Lincoln Town Car Accessories & Modifications
What accessories/mods have you added to to your Town Car?
I'm loolking to get some additional HP to the street out of my '88 Cartier without a major reconfigure. Any suggestions?
As for getting more power, the stock heads and camshaft are the main limitations. Upgrading to a 5.0 HO (as in Mustang) uppper intake and throttle body, boring out the EGR spacer to 60 mm, and adding shorty headers and duals will give you some improvement. To really wake the 5.0 up, you need E7 (HO) or slightly better heads and the HO camshaft. These will require the larger 19 lb/hr injectors, and a Mustang computer is highly reccommended. And remember that the HO cam changes the firing order.
Much more information about this is available at www.crownvic.net.
Recommend your boss buy an early low mileage 91 to 95 Town Car with the 4.6 engine. Check out e bay. There are such vehicles for sale from time to time.
what would be a good 2.4L engine to put in a town car?
thanks shawn
Twinning out your exhaust is about $200 and you can buy a lot of extra gas for that.
Changing the back pressure on the exhaust manifold may adversly affect the O2 sensor causing the on board computer to be mislead.
Replace the air filter and have 35 psi in all tires.
15" & same 5 lug pattern. See what's available for those two relatives.
