Pictures of 2001GM HDs!!!
sovercash1
Member Posts: 112
www.wieck.com/public/index.html they have the
best pictures of the 2001 GMC 2500HD 4x4 and 3500
4x4. Type in 2001 HD Sierra and search. Great
pictures. They look like what will be on the 2001
brochures. Does anyone know of another website
with as good or better picture? If you do leave the
address here.
SteveO
address here.
SteveO
You decide for yourself..
www.pickuptruck.com/html/gmheavy3.html
Man!! Ford is in for a fight.
Anyone else see this or is it just me?
I see no similarity.
It is a much better looking truck than the SD.
- Tim
Rich
SteveO
-powerisfun
If anything it should get a little better than the 454.. They have improved the Breathing of the 8100 considerably...
More Power better mileage, I love it!!!
A supercharged 7.4L would beat both of them though for a lot less money (assuming you already own a truck with 7.4L). You'd have torque of ~600 lb-ft and power of ~430 hp. Of course, you'd have to pay for the premium fuel and you wouldn't get all the other new gizmos. I'm also not sure the transmission would let you use all that torque, either. Oh well, it's fun to dream anyway.
-powerisfun
SteveO
Hope that helps
Steve
I'm not sure what gear ratios the Vortec 6000 or Vortec 8100 will be available with.. but I will find out...The Duramax will only come with 3.73 is correct...
What is the 2500HD GVWR?
Are the 2001's going to offer the same ext. cab 4x4 shortbed with the new 325HP 6.0?
Are all the 2500's going to have a 2" body lift or is that just going to be on the 2500 HD?
Anyone out there have this info or knows where I could get it?
Yes, the 2500HD will come in Extended Cab with a 6.5 bed.. It will also come in Crewcab with a 6.5 bed.. 4x4 and 2x4.....
The 3500 series is 11,400 GVWR and the 3500 Chassis cabs GVWR is 11,400 for 2x4 and 12,000 4x4...
And the Vortec 6000 will be available in all the Cab configurations that the Duramax and Vortec 8100..
As far as I know all the 2500HDs and 3500 series will sit about 2" Higher than a Half ton..
Where do you get it?
I'm still a little confused.
The current GVWR is 8600lbs.
Will I be able to get a 2001 4x4 2500 extendedcab 6.5' bed 8600 GVWR without the 2" body lift? Or are all the 2500's going to be 9200 GVWR with a 2" lift?
I also saw you wrote that the official starting date is May 8, is that the first day you can order one or is that the day they will start building the trucks?
Thanks for the info!!!!
With the 2500HD's having a 600lb greater GVWR than the 2000 light duty 2500 (9200lb vs. 8600lb), does this mean the payload is 600lb higher? Or does the truck weight, presumably higher on the HDs, take away from the payload capacity?
The light duty 2500 will not change it is 8600GVWR.. GM will have TWO 2500 series for 2001 a 2500LD(Light-Duty)= 8,600 GVWR
and 2500HD(Heavy-Duty)=9,200 GVWR
The Cab configurations will not change for 2001 for the 2500LD series..
May 8th is when the Dealerships can start placing orders.. They will start building the trucks in August..
drl64
The 2001HD trucks are a little heavier, so you will need to factor that into your GVWR..
But the HD series has a GCWR of 22,000 lbs.. The 2500LD(Light-Duty) is only rated at 16,000 lbs..And they don't have the Option of the Duramax 6600, Vortec 8100, or the GREAT 1000 Series Allison Transmission..
SteveO
$500 more for the HD
$500 more for the Allison than the current auto
and probably $4,000 or more for the Duramax (judging from the Powerstroke & Cummins)
Hopefully the Duramax option will be less since the Ford and Dodge gas engines are so inferior, they can afford to charge that much more for the diesels.
But my best guess, comparing a current Sierra 2500HD w/ auto, 4x4, tow.... = invoice of around $29,500,
Equivalent finished 2001 2500HD w/ Duramax/Allison would be pushing $35,000. Just my guess.
