Lincoln Aviator Accessories and Mods
What accessories/mods have you added to your Aviator?
Every time I call a dealer they tell me that it will be another month before they come out. Hope they get them soon. I just called on Friday and they again told me the same thing. If anyone hears anything on these mat's availabilty please let me know.
Sonny
Please let me know when these mats become available. I have been waiting since July 03' for them. Finally! I was going to go ahead and purchase a less desirable set but I am glad I waited. Is there a number that I should be calling or are you getting this info from web?
Thanx
Life is better at the Beach
She has also complained a bit about the fact that the sloped cargo floor (when the 3rd row is down) causes stuff to slide to the back, and when she opens the liftgate, bags sometimes actually fall out onto the ground. Now, one solution is for her to only open the glass part of the rear door, and I'll work on that, but sometimes you really have to open the entire liftgate.
Given these requirements, what's my best option? I've looked on the Lincoln accessories web site, and they have a thing called "Cargo Logic System" which looks at least a little promising. (It also looks very similar to the cargo system on the CatchAll web site -- I wonder if they are the same...) There's also a less expensive "Cargo Tray".
Has anyone used these accessories? Are there others I should look at? Thanks for any advice you can give.
Chris
You do know that if you remove the "seat" of the 3rd row, the floor will be a little more level. Not much help if you use the seat every day, however.
So, I guess the lack of a reply to my earlier message a few weeks ago means that nobody uses any of those cargo area mats? Oh well, it was worth a shot anyway...
Chris
Luck
If so, how's it working for you?
Mats: Try www.autoanything.com
THANX
Life's Better at the Beach
Thanx
You might swing by Car Toys or Circuit City and see if they can do it through the touch screen - otherwise I think you might be stuck.
Does anyone know more details about what they've done to this vehicle? What have they added, and is it only cosmetic?
Thanx
Life is Better at the Beach
Anyone?
Or are you just going for the Bling factor?
One thing to remember for overhead mounting is how much it blocks the rear view mirror.
You can get the headrest monitors for $150 or less so even if you crack one it's not the end of the world. Probably much cheaper than one 10" LCD and you have the ability to run multiple sources. And it won't block the rear view mirror.
Just some things to think about.
Ebay.
THANX
Anyone have a remote start installed on their Aviator? The Lincoln website shows a factory version, but I get a pop-up saying it can't be installed on a 2003 Aviator despite the fact that at the bottom of the screen 2003 Aviator is listed as a model that it can be installed on.
Hammer995, depending on the vehicle aftermarket remote starts require an alarm bypass box that basically holds a key to the car to defeat the engine disable system.
Would you mind posting an approx. price paid? Thanks!
check out
click here
Does anyone on the board have any solutions for holding toll booth change?
I have a 2003 Aviator with a power moonroof. I bought it without the overhead rear entertainment dvd system but now the kids want one. The factory unit is made by Johnson Controls and lists for about $1400. I found a unit that was meant for a 03 Explorer Limited for a lot less money. Does anyone know if they're compatible? ie. wiring harness, connectors, radio interface, etc.
Susan
Thanks...
