If the rotors have never been turned, then they should be able to turn them without replacing them. Did he say why they needed to be replaced? If they're not warped or seriously grooved then they're probably ok.
Was the brake pad wear on just one side? The 2003/2004 Lincoln LS' have had a problem where one of the rear brakes wears out quickly. Not sure what caused it. If it's uneven wear that's a sign of a problem that should be covered under warranty.
I've been lurking these boards to see if anyone else experience an A/C failure.
Anyone else? Besides that, enjoying the vehicle although I wish the brakes were even to close to being on par with the X5.
Car has 30,000 miles on it. dealer checked brakes and said the pads were fine, but they 'turned' the rotors, shaving off 1mm I believe. Is that what they should have done, or should they have put on new rotors? Any cons of turning rotors ?
thanks.
Currently own Mercedes 2000 E class but I'm so disappointed with its quality. It gave me a lot of trouble for the maintenance. German car is not reliable anymore. I don't wanna buy german car anymore. I'm also considering Lexus because its outstanding reliability. But Rx330 has only 5 seats. Gx is too expensive. :confuse:
Anyhow, I took the car to the dealership, and to my suprise, my service advisor mentioned mine wasn't the first to do that!
Anyhow, heads up. Be sure if this happens to you, either get the thing towed or be sure not to block anyone in the event that you power down the car and can't get it restarted because it's stuck in gear.
Just an FYI, the plastic shaft I am referring to is very, very thin, probably 1/4 inch diameter, max, and it's hollow. PM me if you would like pics. Also, nvbanker, I'm not sure if your theory is correct as the plastic shaft itself isn't "load bearing". Rather the metal shaft that surrounds the plastic shaft and forms the base of the shifter is what I would assume would take the brunt of abuse.
I recently bought a 2003 Aviator with the 4.6 V8.
I have discovered an intermittent noise. It is a moderately loud, quick( < 1second) whooping noise almost like a siren starting up and then abruptly stopping.
It sounds as if it is somewhere to the rear of the driver down low. I does not really sound mechanical. It's a very clear and smooth tone, does not sound like any kind of a bearing going bad. It's not the same pitch as the backup alarm.
I can't yet find a pattern to when it will happen.
Has anyone else hear such a noise on their Aviators?
Otherwise the car is great so far.
Robicurp :surprise:
If so, that noise is most often a faulty expansion valve in your A/C evaporator system. It's more often a problem in the back unit than the front, but there's one up front too that could do that.
Posting this info as I recall other's on the board experience seat shifting problems.
Is anyone else experiencing this problem? I recently was parked next to another '03 Aviator and the owner said she had the same complaint.
It's higher probable that this is the device they already installed by did it wrong.
Thanks for the info on electronic evaporator dryers. I have googled it, and printed off several articles to share with the dealer and regional rep. Glad to know the problem is out there, being recognized and solutions are being worked on.
I'm not terribly worried about it, as long as they replace the engine 'head' and everythign works fine...but has anyone else had this problem? :confuse:
I have tried to follow it exactly, but I must be missing something obvious.
Anyone else have luck with this? Thanks.
1st, is there any way to override the buttons going gray when I am in motion. I saw that on other vehicles there is a service menu that would let you turn this on and off. Any idea if this can be done?
2nd, anyone understand exactly how Detour works? If I am on a highway for 15 miles, and I want to detour around the next 3 miles, how do I use it? It seems like the detour settings is for how far "away" from the highway to go - not the distance to detour around.
Any suggestions?
3 days after we purchased the vehcil it went into the shop because we boght it with a shimmy in the steering wheel- we were advised that it was a washer and could be fixed easily- it was not I have had the tires balanced- rotated, the drive shaft was replaced- the power steering return hose was replaced- a new set of tires put on the car-made the shimming/shaking worse, etc. etc. etc. The car shkes at all speeds, the steering wheel turns about a inch when your brake just normally the car pulls hard to the left when braking slighly harder and pulls ot the left at highway speeds. any suggestions?
Tahnks gen
No problem with the 2004 Aviator except an intermittent howl from the left rear AC vent. The dealership can not find it and they said it never happened when they had the car.