So, the light duty 2500 will have the 325hp 6.0 and no body lift. Is that right?
Thanks again!!!
The lift on the HDs is for installing the Bigger Allison.
But the 325HP 6.0L in the 2500HD and 3500 series will still have the 2" lift.. And frontend treatment..
Did that answer your question?
gwmoore,
I have been told the Duramax 6600 will be a little less than a Pstroke.. The Allison will be a little more than the 4L80E.. We can only wait and see!
Steve O
Seems strange they would make 2 different 6.0's.
Thank you for your knowledge!!
I was hoping for a 325hp. Maybe I'll try to buy now since there will be no change.
I tow a 22' boat that weighs about 6000lbs, so I believe the 8600GVWR will be just right.
Some of the dealers in my area are saying they can not get that truck this year. Others are saying they will not make it after this year, and can not get it this year, so either wait for the 2500hd or buy a 1/2 ton.
Still another dealer says they can order one this year.
The only thing I wanted to wait for was a 325hp.
I live in the San Francisco Bay Area.
Do you have any suggestions who I could talk to?
Thanks again for your input!!!
I currently own an older ('86) ford diesel.
When I purchased it diesel was 85 cents a gallon and regular gas was $1.15. It was worth the stink and the noise.
Now diesel is usually priced between regular and midgrade, here in Calif. It's not worth it to me anymore.
The powerstroke is quieter than mine and has many times more power, but it still makes more noise than any gas engine I've heard. And you still have to fill your tank, get it on your hands, and on your shoes because your standing in someone elses spilt fuel.
I feel if you always have a big load, or pull a trailer often, diesel is the way to go.
For me, that's not too often, so I'm going gas.
My wife cann't wait!!!!
Thanks, Sean
Lastly,did anyone see the article in Truck Trend's April issue comparing a current GMC/Chevy 2500 against a Ford Super-Duty with a V10? Regardless of opinion on which is better, I thought it was a mismatch - they should be comparing the Ford F-250 with the F150 body style to GM's light duty 3/4 ton. This summer compare the new GMC/Chevy HD with the Vortec 8100 against the SuperDuty 3/4 ton and let apples be compared to apples...
Where do you get a 200K mile life on the Duramax? I'ld put good money it will be much better than that. Comparing the Duramax to past GM diesel offerings is not logical. Isuzu makes excellent diesels, heck, their tiny old turbo diesel that were in their compact pickups and the Trooper last over 500K (friend of mine had the little pickup with over 500K - no rebuild, everything else falling apart). GM has to have a different philosophy this time around with the diesel, and Isuzu's influence certainly helps.
sdpierson,
The other thing to consider is that as fuel prices (unleaded and diesel) go up, the better mileage makes a bigger difference. I don't care much about break-even points, but the overall higher fuel prices should shorten the period.
In the future, a diesel substitute created from natural gas and/or coal, called "Syntroleum" may become available. This fuel has the same combustion characteristics as diesel, but has no sulfur and low carbon. The fuel has already been used with Dodge in the Cummins, and reportedly worked well. The fuel is not cost-effective until oil prices reach the levels they are currently at, but this fuel at the pumps may become reality sooner than later if oil levels stay high or environmental restrictions get tighter. Upside, a less stinky/smokey fuel, and prices should be less volatile since domestic natural gas reserves are so good. There are several major oil companies backing this technology, including Texaco, Enron, ...
As for Average Engine life... GM specified to Isuzu that the Duramax had to have an Average expected life of at LEAST 200K with out a Major Component Failure (High pressure Fuel Pump,Piston,Turbo,Water Pump, Heads, Block, Oil Pump) thoses things are considered Major Components..
The Duramax is not like any Diesel engine you have ever seen.. It is MUCH better...
Steve O
It is a BIG gear in the Back of the Trans for PARK.. It has a Bracket(Parking Pawl)and it rides on Rollers that locks in the gear for park postition..
this topic is being "frozen." it will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
