is some hesitation in acceleration as well. Leaves me scratching my head, and wondering what could be wrong. And just to clarify everything I always fill my BMW with premium high octane fuel. Very unfortunate, given how much I love this car, but I will be taking it to the dealership soon for further analysis and hopefully they will get rid of that annoying rattle noise and sensation for good! :sick:
One day, my car simply would not respond in reverse. I took it to a repair shop that came highly reccomended, and after they tried cleaning/replacing filters, the problem persisted. They are reccomending ordering a new valve body (costing rougly $2,000!!). Is this overkill? Are they doing this because I'm an 18 year old kid who bought the car just a month ago and I have never been a customer before? Advice would be GREATLY appreciated.
How much is a complete rebuild? Or can you buy a used unit instead?
I think that unless you are on your own making a pretty good buck this may not be the car for you...they cost a lot to maintain and repair...you may want to fix it and bail and try a 3 or 5 series.
(sight)
Okay, let's go from the most obvious to the least obvious.
If overheat is FAST overheat, 10-15 minutes off idle:
1. Thermostat (remove and test_
2. Electric cooling fan (observe)
3. head gasket, cracked head (test)
If overheat is SLOW overheat, at highway speeds or only after a while
1. clogged radiator (flow test)
2. contaminated transmission cooler (observe)
3. not shifting into high gear (observe)
4. dragging brakes (test on lift)
5. excessive lean mixture, vacuum leaks (test on machine)
mike :sick:
thnaks
http://www.data.bmrparts.com/bmwparts/343.html
Pressurize the cooling system and then remove a spark plug and look for water on it..might be tough to remove all of them, put it's one way to know.
Test coolant for combustion gases
Sometimes with engine running you can see combustion bubbles in coolant by looking into radiator
Check for water in oil, or oil in water
If you want to keep in in there that long, I'd definitely do an oil analysis at 10K.
You lose that engine, you've lost the entire car.
It's not really my call... It's a call that BMW's been making for the past 15 years, and they haven't had any problems with their engines as a result.
You should probably wait for the field engineer to come out and check it, then wait for the engine, if necessary....
You mean a 1990s era performance sedan that drives like a BMW but runs like a Lexus?
No such animal IMHO.
If you could live with a mid to later 90s 5 Series BMW, that might work better for you. Again, low miles.
