Toyota TACOMA vs Ford RANGER - IV
11011131516
  • hindsitehindsite Member Posts: 590
    Usually it is cheaper than to fix, but if your engine in that car is good running order then it might worth it. However, the price of that Tacoma sounds a bit high and you may want to look around.
    This is new and a current link from an 2000 Ranger owner with problems.
    http://www.thecomplaintstation.com/f/_ford/000000cf.htm
    Sorry that was a typo.
    Great links regarding the recalls and TSBs on the Rangers. Keep it up and never quit.
  • cpousnrcpousnr Member Posts: 1,611
    Component: INTERIOR SYSTEMS:PASSIVE RESTRAINT:AIR BAG ON-OFF SWITCH ASSEMBLY
    Campaign #: 98V188000
    Year: 1998 Make: TOYOTA TRUCK Model: TACOMA
    Potential Number of Units Affected: 84323
    Component: FUEL:THROTTLE LINKAGES AND CONTROL
    Year: 1996 Make: TOYOTA TRUCK Model: TACOMA
    Potential Number of Units Affected: 5145
    Summary: THESE CRUISE CONTROL SYSTEMS FAIL TO HOLD THE SPEED SET BY THE DRIVER AND CAN ACCELERATE ABOVE THE INTENDED SET SPEED. UNINTENDED ACCELERATION CAN INCREASE THE POTENTIAL FOR A VEHICLE ACCIDENT.
    Component: SUSPENSION:INDEPENDENT FRONT
    Potential Number of Units Affected: 90000
    Summary: UNDER CERTAIN DRIVING CONDITIONS, THE FRONT SUSPENSION SUPPORT CAN CRACK LEADING TO FAILURE OF THE SUPPORT. THIS CONDITION CAN RESULT IN LOSS OF VEHICLE CONTROL.
    Component: ELECTRICAL SYSTEM:BATTERY
    Year: 1995 Make: TOYOTA TRUCK Model: TACOMA
    Potential Number of Units Affected: 9882
    Summary: THE BATTERY CAN HAVE A DEFECTIVE WELD INSIDE THE POSITIVE AND/OR NEGATIVE TERMINAL ALLOWING THE CONNECTION INSIDE THE TERMINAL TO SEPARATE. THIS CONDITION CAN RESULT IN A NO-START CONDITION, OR A BATTERY EXPLOSION.
    Manufactured From: To:
    Year of Recall: '96
    Type of Report: Vehicle
    That is 279,350 Toytoa recalls.
    For such things as serious a cracking frames, exploding batteries, fuel linkages that can stick and passive restraint systems that do not work right.
    Spoog, I will take an incorrect sticker that tells me I cannot mount a 16 inch tire on a 15 inch rim anytime.
  • scottssssscottssss Member Posts: 147
    justone comment. The rangers airbag cutoff switch is OUT OF THE WAY at the bottom of the dash. in a place that could only have been designed for that purpose. Where as the tacoma switch appears to be in the middle of the dash in a RUN of the mill Accesorie slot. And by the way lets not forget that ford is Decent enough to include second generation airbags in the ranger. how about the tacoma ... OOOPS still first generation.
    this place is getting a lil hostil these days lets remember this isnt personel and lets keep in civil.
    AND PLEASE NO MORE POSTS OF 1000 lines... they make my eyes hurt and i dont care if there is a new manual for fixing the ranger heating system. please just post stuff that makes a difference.
  • spoogspoog Member Posts: 1,224
    Hey Vince, the 4wheelr comparions test used the EXACT SAME MODLES that are for sale today! Get it? I thought so. lol. This is soooo much fun.
    Hey Cspounser....I posted aroudn 400 TSB's fro mthe Ranger 97-99. Are you telling me your few little nitpicks make up the entire lists? Nice one C, you are grasping for straws yet again.
    Time to hang it up. Your in over your head.
    As for the Daytona 500, I don't watch that redneck BS.
    Scottsss---- Im sorry if you don't like the facts. The Rangers freakish amountof TSB's are alarming.
    Ranger owners just makes me laugh. All ticked off that they got the "value" truck instead of the performance machine. Shall we hear some more from the transmission expert?
    First link about extended warranty. Where is the Tacoma?
    Second link I will have to assume that is a real problem.
    Third link is nothing about the Tacoma.
    Come on you can do better than that. Only 1 minor hit and two big misses. I guess the bending of the frames has no correlation to the Ranger, and likewise your two links are meaningless.
