Toyota TACOMA vs Ford RANGER - IV
Cspounser writes:
The 2001 Adrenalin, man gotta look at that guy
this summer. SPOOG, thank you for complaining that
Ford lacked a vehicle like the TRD.
Ford LISTENED to you. "
No. If FORD was listening, they would have completely redesigned the vehicle from the ground up with offroading in mind, and the options that cater to offroading, like Toyota did. Hence the marvelous Suspension on the stock Taco. Now add a GREAT designer like TRD, and you have a vehicle that meshes together perfectly for it's purposes.
Ford didn't listen. They didn't build ANYTHING like the Tacoma TRD. YOu can't slap more HP and a fancy name on a car suspension Ranger and expect it to compete with a Tacoma TRD. How Nieve~!
" The TRd TAcoma handled the rough stuff better than any vehicle we have ever driven"
---4wheeler.com , 4wheeler magazine.
That says it all, right there.
Summary: SOME VINYL COVERED ITEMS MAY
EXHIBIT A SMALL DENT, SCUFF, ABRASION AND/ OR
DISCOLORATION
Summary: LIFT EFFORT IS EXCESSIVE ON THE DRIVER
AND / OR PASSENGER OUTSIDE DOOR HANDLE. *YC
Summary: EXPERIENCING A " BUZZING " OR " RATTLING
" NOISE FROM THE EXHAUST SYSTEM. *YC
Summary: FORD MOTOR COMPANY HAS RELEASED A NEW
ELECTRICAL GREASE
Summary: INFORMATION REGARDING REPROGRAMMING
POWERTRAIN CONTROL MODULES (PCMS). *TT
Summary: CUSTOMER MAY COMPLAIN OF A BROKEN AND /
OR STRESS CRACKED WINDSHIELD GLASS. *TT
Summary: FORD MOTOR COMPANY NOW RECOMMENDS SAE
5W-30 VISCOSITY GRADE FOR SERVICING ANY FORD
GASOLINE-POWERED VEHICLE REGARDLESS OF MODEL YEAR.
Summary: FORD MOTOR COMPANY HAS RELEASED A PRIVATE
LABELED MATERIAL TO BE USED FOR IRON PARTICLE /
ACID RAIN SERVICE REPAIRS. *TT
Summary: INFORMATION ON MAINTAINING TIRE PRESSURE.
*TT
Summary: INFORMATION ON THE NEW FLUSH AND FILL
TOOL AVAILABLE THROUGH ROTUNDA. *TT
Summary: CONCERNS WITH OUTSIDE PASSENGER OR DRIVER
SIDE MIRROR SLIGHTLY FULTTERING / SHAKING AT
HIGHWAY SPEEDS. *TT
Summary: THIS BULLETIN MENTIONS CLARIFICATION ON
HOW TO OBTAIN RANGER ELECTRIC VEHICLE (EV) TRACTION BATTERY MODULES. *TT
How does this apply to my Ranger?
Summary: INFORMATION ON POSSIBLE BATTERY
OVERCHARGE WHILE USING NGS TESTER. *TT
The issue on wipers was listed 6 times
The issue on fluttering mirrors was listed 3 times.
You found 8 that were iffy. hmmm........
http://www.discoveromaha.com/partners/wowt/news/heartland/ford_0329.html
http://www.baddesigns.com/wiper1.html
Rangers are 5 star rated for 30 mph crashes, not 74 mph crashes.
Given one star rating, what would the damage have been?
Do you REALLY want me to post 95-97, and 87-94 as well? Such as what you did? I don't think you do. But go ahead. Don't accept the facts. Your good at it. Your good at denial. You really can't face the fact that you bought a pickup that is only rated to haul 1000 lbs, and that has the sacrificed suspension of a car for highway travel. All that and you live in Colorado. Tsk Tsk.
Hot off the press!!! HOT off the press!!!!
Jury awards family 144 milion after Ranger is deemed defective!
http://usatoday.com/money/consumer/autos/mauto021.htm
Spoog still waiting on that intake height..
oh yeah and i really like the Tsb on how much air to put in my tires.. and the one on a new repair book for the climate controls... and the Recall on the electric ranger.. when is toyota going to have an electric vehicle or even a LEV (low emision vehicle). Ford has two rangers that meet those qualifications.
"When the magazine tied a load securely in Tacoma's cargo bed, the walls of the bed bent. Kind of hard to ignore a fault like that."
Bent? Superior steel?
Yes spoog "...tis a pleasure to live in Colorado."
http://www.crashtest.com/toyota%20truck/index.htm
Oh dear, there is a lot of red in this report listed above. Something about death rate. . .
"MARGINAL"
But is that not simular to Tacoma?
And you got a broken grille?
I hit a tree going backwards and got a dent the size of a nickle. You know I had my water tank lashed in the back of the bed and sustained no bending hitting the tree. . .
Anybody else get "program attempted an illegal operation, shutting down" message in programs with Windows 98 Second Edition?
