Visitor Agreement.
I feel that by trading/purchasing this vehicle over the one I have currently I would be getting a better deal because I would eventually end up with a 3.5" suspension lift kit on it, including the larger tires. What do you think? And also (VERY IMPORTANT) when I did the 'Appraise This Vehicle' on Edmunds on MY car, Power Steering was an option. But when I Appraised the vehicle at the dealership, I found no option of the sort. Does the 95 come with the power steering?
The Tacoma I have now is really standard. The one I am looking into and the one I have now are both EXTENDED CABS, but the one I have now has no power d/l, w, mirrors, etc. Please HELP!
One final note; with the supercharger installed, does the gas mileage decrease? And does it make that much of a difference in acceleration? What is the price of those usually with installation? Thanks so much guys.
I have 110k on it and it runs just like the day I bought it. I get about 25/26 mpg commuting to work and 28/29 mpg if I take if for a long trip. the mileage goes down about 15% in the winter.
Be careful about overloading it. I broke a rear spring by carrying firewood.
I have a friend that installed the supercharger on his 4Runner. His mileage stayed about the same, but he needs to use premium all the time.
Thanks in advance to anybody and everybody who responds. Have a great weekend!
I have just traded my 87 SR5 pickup for a 2000
Tacoma 2wd (see how long they last
my 3rd day of driving it. Unfortunately, my test
drive didn't pick up on the engine drone at
highway speeds of 60MPH and better. At just over
60, with only a very slight amount of pedal
applied, I get what appears to be a resonation coming through the driver side only. I *think*
it's being projected through the steering column
or from under the dash. If I lean to the
passenger side, it quiets down to an acceptable
level (I haven't ridden in the passenger side yet
but that's next).
I talked with Toyota service and only received
a statement like "the 16 valve engines are
noisier than the 8 valve engine in your 87"
Anyway, I have a an appointment next week to have
it road tested but I thought that I would poll
the crowd here to see if this is "normal" with
the Tacoma design.
I am also going to call the salesman and arrange
for a test drive of another Tacoma. Now that I
know what to listen for and when, it should be
easy to tell if there is something wrong with
mine or this is typical of this design.
My normal vehicle use is 95% highway (commute)and
5% utility so this is important to me. My '87
never droned on like this or I wouldn't have had
it for so long.
Any thoughts, suggestions or similar experiences?
Gary.
I've had it for just over 4 months and now have about 8000 miles on it, and it is a fantastic truck. And the mpg has steadily gone up! Anyway, I think that your truck is just fine. But it probably couldn't hurt for the dealership to take a look at it, just in case. Otherwise, I don't think you'll have any problems from the "engine drone". Maybe it will go away like it did on mine...............
might be a break-in issue. I have seen air pumps,
etc. in the past that have made quite a bit of
noise until broken in. We shall see what happens
as I only have 375 miles on it now. I will still
ping the dealer and see what they have to say.
So far, with the exception of the noise, I
really love the 2000 4x2 extra cab. My first
tank was 29.5MPG. I've been babying it. It that
goes up overt the next few thousand miles, I'll
be quite happy.
Gary.
Thanks for any info you have, Eric
Good luck,
Terry
The other one was the exact same truck, except with the automatic transmission for $17,750 out the door.
I don't tow anything, this truck would be my everyday transportation, and to go hunting and fishing up-country. the 5spd seemed a little peppier, but the auto is conveinent. Would you go wrong by getting the auto? I would plan on keeping this truck till it dies. I have a 89 camry with a 166,000 miles, and it has been great, but obviuosly not good for logging roads etc..
just concerned with maintanence,reliability, wear.. over wich transmission to consider.
thanks, john
My question is this:
Are you planning on towing anything or using this truck at higher elevations?
Are you planning on doing any highway driving?
Do you fit well in the vehicle?
If you plan on doing longer trips, towing, and plan on using the vehicle at higher elevations, I would go for the v6 with the extra cab.
You really won't save that much on gas since you have a 4wd anyway.
save some more scratch and get what I really want,
I'm going to keep it until it dies, so for 2-3
grand more, might as well go for the extra room.
thanks for the straight talk, john"
No problem. I had a regular cab Toyota 4x4 for a long time, and I am fairly large. I got used to it. I loved that truck, but there were times I wished I had the extra cab, esepcially on long road trips.
But, a truck is a truck, right? I now own a extended cab 4x4 tacoma. But I still prefer the look of regular cab trucks. I find extracab pickups to be very unsightly.
If you like it, and are comfortable with it, then go for it. IT will be a very reliable friend for a long time.