    Thanks for those comments about the short web site. Okay the switch placement is a moot point for the airbag, but first or second generation is reaching a bit. What about the higher air intake, the two auxiliary outlets, the unequal front half shafts? I went antiquing today and saw this 1999 Ford Ranger 4x4 and I should have taken the pic of the front axle. Maybe I will drop by my local Ford dealer to get that shot of the front axle and the missing skid plate. Gosh there was no skid plate!! Oops . . . still and option.
    1000 lines!!! Gee that is Cpousnr and Spoog.
    Hostile? This is hostile? Why we are being friendly here. Darn . . . I am here to give facts and links.
    just link em dont post em..
    BEST BUY------------------> RANGER or mazda b4000
    ratings
    Dodge Dakota Very Good
    Ford Ranger Very Good
    Mazda b4000 Very good
    Chevy s-10 Good
    GMC sonoma Good
    Toyota Tacoma Fair
    just to show it UNBIASED oppinion the Tundra got an execelent rating and was a best buy along with the F-150.
  • wsnoblewsnoble Member Posts: 241
    Is this what happens when you don't read the posts for a few days. Wow! I'm not sure who said it but i'll agree, links only please!
    Hind: Good photos of your truck.
    Vince: I'll try to make this as clear as possible, listen carefully!
    I DID NOT DISREGARD YOUR CRASH TEST POST. I ASKED YOU TO FIND OUT IF IT WAS A 4X2 TACOMA OR A 4X4. HAVE YOU DONE THIS? NO YOU HAVE NOT! SO UNTIL THEN WE ARE MIXING APPLES AND ORANGES. DO YOU UNDERSTAND THIS? A SIMPLE YES OR NO WILL DO!
    Also the coffin stament was a jerky thing to post. You deseved it and deep down inside if you have some sort of soul you know you did. I will refrain from refering to you as a jerk, when you refrain from stooping to that level.
    So run along and answer my 4x2 or 4x4 crash question. I await your reply
    Tires: Besides CP does anybody else run the BFG AT ko's or the Michelin LTX AT's? The Firestones on my tacoma are awful and i want to dump them soon.
    -wsn
    but lets see.
    First, there are about 350,000 Rangers made a year in all configurations. Of that for the sake of argument, lets say 65% are the V6 engines, 3.0 and 4.0 which is 210,000 vehicles. Of the V6, the 4.0 is favored about 2 to 1 leaving about 70,000 Ranger V6 3.0 engines recalled for the FUEL:THROTTLE LINKAGES AND CONTROL
    Campaign #: 99S09 as the recall was ONLY for the 3.0 engine:
    So you have 140,000 Rangers recalled for that campaign, plus 11,500 Rangers recalled for the : EQUIPMENT:CERTIFICATION LABEL
    Campaign #: 98S02, which was really a non-issue (remember, that was the label no 16 inch tires on 15 inch rims) for a total now of 151,500 vehicles. Add the 600 Electric Rangers recalled and you get what, 152,100 Rangers recalled, correct?
    In the same time period there were 279,500 TACOMAS recalled, almost double the number of Rangers and Tacoma produces about one half the number of vehicles as Ranger.
    152,100 verses 279,500.
    Which vehicle has a WORSE record for recalls?
    Toyota Tacoma.
    Thought Tacoma was a quality vehicle.
    Why are more recalled for defects than Ranger.
    Superior steel?
    Do the math spooge
    the length of post and hostility comments wern't dirrected at you.. and i dint comment on the other points your site made bc they were valid points. And if i had a 4wd ranger the skid plates would be a concern of mine. But i do really like the looks of the Stainless Steel front skid that Ford puts on them.
    as far as the airbag if i was in a not so bad front end colision i would be glad to be hit by a slower deploying airbag then one that only came out at full speed. And your right the airbag deactivation switch is stupid to be discussing. I just kinda like where the ranger has its switch. out of the way not in the middle of the dash, especially considering i have never used it. If i had a child i would but i dont so it is a non issue , so it makes me wonder why i am talking about it LOL.
    it probably was the 2wd version tested. But does it matter. ok you will be safer in a 4wd if a cadilac hits you. but will that extra height really help you if a excursion hits you. i dont think so. toyota i am sure is working on the issue and the next release of the tacoma will be much safer in both 2wd and 4wd.
    Consumer Reports 2000 small truck comparison
    ratings
    Chevy s-10 Good
    GMC sonoma Good
    Toyota Tacoma Fair
    just to show it is an UNBIASED oppinion the Tundra got execelent rating and was a best buy along with
    the F-150.
    post 700 was suppose to say "... recalled for more defects. . ."
    Yes the Tundra was very well recieved by CR.
    So the Ranger has less problems. What are the years for each of those problems respectively. How did you arrive at 65% for the 3.0 & 4.0 engine? Are the problems regional?
