Visitor Agreement.
The Power stroke is an under rated motor and has great reliability. I know several people who have had both and tow large boats and they all switched to the Ford Power Stroke and say it is a much better motor with better fuel mileage.
I don't know..........
410,000 miles?? Hmmmm.....
All Diesels are made for, as you say HD use, get a clue!!! because the 5.9 Cummins is offered in more then just Dodge pickups, it is offered in Medium Duty applications and construction equipment i.e. Rough Terrain 4x4 Forklifts with telescopic booms. I was speaking to the audience at this Forum, I guess you do not know what Hot Shots drivers are, pickups, long distance, HIGH miles, Hmmmmm...clueless.......
I've been in the oilfield industry, so i've seen all the heavy duty truck applications, pipe haulers, hot shot drivers, ton and a half tool body trucks, welding trucks. I've seen them all get many miles, and i've worked on every diesel engine froma 100 hp Detroit Dieselt to 2000 hp Caterpillar and Cummins, so please don't call me clueless.
I've seen diesels in the high mile, heavy load applications, and they are the best for the duty. I've never seen a Cummins with high miles, because hardly anyone in that industry uses them, mostly powerstrokes.
Piston rings, and rod and main bearings can make 400,000 miles, the materials we have today are SO much better than 10 years ago. But cams, injectors and fuel pumps are high wear items. Fuel pumps are usually the first to go, and 100-150K is about all they make. injectors are usually the next.
The core of the engine can last that long, but theres got to be some parts replaced. And as far as the rest of the truck, i would love to see it after 400K.
Faster acceleration
More noise, raucous note
Needs catalytic converter
The Cummins:
Better fuel economy
Mellow exhaust note
Needs no cat
Both are big, big sellers. 100k warranty is on engine only. Diesel engine repairs are very expensive.
Buy if you need it to haul your load, but if you are expecting a payback on fuel saved over a gas engine, one fuel injector, or pump, if required will eat up all your savings, pronto.
Unless you have two Forum names, alias Rocles as I directed my #12 post to, then you need to back off, I never called you clueless. If would like to debate Diesels then jump in, I have been in the Heavy Equipment buisness for 19+ years, and you?
I think you should understand what a Heavy Duty truck application is, it is not 1 1/2 ton tool bodies, welding truck or Hot Shot truck, those are considered light duty applications (under 26,000 GVWR) no truck scales needed. Just because people in your industry do not use Cummins trucks, does not mean the rest of the world is doing the same, there are more professions then Oil, and there are more 5.9 Cummins applications then just 3/4 and 1 ton Dodge pickups, you should know that if you work on all those different diesels. You are right I would like to see some pickups after 400,000 miles, they probably would not be worth squat, but I know from experience 400,000 on a Cummins engine is not unreasonable, just because Cummins puts a 5.9 in a pickup, does mean the engine materials, design, and durability are any less then an 80,0000 GVWR Tractor. Sorry if I offended you in some way, but we all have our own experiences, and preferences in vehicles which we choose to purchase and drive.........Bill
Back off!! bmckenzie called me clueless!! Stop trying to garner my deserved ignorance! LOL!
bmckenzie,
Feeling bitter today? I do understand and acknowledge that Few (RARE) vehicles have reached 400,000 miles. I wasn't attacking your beloved Cummins engine-rather questioning that a one-ton Dodge (of all brands-DOdge) that has been used can achieve such mileage. These type of "facts" are hard to prove over the internet which is plagued by embellishments.
Oh thanks for the inclusion of applications that the mighty 5.9 is used for. Without your great big HD experience--I am clueless!
During your next lesson--can you tell me what the term: Single screw and double screw mean? Your SO informative for my clueless life! Golly! Telescopic forklifts?? Gee willikers!!!
Hmmmm...someone is getting a little flustered....
200,000 miles on the original brakes from a 84?
Where do you live? It might be relevant to your extraordinary situation.
(Hey Billy, No "hmmmm" here. OK? Don't get nutty about brakes and referring to some forklift used in the Amazon at night under a full moon with a Macall sleeping!)
My Ford f250 powerstroke will still be going strong though.
That's good and effective. No screaming or hollering! I like it.
My Ford gas burner got 8 to 10 mpg so even with the price increase thats starting to go down, and gas is starting to go up I'll do better with the Diesel.
Mike waiting for my 2001 Dodge 3500 4X4 Cummins
I think its crazy to push up the price of diesel fuel. That is inflationary in that it is used in almost all modes of commerce including trucks trains jets heavy equipment ect. That affects the price of everything.....
He would probably explain the fix maybe even sell you the part etc, as it is a waistgate fix.
I dumped my 2000 joke and got a 2001 cummins HO dodge. I am happy again. My powerjoke had 16 lbs boost. The cummins is rated for 26lbs max and this one feels like it has most of it.
Good luck,
Fatso
Here from my two latest issues of the TDR.
They don't list year of truck but have pictures. Owners must present a picture of the truck and Odometer for credit of mileage.
New body style:
300K - 378k 1 ton Boca Raton FL
200k - Westwood NJ
233k - 1 ton - Danridge TN
Old Body Style:
302k - 3/4 ton - Lake City FL
214k - 3/4 ton - Peralta NM
These are just a few of the long running trucks.
David
Also see too many topics on the p.stroke w/ problems and not one on the cummins.
I think the ford is a better truck overall, it's too bad they didn't keep the rights to cummins, that would have ben a great truck. Dont get me wrong, I like my dodge, but it's the cummins that I stick with, God forbid they put the cummins in the tundra, I guess I would be driving one of thoes (with a bag over my head but I guess I would)
Good luck
R.....
when I go to florida from where I live, round trip is about 5000 miles, it takes me 6 days do do that. You figure it out from there.
a.k.a. Albert
Now you know why my truck has so many miles, and why I still have time to go on the net and B.S. with all my fellow truck nuts.
izzat anything like "beer nuts?" Or "You might be a Redneck if....?"
Inquiring minds want to know?....
Front Porch Philosopher
"Where and Truck or V8 sound will turn your head, and you can tell what engine it has in it by Sound"
lol
This doesn't include cars with beds, such as Toyotas
GMontgomery
R.....