It is always in a .dll file in what ever program I happen to be using.
http://www.dougshome.com/truck/ford/defects.htm
now it is all good as new.. no sheet metal was bent at all.
as far as the computer problem.. Wlcome to the world of windows '98. Id like to find a person who didnt get those errors. Is it the same Dll each time (dll's can be shared between programs) if so it could be a dll that need to be updated. Dell is notorious for shipping high end machines b4 all the Proprietary componets inside are compatible with all the software they bundle.
Hind..
i hate to see stuff like that.. that is shotty workmanship. but it makes you wonder why this guy bought this thing.. when i took delivery of my truck i went over it with a fine tooth comb.. that is just as much of buying a truck as not paying whats on the sticker.
as you can see tho the Guy is still a proud ford owner.
operation, shutting down" message is one of the worst, almost as bad as the "blue screen of death", even my IS guys wont touch it.I usually just take out the components and put them back in one by one till I find out which one is causing it.
Good thing, Dell is sending you a new computer on Tuesday, they're usually set up pretty good.
Maintenance and Repair/Topic #998/Entry #25
Please feel free...
Look closely and you'll see the problems. "Also, "keep in mind it's a brand new truck
and Ford says "it's all within their tolerances!" :
1) Notice how the frame around the window disappears towards the hood of the truck.
The window frame and roof were "bent to fit" from the factory."
Cspousner-
INteresting that you have been harping on that Consumer Reports test since 95. Shall we take a look at how Consumer reports rates the Tacoma over the Ranger? Should we see what CR thinks of the Tacoma in 99? LEts count up the black dots. lol.
Crash test data and gaskets is all he gots, trouble with the Ranger? Click here http://www.nhtsa.dot.gov/cars/problems/ for lots!
Different .dll files, depends on what is running. There is a fix for WIN 98 you can download but did not fix beeps. That is really what bugged me.
reddog:
The CD is reading and writing so the pins are ok.
Ford Ranger 4.0 Engine problems.
Check out the NHSTA site for reilability data and 4wheeler.com and the 98 ranger verse Tacoma comparions for all your needs.
Needless to say, when the Ranger and tacoma went head to head, the Tacoma won every single performance category, and the Tacoma was a unanimous decision.
Also check www.carpoint.msn.com, www.crashtest.com. The Tacoma is a driving coffin, rated LAST in crash tests.
When you read the NHSTA site, spooog wants you to see the TOTAL numbers, not each individual entry or duplicate entry, or entry for stickers, glazing ect..
:Summary: BRIEF INFORMATION REGARDING THE IMPROVED
SAIL MOUNT MANUAL MIRROR.
As I and others have told you spoog,most of the postings on NHST are insignificant and or non problems but clarifications or repair practices. Well I will go to the NHSTA site and download the issues on Tacoma and will START with the one where the Transfer Case locked up for no reason and resulted in INJURY. Remember those posts a while back, comparing the INJURY rate of incidents Ranger Vs Tacoma. And do you recall that the INJURY rate for Tacoma was IN EXCESS of the Ranger's?
Mission accomplished, got spoog to read Consumer Reports. However, he seemed to miss the part about Ford Ranger being it's "BEST BUY" how many years spoog?
They, Consumer Reports also publish a magazine devoted to Trucks and SUV's and GUESS which truck it lists "Best In Class, Compact Pickup"
By the way, where are the Toyota engines in the Daytona 500 Today? Seems to me that the following are in the front runners today:
Chevy
Ford
Dodge
Can they not build a V engine that can sustain 180-190mph, 6000-7000 rpm for sustained periods?
Just asking, but as usual the answer will be silence.
Ford
Frist On Race Day
Well I went there year before last and yes there is a great deal of off roading. And yes I did see quite a few Australian Fords.
The second most in number documented that you cannot inflate a 16 inch tire on a 15 inch rim.
DAH.
You put 17 inch tires on your superior 6 lug 16 inch rims spoog?!?
Dumb [non-permissible content removed]
Lets see, 11200 needed to have a sticker saying that you cannot inflate a 16 inch tire on a 15 inch rim and 322 electric vehicles had a transmission parking detent problem.
GIVE ME SOME SOLID DATA THAT MY 1999 RANGER HAS MORE PROBLEMS THAN YOURS.
YOURS HAS defective heads and or head gaskets that lunch engines.
YOURS HAS defetive frames that break because they are not strong enough.
YOURS HAS transfer cases that are reported to lock up creating accidents.
YOURS HAS a cargo box that is reported by a national magazine toe "BEND" when stuff is tied into it.
Now, with the exception of two switches that Ford replaced on my truck, I have had
NO PROBLEMS!
I do not leak fluids, have not blown a head gasket have not cracked frames but I
HAVE BEEN
all over 10,000 ft moutian off-road passes with JEEPS, F150's, Suburbans, Scouts, S-10's and NOT ONE Toyota in sight(except the Land Cruiser bogged down to its frame in mud). And a lot of that travel was with my BAD tires.
Again spoog, come up with some SOLID data that your Tacoma is superior to my 99 Ranger XLT because as of yet you have not presented it.
Spoog, how can you of all people accuse any one of repetitive posts. Dude you have the best truck, you are the most mature, you only state the facts, millions of Ford owners are wrong. Now go get a life and enjoy your better than everyone else's truck.