    None taken from your post.
    Vince,
    If your around come out fighting like a man.
    I do think if the test was done on a 2wd Tacoma and i have a 4wd drive Tacoma, that it does matter. Coming from a technical background i cannot accept results from a test that was not done on the same vehicle in question( 4wd tacoma) The rating may or may not be just as bad with the 4x4 or the 4x2, but the equatiuons are way to different. In this scenerio you are hitting with the same car or object across the board but not hitting both the same Tacomas. One has more weight and mass, which i do honestly beleive will matter in the outcome of this test. I do think Vince's site is relevant in helping folks find a place to start in making decsions on safety in regard to future purcahses. I just do not think one can make those types of asumptions when involiving techinal testing results. think of it this way. Does 3 mixed drinks affect 150lb man who has naver had a drink the same way it will affect another man weighing 400lbs? I won't because you have replaced one of the variables in the equation.
    The other half of the point of my post was to show a particular idividual that he was wrong about his position. He was not being ignored, he was just posting inaccurate testing data. This idivdual loves to jump the gun and was firing off questions he didn't want factual answers to.
    I'm a facts kind of person. Heresay and Friends opinions don't fly with me.
    -wsn
  • smcpherrsmcpherr Member Posts: 114
    wsnoble - true, the 4wd drive Taco will perform differently in an accident than the 2wd Taco. Weights, heights are different, etc. But, I would say that the tests do give an approximate indication on how a vehicle frame will react in a collision.
    Say 2 identical trucks run into a brick wall, one with an empty bed and the other with a bed full of bricks. The heavier vehicle should get damaged more, due to the extra weight. Why? The frame is the same, and the extra weight only adds energy to the impact. However, the extra weight found in a 4wd versus a 2wd is almost negligible. The only way that I can see that a 4wd vehicle has an advantage in an accident is height. If a 4wd truck is hit by a lower vehicle, a large percent of the energy in the collision might be deflected under the vehicle, reducing the amount of energy transferred to the passenger. Extra weight only increases the amount of energy in a collision, it does nothing to help protect you.
    I feel that these tests are accurate enough to give a sense of which frame is better at keeping impact energy away from the passengers. They do not say one is always better than the other, but the highest ranking vehicle will more than likely be safer in most situations than the lowest ranking vehicle. I have been in an accident before. I rolled a Blazer on the interstate after I blew a tire and lost control. It rolled seven times, and the drivers behind me told me that in one of the rolls, the vehicle became airborne and landed hard on its top. When it was over, the roof has been crushed down so it was not much higher than the hood. After going through that, I think it would comforting to be in a vehicle that had ranked high in any collision testing.
    The tacoma 4wd weighs about 500+ lbs more than the 2wd version. I still think the 500+ lbs will help you when getting hit. Your loaded bed scenerio has a flaw though. In your example the object is moving with 500+ lbs extra into a fixed object. Our scenerio is getting hit in the side by a moving obeject. The object hitting the Tacoma 4x4. In the scenerio of getting hit in the side you are the stationary object. Your the wall not the object. See what i mean...
    "Say 2 identical trucks run into a brick wall, one
    the impact"
    Your example is B (Tacoma) hitting A (Object. In my side impact example i am comparing B getting hit by A
    Example: If I run into somebody on the side walk while walking, say a heavy man, i have less of a chance of pushing this man then say a smaller man.
    Wouldn't you agree?
    -wsn
    ok... if a vehicle(lets say a excursion) hit a 2wd tacoma in the side it will cause damage and push the tacoma sideways. now anyone who has pushed a vehicle knows that the more it weighs the harder it is to push. (no ford jokes please :) )
    since a 4wd tacoma weighs more than a 2wd tacoma it will resist moving more than the 2wd tacoma causing more damage.. therefor more damage into the driver compartment.
    it is simple physics
  • barlitzbarlitz Member Posts: 752
    If you check out the auto.com site it says a lot of Toyota workers want to become uaw members,Toyota doesn't want it I don't know how this will affect the build quality, now on the average a Toyota employer makes about $7.00 an hour less icluding the benefit package than a UAW worker.I am not sure but I think the Tacoma and Corolla are already UAW built.
    but what about vehicle price..
  • cthompson21cthompson21 Member Posts: 1,102
    Regarding the Toyota's crash-worthiness:
    Why would you believe that a 4x4 Tacoma would fair any better than a 4x2 Tacoma? As far as I know, differences in the drivetrain don't protect the passengers any better. Ride height? I guess that all depends on what hits you... Are there some sort of differences in the doors or other parts of the body? If there are, why wouldn't Toyota use the stronger materials for their trucks and keep their customers safe?