But, you make a good point. If you plan on keepingit for a long, long time, you should make sure you don't have any doubts. I loved my reg cab, but when I got a new one, I got an extracab, if that tells you anything.
Don't forget to include that not only do you think it should not be doing this, but you don't like it and it's under warranty. I don't think it's your job to figure out the solution...just document the problem.
I assume you haven't been towing large volumes of concrete uphill for the last several months
Good Luck!
I've decided on a Tacoma Prerunner v6 extracab. The decision between the 4 cyl and the 6 cyl was easy. I wanted a moonroof but was told it only comes with the TRD or a 4x4 (I cannot afford a 4x4). So I took the TRD for a test drive and found the ride very hard (because of the offroad suspension), not nearly as smooth as the prerunner. I'm now leaning towards the prerunner, even though I do favor the sporty look of the TRD and the moon roof. The reality is that I'll never go off-roading. Does anyone have any thoughts on this?
I wouldn't drive a vehicle that didn't have a sunroof, moonroof, or removeable top.
any problems with it?
I own a 1999 Tacoma TRD with 16,500 miles. About the last 4,000 miles, I started noticing that when I let off the clutch from a standing stop, it feels like I have to let out a lot of clutch to get the truck to engage and once the truck begins moving there is some hesitation and roughness. I'm thinking the clutch cable has stretched and/or the clutch hydraulics need to be bleed. Also thinking maybe just a simple adjust to the timing would cure the problem. I plan on running it into the shop next week but would appreciate any heads-up or ideas before going to the dealer.
If you want to go 4-wheeling at 5 mph or lower get the TRD locker.
If you want to go pre-running at speed (the most fun) get the TRD Lock-Rite rear end. (available from TRD and installable by the dealer). This rear end automatically goes to full mechanical lock at any speed when 1 axle rotates more than about 1/4 turn more than the other. I have this rear end with the supercharger on a 1999 prerunner and find it a great setup offroad. There are some drawbacks.
1. The rear end locks at 1/4 axle turn difference off-road at 80 mph and in the parking lot at 1 mph so your rear tires last about 15,000 mi.(u-turns are a killer)
2. There is a fair amount of noise from this rear end when the gears lock.
3. The supercharger / rear-end combination can cause sever wheel hop on or off road under hard acceleration so I am presently checking into a good set of serious traction bars. If any one knows where to get some aftermarket let me know. It seems as of now that I may have to have them custom fabricated.
In summery if you want to look like a prerunner skip the locker. If you want to take the truck out and really play with it get the aftermarket TRD rear end.
I had a power moon roof installed in the truck in June (what a great job) and now I enjoy the open sky when i drive. The Taco performed excellently in 4wd in the deep snowfall we had here in Central VA. It handled flawlessly. Everything in the truck is well constructed. I am looking for years of virtually trouble free driving.
The tech. there accused me of abusing my truck because I have a hitch and helper springs. The helper springs are to keep it straight and level which it won't be even with only two or three hundred lb's in the back.
Are you saying that your Tacoma has problems carrying loads? Do other Tacoma owners have such problems with such small loads? You're making me think twice about buying one . . .
tires after discovering cracks
Toyota has informed Bridgestone/Firestone that it
will no longer accept tires that fall under the
Bridgestone Dueler brand name after Toyota
discovered "abnormal surface cracks"; in new tires
that come as standard equipment on such models as
the Toyota Tundra, according to CBS affiliate WWJ
News Radio in Detroit, MI. Surface cracks, if they do appear on tires, do not usually show until the near the very end of a tires life. This newly discovered problem could also lend to the argument of safety advocacy groups that quality is still an issue at Bridgestone/Firestone."
I would suggest that anyone thinking about the supercharger buy it from and have the dealer install it since it then falls under the full factory warranty.
P.S. does anyone know if anyone is making aftermarket traction bars and a Fox front shock / spring setup for the 1999 prerunner?
Happy Motoring. ;-)
Pocahontas,
Edmunds.com/Roving Host
We also would like to have the cab as comfortable as possible and would like to get whatever is considered a "luxury" package for the cab. Do you have idea as to what this might include and what it might cost.
The reason were looking at a 2000 and not a 2001 is we've been told were in a better bargaining position since the dealer is under pressure to move the 2000 models. Is this true? Or would we do just as well to get a 2001?
Thanks, any and all comments would be appreciated.
Phat Mikey
trading my 1998 5speed that had a transmission problem. While driving the gearshift moves back and forth. I only have 2300 miles on the truck and the dealer said this is normal. Anyone have the same problem?
Ben
