For a more detailed criticism of this type of chip, please read below:
How Not to get Ripper Off By Tuning Goodies
You would probably be better off buying an ECU re-flash through Autologic.
Biggest problem is that the supercharger pulley would NOT come off the shaft--seized on there. I had to remove the compressor and press the pulley off on a hydraulic press.
By all means, if your car lives in a harsh winter climate, you might anticipate a struggle with stubborn bolts on your MINI's front end.
I'll let you all know how the modification affects performance.
VISITING HOST
You can rest assured though that BMW will replace the parts free of charge, just so that they can avoid bad publicity...
Can it be added if it is not there?
Thanks, Hal