    "Looking solely at multi-vehicle side impacts between LTVs and other light vehicles, approximately 78 percent of the LTV fatal 'torso' injuries are caused by other light and heavy trucks, and only 22 percent by passenger cars . . .
    This increasing disparity of LTV with car weights has increased the threat of fatalities to car occupants and further widening of the disparity will elevate that threat even more. P. 62.
    The mass, momentum, and structural strength, such as the longitudinal stiffness, of LTVs make them aggressive vehicles which are hazardous to occupants of lighter vehicles colliding with them. Pp. 1, 4.
    Most of the deaths in LTV-car collisions are of the car occupants, and the chances of death and injury to those car occupants rapidly accelerate when the striking LTV weighs more than 4,000 pounds. P. 109, fig. 5-11.
    Conversely, there is a direct and constant linear relationship between car weight and fatality risk indexed to the average weight of the current fleet of LTVs: as weight decreases for the passenger car below 4,000 pounds, there is a direct increase in crash risk from collisions with LTVs so that the chances of a car occupant fatality in a car weighing 2,000 pounds is more than 20 times the fatality risk of a car occupant in a car weighing 4,000 pounds.(17) P. 162, fig. 6-6.
    Seriously if your going to go back to 1995 for the Tacoma then you should likewise go back to that year for the Ranger.
    Fact is that the testing for the side impact is only valid for that class car. Read the article I posted above.
    I did search the database for Ranger 1995-00 and for 2 years recieved this from the database.
    There were no matching records for your entry: Ford Truck Ranger 1997.
    There were no matching records for your entry: Ford Truck Ranger 1995.
    Yes I did estimate on the number of Ranges effected by the Fuel Injection seals however please consider that ONLY the 3.0 for Ranger was recalled, not the 4.0. I CHECKED that with Ford before I bought it.
    recalls for the years 1995 to 1997
    I mean.
    that article is for all colisions.. in a head on colision the heavier Vehicle ALWAYS wins.. but in a side inpact the more the vehicle weighs the less it is going to slide and therefor greater intrusion into the passenger area.. once again basic physics.
    even if the 4wd tacoma is safer than the 2wd version, how safe does that make the 4wd drive ranger, considering they tested the 2wd ranger as well??
    just a thought
    What does it make the 4X4 Ranger?
    Safe, VERY safe.
    I do not but the argument that the 4X Tacoma OR Ranger would fair any better or worse in the accident test. There is no data that has been presented. The only thing that MAY factor in is the 4X4 Ranger supercab has 2 more cross member frames than the smaller Ranger and MAY be stronger.
    Well, how bad is the Tacoma in crash tests? Let me for now say this:
    My wife's 1990 Chrysler LeBaron convertable, not a vehicle noted for the highest quality, has a MUCH better crash test rating than a Toyota Tacoma.
    Ford took 1st, 2nd, 3rd, 4th and 5th place at Daytona.
    Where was Toyota? Oh I see, they were parked in the infield. . .
    That portion was taken from a side impact article. Apparently you are confused so go to this link.
    http://www.saferoads.org/petitions/petition.html
  • DTKWOKDTKWOK Member Posts: 131
    Didn't realize that any foreign auto makers are even in this type of race (not a big fan of this racing, myself). I respect the machines themselves but am not too thrilled to watch people race around an oval track aka NASCAR, what's the point? (unless of course it's to see who wipes out first). If you want speed, go over to KART racing, higher speeds, uglier wipeouts!
    I'm more into something that requires the cars to make left AND right turns and go up and down hills, such as: touring, Pikes Peak, Baja 500, and of course the WRC (imagine launching yourself at 60-80mph, 5-8ft in the air in a car, not truck!) Just my thoughts
    DTKWOK
    The Ranger recalls from 89-99 are indeed more than the Tacoma. By far.
    And let me tell you, the reason the Ranger always ends up in recalls with MUSTANGS and OTHER CARS is that FORD recuycles there parts. Your Ranger has components from Fords line of cars and Explorers.
    It was also explained from the Trans expert website that Ford uses the transmission from their cars in the Ranger.
    All this data is hardly mindless. oh, and theres plenty more to come. Im just getting started.
    http://www.nhtsa.dot.gov/ncap/cars/1990MidS.html
    Here the 1990 LeBaron was rated 5 Stars drivers side rash rating.
    http://www.nhtsa.dot.gov/ncap/cars/1990Pkup.html
    Here the 1990 Toytoa P/U was rated 1 star drivers side rash rating
    So my wife’s old Chrysler ha a better rating than the 1990 version pickup and it is a better rating than all the Tacoma’s listed below.
    http://www.nhtsa.dot.gov/ncap/cars/1995Pkup.html
    Here Ranger has a better drivers side crash rating
    http://www.nhtsa.dot.gov/ncap/cars/1996Pkup.html
    Here Ranger has a better drivers and passenger crash rating
    http://www.nhtsa.dot.gov/ncap/cars/1997Pkup.html
    http://www.nhtsa.dot.gov/ncap/cars/1998Pkup.html
    Here Ranger and Tacoma have equal drivers side ratings but Ranger is better for passenger side.
    http://www.nhtsa.dot.gov/ncap/cars/1999Pkup.html
    Here the Ranger and Tacoma are equal for drivers and passenger side ratings but Ranger is far better in side impact testing. Here a side impact crash in a Tacoma has a 45% greater chance of serious injury.
    http://www.nhtsa.dot.gov/ncap/cars/2000Pkup.html
    Here there is no front test planned by Tacoma and Ranger is 4 stars front impact for both driver an passenger and 4 or 5 stars side impact depending on if the vehicle is a standard or extended cab.
    No foreign cars are not in this type of racing. I was just braging a bit that Ford took the top 5. Some people on this board do not think Ford has a racing team.
    The Tacoma and the Ranger in regard to recalls and TSB's.
    That is what I am doing, the 1995-2000 years.
    It indicates that Toyota had a bit of a problem with bringing the Tacoma up to speed.
    BTW WHY is there no mention of the Recall for the 3.4 V6 head/head gasket problem when every Toyota owner of that engine should know that it was recalled? There are other sites, posted above that talk volumes about that recall.
    spoog says"
    ". . .FORD recuycles there parts. Your Ranger has
    components from Fords line of cars and Explorers."
    Support that statement?
    I can think of seeing that there was a sharing of an automatic transmission in the late 80's early 90's but what is your point? Present your factual information that Toyota does not share the same part in it's vehicles.
    By the way a "recylced part" means that it was used once then used again. You have presented NO facts to support that statment.
    Now I will not call you a liar, like you have done to me numerious times (WHAT WAS SOMEONE SAYING ABOUT MATURITY?) but I think you should support your facts.
    I will check for common usage parts on Toyota's. The only one that comes to mind is they put the same diesel engine in the 1981 Pickup truck and the 1982-83 Corolla.
    So if Toyota did that, and they did as I owned an 81 pickup and my sister-in-law owned an 83 Corolla,both diesel with the same engine, are they "BAD" like you imply of Ford?
  • mviglianco1mviglianco1 Member Posts: 283
    "Ford took 1st, 2nd, 3rd, 4th and 5th place at
    Daytona.
    the infield. . ."
    Crossing Anartica and in my case hitting the dunes at Carolina beach this past weekend followed by a complete scrub, polich, and wax.
  • rickc5rickc5 Member Posts: 378
    Hi Mike,
    I didn't say I had "problems" with my '99 Tacoma, other than the power steering leak. I was whining and complaining about it. While my test drive MIGHT have allowed me to detect the complaints I listed, alas, it did not. I should have driven a Ranger for comparison. I didn't do that either. Another mistake I won't make again (another whine).
    So YES, I can be faulted for buying something I now find I don't like. My point was that compared to other Toyota trucks I have owned since 1985, the Tacoma is not an improvement, other than it's faster. The Tacoma was Toyota's first "de-contented" vehicle of the 90's and IMHO,they botched the job and probably will never admit all the problems they've had with it.
    If Toyota learns from its mistakes, their NEXT generation of small pickup will be dramatically improved. Unless the bean-counters say otherwise.
    As I said in my first post, I used to love Toyotas. Now I find myself looking everywhere EXCEPT Toyota for my Tacoma's replacement.
    wsn - the reason I picked a wall for the impact was because a wall would apply forces in the same direction to both 4wd and 2wd vehicles. I couldn't think of a vehicle that would strike 2wd and 4wd trucks at the same angle. I suppose I could have used a semi. My point is as Cthom said, the main difference between 4wd and 2wd trucks that helps in an accident is the height of the 4wd truck. Your example, of hitting a smaller man vs a bigger man, is more suited to the argument of hitting a Ranger vs hitting a Mack truck. Try this one instead... A. Running down the street, you body-check a 150 lb man, vs. B. running down the street, you body-check the same 150 lb man who is now carrying 50 lbs of lead in a backpack. The 50 lbs doesn't help/hurt the 150 lb man much. Assuming you hit him the same each time, he should sustain the same injuries, because his frame hasn't changed.
